Question about Bugaboo Cameleon Stroller
My bugaboo cameleon is sticking on side when I try and open it up, how can I fix this?
    Champion:
  • 274 Answers
Contact www.buggypitstop.co.uk they are the only company that repairs bugaboos
Posted on May 21, 2010
    Guru:
  • 541 Answers
How to fix a Bugaboo Handle
If you are not a handyperson type, take these instructions to you local Bicycle Mechanic or Small engineering shop.
The bugaboo handle fault is caused by two small plastic pins shearing of a plastic disk that actuates two metal locking rods. Why bugaboo uses a plastic disk for this critical component is beyond me!
1/. Remove the domed star lock washer. This is the hardest part of the job. Most people try to leaver this off in the hope of re using. First problem with this is you will mark or damage the surrounding plastic second is star locks are not intended for reuse and will never hold as well as when first used, so best find a new replacement. A hardware store should be able to source some for you. Quickest way to remove a dome washer is to carefully cut a slot in the dome with an angle grinder and then use a large screwdriver to carefully prize one side up so you can fit a screwdriver. Note the walls of the aluminum hub axel are thin and easily distorted, make sure you only lever the Domed Star Lock and not hub axel. Use one screwdriver as a support and another to lift off the Domed Star lock.
Note it is best to open and repair one side at a time, so your moving and flexing one side of the handle does not dislodge parts in the other side. The hub and disks are mirrors of each other and not interchangeable. The side with the brake lever is left The Bugaboo parts will have an "L" after their serial numbers.
2/. The lock mechanism is very simple; a wire rod rotates a plastic disk. Check the hubs for ware. If too badly worn or damaged you will have too much movement in the locked position. The Frog and Chameleon use the same plastic hub find another frame to salvage hubs from. They are held in by a single aluminum rivet.
The disk has two plastic pins that move the locking rods in and out of the inner hub into and out of the outer hub. You need to either repair the disk by drilling out the pin stumps and finding a replacement metal screw you can fit / glue in. Or (my preferred choice) have a new metal disk fabricated that will last a lifetime.
clip_imamy bugaboo cameleon is sticking on side when I try - clip_image006.jpg
3/. Reassemble handle locking hub and check operation. If wire rods seem to be in the incorrect position, loosen the top plastic fittings where the handle extends from by removing the small self-tapping screws and wiggle things into alignment. (I use a small amount of the grease used for taps to give a smooth action) If all is working well fit the new star dome on the hub shaft and tap home. To protect the dome finish I use a large socket from my socket set and an old rubber washer from a toilet cistern. Repeat operation on the other side
I have available kits with two (left & right) laser cut metal disks with stainless steel pins fitted and two new star dome washers. Cost is $150 New Zealand plus shipping. If you like a set, you can contact me macnutz@xnet.co.nz
Regards
Steve
Posted on Oct 31, 2010
2 Suggested Answers
  • 11 Answers
SOURCE: Faulty Latching Mechanism On Bugaboo Cameleon
SOUNDS LIKE THE SPRING NEEDS REPLACING... INSIDE THE HANDLEBAR ARMS SHOULD BE A CROSSHEAD SCREW... UNSCREW THIS AND PULL THE HANDLEBAR OUT, THEN SEE IF THE SPRING IS BROKE OR MISSING AND REPLACE IT :)
HOPE THIS HELPS X
Posted on Jul 14, 2009
How to fix if bugaboo front wheel spring is broken?
Not worth the time trying to repair. Bugaboo sell the wheels as a spare part and there are lots of wheels secondhand on eBay.
Nov 20, 2011 | Bugaboo 'Cameleon' Stroller
I've been having intermittent problems with my Bugaboo Cameleon's chassis. When folded up and trying to unfold, one side often became stuck and took patience and gentle coaxing to finally open both sides...
BUGABBO BEE HANDLE PROBLEM!
I've problem with my bee !
The handle just slide down without cliping The locks SO IT'S IMPOSIBLE TO PUSH THE BEE AS THE HANDLE is moving all the time????what can do?please help
Sep 08, 2010 | Bugaboo Cameleon Jogger
My bugaboo cameleon chassis 2007 model won't open,
Go to www.buggypitstop.co.uk they are the only company that repairs bugaboo chassis
May 19, 2010 | Bugaboo Cameleon Jogger
Bugaboo cameleon snapped break cable
try buggypitstop they sell new and second hand parts for bugaboo. They have a website
Oct 23, 2009 | Bugaboo Cameleon Jogger
Bugaboo Cameleon
There a company based in London www.buggypitstop.co.uk and they do repairs to bugaboo's
Oct 03, 2009 | Bugaboo Cameleon Stroller
HOPE THIS HELPS X
Apr 17, 2009 | Bugaboo Cameleon Jogger
Bugaboo Replacement Brake Foot - Cameleon
you can try www.buggypitstop.co.uk they do repairs to Bugaboo they should be able to help. They fixed my pushchair and did a great job. I would highly recommend them.
Mar 05, 2009 | Bugaboo Cameleon Jogger
Bugaboo cameleon problem
call bugaboo depends what it is sometimes it can be fixed
Tel # 1-800-460-2922
Sep 12, 2008 | Bugaboo Cameleon Jogger
Bugaboo Cameleon Stroller Logo
193 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
