Question about Vtech Lands Phones
Deregister a ds6322-4 without the base - Vtech Lands Phones
For the Vtech cordless phones model DS6322-4 models
In the handset press
*331734# and the menu button, yur handset will be deregistered.
Enjoy unlocking :-)
Posted on Jul 31, 2010
  • 11 more comments
  • jimmy219 Jan 27, 2011
    I couldn't believe it but this actually works. I bought a DS6322 set with 4 handsets at Costco a year ago, then snagged the 3-handset version off Woot a few months ago thinking it would be a cheap way to add 3 more handsets. Couldn't figure out how to join the new handsets with the old base no matter what I tried.
    To confirm the procedure - make sure the base to which the handset is paired is not powered on (pull the plug). The handset should say "No power or out of range" or something similar. Press *331734#" then MENU/SELECT. If it worked, the screen will go blank and you'll hear three beeps that go up (if you're musically inclined, the actual pitches are G3, F4, D5). When the screen comes back on, it will say the thing about pressing "HANDSET" on the base and then "#" on the handset. Follow the instructions and you're all set!
  • luciangel Mar 11, 2011
    Thanks for much for this! Vtech support said I had to go buy NEW PHONES after I bought a replacement base for one lost during a move. Happy to say I now have 3 phones, the 2 old ones and the new one all sync'd to the new base using this solution. My phones were a different model, but it still worked! I have model number CS6229.
  • coucou1968 Jun 21, 2011
    Thank you sooooo much! I tried everything, no success... until I read your solution. It worked perfectly for the VTech DS6221! Thank you again!
  • GP Estep Feb 07, 2012
    thank you so much for the info. i've tried everything for days now, to deregister my radio shack 43-327 system that was mis-matched, this solution worked perfect. and believe me, i've tried many other de-regerister codes from other brand names, BUT THIS IS THE ONE, THANKS A MILLION
  • nrlorenzo
    nrlorenzo Jul 22, 2012
    Gracias, Me funciono e maravilla para el Vtech LS6425
  • Marianne Sep 04, 2012
    This solution worked for us but we gave up on the ds6322. Now we have a ds6472-6 (handsets are ds6401) - Does anyone have this code to reset one of the handsets? Thanks, Marianne
  • El Greco Nov 04, 2012
    Gracias. Funciono perfecto par ael ds6229. Works fine for the ds6229 thanks
  • efilnikuf65
    efilnikuf65 Nov 08, 2012
    Thanks a bunch!!! I had a 4 handset set, 2 broke, then I bought 3 handsets at an auction that didn't come with a base. Cost a dollar to get back where I was and have an extra handset too!
  • efilnikuf65
    Thanks! I purchased 3 handsets at an auction in a box that originally came with 5. I was fighting trying to register them for 3 days. The users manual was no help. at the price new handsets cost I saved a ton of money!
  • mr_robert_st
    mr_robert_st Jan 08, 2013
    Works great. Needed to do it a third time, but the first time, I didn't press "MENU/SELECT" after the numbers, and the second time, I may have made a typo. Star, 3, 3, 1, 7, 3, 4, Pound, MENU/SELECT worked! Three confirmation tones followed, then the message to press "Find Handset on base..." appeared. THANK YOU!!!
  • caitsith2 Nov 28, 2013
    Awesome. Exactly the solution I was looking for. Had an odd-ball handset where the base for it was missing, and I wanted to tie it to my existing CS6219-3 base as a 4th hand set.
  • Jan Atkinson
    Jan Atkinson Feb 14, 2014
    Thanks! It worked like a charm on my cs6229 handsets. I was getting nowhere fast with the user guide!
  • Anonymous Dec 12, 2016
    I have spent many hours accomplishing Zero. I followed your advice and BINGO! I can't thank you enough.
    New Friend:
Thanks. *331734# then Menu Key worked for my CS6425 (CS6409) handset.
Posted on Apr 20, 2015
This works great for the handsets that were registered to a broken base station, but what about the AT&T TL7610 headsets that were registered to this base station? There's no way to enter a code without a keypad...
Posted on May 14, 2011
  • 1 more comment
  • kjbender Oct 16, 2011
    Thank you so much! Worked perfectly on my DS6322-4 (purchased 2 sets at Costco like you and wanted to combine them - not using the 2nd base, just the handsets). Shame on V-Tech for not printing this in the manual and driving others to buy more expensive single add-ons.
  • efilnikuf65
    kjBender since you purchased 2 sets, all you needed to do was hook up the base on the second set, charge the batteries, and then press find handset on the base for 10 seconds. Within a few seconds all handsets registered to that base would say "not registered" put the second base up in case you need the spare, and register it's handsets to the new base. The method found here is only needed when the original base is not available for whatever reason.
  • kevin satterfield Dec 24, 2013
    Works great exactly the fix
    New Friend:
I have a CS6629 and it didn't work. My handset says out of range/no power at base. These were registered to a base that went bad and I want to reregister to mine. When I press in the code above, it just shows up as 1--331-734 and a character that looks like an upside down capital A
Posted on Sep 05, 2014
  • John Fako
    John Fako Sep 05, 2014
    I unplugged the base and tried *331734$ menu and it says enter number
  • John Fako
    oops, meant # not $
Unplug power from most Vtech Base Stations if you are doing the manual de-register using *331734# then Menu Key. It will work on most Vtech Handsets.
