Question about Microsoft Xbox 360 Console
Xbox red with 2 red flashing lights
My Xbox has 2 red flashing lights, I check on the net, this says overheating and recommended the change of the heat transfer gel, which I did, the problem still persists what to do
    Problem Solver:
  • 5 Answers
Change your thermal pads as well. then overheat your xbox by wrapping it in towels and leaving it for about 20 minutes. let it completely cool and then turn it on again. this should reset the overheat sensor that keeps your xbox from booting
Posted on May 06, 2010
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
3 red static red lights ,not flashing lights, just happened no prior warning
Hi there tazdodds123
What to do when your xbox Has problems with flashing red lights RROD/red rings of death.
You will need some simple repairs done on your XBOX as the GPU chip (Graphics) or the CPU chip (brain) or even both have lost connection to the motherboard Due to overheating.
Option 1
You can send this off to Microsoft if your still in warranty because it is included in there free fixes so they will do the collecting for you, fix it and return the Xbox to you, all for free, but it will take 4-6 weeks.
Option 2
If you are out of warranty its the same process as above but its $150 in cost
Option 3
What I recommend is a XBOX REPAIR GUIDE that will show you the simple steps yourself, you will be up and running again in less than an hour and the cost is far less than option 2 & 3
Feel Free to leave me a comment if you need further assistance.
Jul 09, 2010 | Microsoft Xbox 360 Console
I have 2 flashing red lights but they burn
if lights are flashing and your Xbox is not turning on then it has been blocked by Microsoft probabaly if there is a hardware problem i dont understand your question but i think that your Xbox must be hacked so it has been blocked by Microsoft there are ways ti get around this Xbox-Scene
one site is this above
For Softmodding
Mar 09, 2010 | Microsoft Xbox 360 Console
Plays games then stops when red lights start flashing
How may red lights are flashing?
1 red light normally E74 error message on screen
2 red lights overheating
3 red lights the GPU and the CPU have overheated.
4 red lights is the AV cable not plugged in properly.
You can fix the 1, 2, 3, red lights yourself or send it in for a fix
Oct 25, 2009 | Microsoft Xbox 360 Console
XBOX 360 TWO RED LIGHTS FLASH
the two flashing lights is the code for your console overheating make sure nothing is on top of or behind the xbox and make sure it is not in an enclosed space
Sep 20, 2009 | Microsoft Xbox 360 Console
When the xbox 360 is up straight the 2 red lights on the buttom side light up. nothing plays. and is not over heating. whats wrong?
actually the two red flashing lights means your xbox is overheating you must be blocking a vent or something when it is upright
Sep 18, 2009 | Microsoft Xbox 360 Console
What is the problem when red light is appear?
the other tech is correct but theres also other causes. if 4 red lights are flashing making a full ring your av plug at the back of the xbox is not plugged in. if it has 2 red flashing lights yor unit is overheating. 3 red flashing lights means your cpu is unstuck and is stuffed. 1 red flashing light is a HDD issue
Jun 16, 2009 | Microsoft Xbox 360 Console
2 red ring
try keeping your xbox wrapped in towels
Mar 29, 2009 | Microsoft Xbox 360 Console
Three rings of death
Your system will need the 3 red light service. The 2 red lights flashing indicates overheating. We can fix this for you if interested email for estimate
xbox360fixer@verizon.net
Thanks
Jan 13, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
59 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
