Question about Canon LaserCLASS Fax 710 Printer
Can't figure out how to use the fax function - Canon LaserCLASS Fax 710 Printer
Can't figure out how to reset date/time/header information on faxes & reports.
After you change to fax mode, press menu and then general setup for the date and time. After that you scroll down to fax setup to change the header.
Oct 16, 2009 | Brother Multi-Function Center MFC-240C...
I am having trouble with setting up the fax function with my phone line. I have one line I am trying to use for both phone and fax. I am able to receive faxes automatically when I am not on the phone. ...
You need to make sure that the line from the wall jack is plugged into the "Line" jack on the fax then the phone is connected to the "Phone" or "Out" jack. You might want to check the number of rings before your fax picks up.
Oct 14, 2009 | Office Equipment & Supplies
My fax machine sends faxes, prints, and received faxes but the faxes are blank. We have been trying to figure out the problem and while fiddling with the machine have actually received a successful fax???...
Probably not. You can change that setting in the user modes in menu/function and set it to 99 minutes. HAve you tried another drum unit? Your charge corona wire in the drum unit maybe broken!
Aug 28, 2009 | Brother IntelliFAX 4100 Laser Fax
Need to change the pickup from one ring to picking up on the 5th
This should do it:
Press the {Function} {6} then enter
the access code {2} {2} {2} {2}.
Then press {6} {1} and the {Yes} key
press the 'next' (right arrow) key until it displays "set number of rings" . Press "yes" (the current setting is displayed). Press "no" to change. Enter the desired number, then press "yes" to set. Press "function" to exit.
Please rate me :)
Mar 14, 2009 | Ricoh 2050L Laser Fax
No dial tone
plug it in to power socket ,turn it and phone jack on,go to HELPand using resolution or function reset ever item listed.from harry in australia
May 10, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
HP Office Jet 6110 All in One faxing
This document covers the basic fax functions of the HP Officejet 6100 series. The HP Officejet 6100 series can perform the following functions:
  • Send and receive paper faxes.
  • Send and receive color faxes. Color faxes can be sent only to color fax capable machines. If a color fax is sent to a black-and-white only fax machine, the HP Officejet sends the fax in black and white.
See Figure 1 below to identify the buttons in the Fax area of the front panel. Figure 1: Identifying the fax area of the front panel c00259777.gif 1- Turns Auto Answer on or off 2- Scrolls through speed-dial entries 3- Redials the most recently dialed number 4- Dials fax numbers, enters text, and specifies menu items. 5- Starts a fax 6- Changes the fax resolution 7- Dials one-touch speed-dial numbers Fax settings Most fax settings are configured during installation through the Fax Setup Wizard. These settings, and some additional options, can be accessed through the front panel menu (see Figure 2). Figure 2: Changing fax settings from the front panel menu
1. Menu: enters the menu system.
2. Right and left arrows: navigate the submenus and options.
3. Enter: selects a submenu or option.
4. Cancel: exits from the menu. c00259778.gif Sending a fax To ensure the best quality when sending faxes in color, use a color original instead of a color copy. Follow these steps to send a fax:
  1. Load the original. Load originals directly on the glass or in ADF. For multi-page faxes, you must use the automatic document feeder (ADF). Loading original on the glass Place the original, print-side down, on the front-right corner of the glass. Loading original on the glass c00259779.gif Loading original in the ADF Place the original, print-side up, in the ADF. Adjust the paper-width guide to fit the original. Loading original in the ADF c00259780.gif
  2. Enter the fax number using the keypad. Dial the number just as you would from a telephone (dialing 1 before an area code, etc.)
  3. Press Start Fax Black or Color.
  4. If there is no original in the ADF, the display will read, "Send from Glass? Press 1 for Yes or 2 for No"
    • Press 1 to scan the document from the glass.
    • Press 2 to load the document in the ADF. The display will read, Load original, then press Enter .
Apr 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
PANASONIC UF 8000 FAX
Normally function/Menu and start should print the help list or a separate help button may also be provided.
Samir
Mar 13, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Canon LaserCLASS Fax 710 Printer Logo
118 people viewed this question
old marine
old marine