Posted on Aug 22, 2014
3 Suggested Answers
  • 8 Answers
SOURCE: Deregistering a phone you can't find
I had trouble deregistering one of the phones, as it has to be close to the original base (kept telling me out of range). I found out that pressing END and #, also deregisters.
Posted on Aug 25, 2007
SOURCE: I need to deregister all the handsets from the vtech i5867 base unit
My hand held still says "Searching for Base"???
Posted on Nov 08, 2010
How do I deregister an orphaned Vtech sb67108 handset to use on another bases without the original base
Here are the steps: Press menu, then press *883247# and then press the up arrow. Select deregister and then unplug and take the battery out for 10 seconds. Plug the phone back in and it's ready to be registered to another device.
Oct 06, 2014 | VTech Communications 4-Line Cordless...
Deregister AT&T SL82118 handset
The following is for the model ATT 5830.
Enter the following sequence on the base station including the * symbols.
**335782
This will deregister all handsets associated with that base station. Handsets can then be added back into the system by entering the base station ID into the handsets one by one. The base station ID is on the bottom of the base station itself.
Feb 06, 2014 | AT&T 5830 Cordless Phone
How do you deregister vtech ds6401 handset without the base?
Enter the following on the handsets you want to deregister: *331734#, followed by the left soft-key (the key labelled "-" at the top left of the keypad).
Jul 13, 2012 | Lands Phones
Deregister used panasonic handset without base
On another working handset do the following;
Menu #131
Scroll and select the handset you want to deregister
Confirm you want to deregister
"Deregister" screen will display and handset will be deregistered
Feb 15, 2012 | Panasonic KX-TGA650B 5.8GHz 2 Line...
I need to deregister a DS6101 without the base. I needed to replace the base and once we installed the new base, the extra handset that we had registered with our old base shows the following message...
Called the manufactuer.... To do this enter on the handset you want to deregister:
*331734# and press (Menu Key# 1 - top uppermost left button that is unmarked).
This will put the handset back into the register mode.
Hope this helps,
James Pavicic Jr
Feb 16, 2011 | Vtech DS6101 19 GHz Cordless Phone
I bought some handsets but they were registered to another base. How do I deregister without the base
First, select Deregister HS from the main menu. Secondly, press the red phone button and the # key simultaneously for about 5 seconds to finish deregistration. You will then see a message telling you to place the phone in the cradle of the base unit to register it to your unit. An "operation complete" message will confirm that the handset is now registered and ready to use. Good luck.
Jan 16, 2011 | Uniden TCX905 Cordless Accessory Handset...
My uniden phone says - out of range
Uniden wxi477 out of range fix
This problem arises when the handset does not communicate with the base.
These are the steps:
1: Deregistering the handset
2: Registering the handset to base
Deregestering clears the stored (incorrect) base information on the handset.
Reregestering allows the base to assign a new ID for the handset.
Deregistering- press and hold the OFF (red button) and the # button on the handset for 5 seconds. select base unavailable and press OK. Are you sure appears. select yes and press OK. you will hear a confirmation tone. The handset will delete its own base information without trying to contact the base. It will now display MODELS VARY PLACE HANDSET ON THE BASE FOR REGISTRATION.
Registering the handset with the base- Make sure the tel. line and power is plugged into the base.
Press an hold the register button under the base (located between the tel. line and yellow power socket under the base) for 5 seconds until the red light flashes. At the same time press and hold the # button on the handset for 5 secs. You will hear a tone and It will now display REGISTRATION COMPLETE.
If it says registration failed: Retry the registration steps. Make sure the handset have enough battery power. If not charge for 15-20 hrs.
Check your connections on the base and make it is getting power.
The Steps above was my fix for the uniden wxi477 out of range problem.
Good luck.
May 25, 2010 | Uniden TRU9585 Cordless Phone
I have a Pansonic kx-tga270s that is registered to a base I do not have. Is there a way to deregister it.
you dont need to deregister it if you have not registered all 8 hand sets with your base unit. Just register the new one and the base will assign a new # for this new. I you had registered 8 hand sets with your base already, you need to remove(deregister0 one handset from your base(it can take only upt 8).
If it still not registering please deregister as follows:
on the base unit, press program, them mute, then enter 335#, then enter the handset number you wish to deregister.
after deregistering try to register your new hand set.
Nov 19, 2009 | Panasonic KX TGA270S Cordless Expansion...
NEED TO DEREGISTER LOST HANDSET
The "END" and "#" key combination can be used for several purposes:
1) If wanting to use an ALREADY REGISTERED HANDSET on an alternate base, and if if the INITIAL BASE isn't available to deregister the handset:
1a) Press "END" + "#" until it for 5+ seconds (wait for it to beep)
1b) Choose the "Base Unavailable" option
1c) That'll deregister the CURRENT HANDSET so that it can be re-registered on ANY base.
2) If a BASE has a handset registered to it which you no longer want registered but the registered handset is missing or broken:
2a) Grab another WORKING handset which is properly REGISTERED to the BASE in question
2b) Press and hold the "END" + "#" key for 5+ seconds (wait for it to beep)
2c) Choose the "Deregister HS" menu option
2d) Pick the REGISTERED HANDSET # to de-register. (Every other registered handset EXCEPT THE ONE YOU'RE ON will appear in the list!)
May 08, 2009 | Uniden TRU8866 Cordless Phone
Apr 29, 2007 | Uniden TCX860 Cordless Expansion Handset
Lands Phones Logo
4,967 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
