Question about Lowrance MapCreate 6 and MapCreate TOPO CDs GPS Receiver
I'm having difficulty installing MapCreate 6.3 on Windows 7
I'm having difficulty installing MapCreate 6.3 (Canadian Version) on my laptop running Windows 7. Is there something different that I need to do?
I originally installed the software on a laptop running Windows Vista. The local supplier provided me with step-by-step instructions on how to install it in compatibility mode as Windows XP (sp2) and it worked just fine. Unfortunately, my laptop was stolen and I have purchased a new one which runs Windows 7. I tried installing the software on Windows 7 and although it appeared to install properly I recieved an error when I tried to run it. I then uninstalled it and tried installing it using the instructions to install it in compatibility mode as Windows XP (sp2). Again it appeared to install properly but generated an error when I tried to run it. I have uninstalled it again.
2 Suggested Answers
  • 30 Answers
SOURCE: Loading Maps
There is an update for MapCreate to work with VISTA. Go to http://www.lowrance.com/en/Downloads/Product-Software-Updates/MapCreate-7-Windows-Vista-Update/ to download.
The ENHANCED LAKE MAPS are already built into MapCreate 7 so if you can get it working with VISTA with the update, you may have what you need.
MapCreate is mostly land based mapping so may not do much good on thewater.
The Enhanced lake mapes are only on certain lakes.
Go to http://www.lowrance.com/en/Products/Mapping/Enhanced-Lake-Maps/Downloads/ for a list of available lakes.
These Enhanced Lake Maps have depth contours but are not as good as Navionics, or Fishing Hot Spots, or LakeMaster charts.
Go to http://www.lowrance.com/en/Products/Mapping/ to see mapping options.
If you can get MapCreate 7 working on your computer, try it out. If you decide you need better mapping you can always get a better mapping card later.
Posted on Jul 11, 2009
Download turbo tax to windows 8
Since it is a 2009 Version, that may be the problem. Can you try it on a Windows 7 OS to see if it runs on that platform?
Apr 15, 2014 | Intuit TurboTax Deluxe Federal & State...
Print shop deluxe version 6 on 64 bit windows 7
download free virtual machine then you can install xp on your windows 7 64 bit pc. then install your print shop 6.0 and you can use it just like you did on your older pc. windows 7 professional has a mode that you can also use windows xp.
Feb 11, 2013 | Broderbund The Print Shop 21 Deluxe Full...
I recently purchased a new computer (HP/Windows 7) and am having difficulty loading my copy of PDFCreate!3. The error message is: "AddPrintDriver Cause of Failure - 2". Is this version of...
hi,
it does appear that even create 4 didn't have windows 7 support. You may try installing and then changing to windowsxp compatible mode by right clicking the icon and selecting properties and the compatibility tab then place a check in "run this program in compatibility mode" and choose windopws xp. and or install virtual PC with windowsxp compatible then install and run your older software in a virtual machine.
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Aug 08, 2011 | Computers & Internet
I have a problem in downloading sound driver for window7
There are no officially supported Windows 7 drivers for the Acer Aspire 5570 notebook. However, the Vista drivers should work just fine.
If you don't know whether you have 64 bit or 32 bit Windows 7, then please follow these steps.
1. Press Win+R to open the Run command.
2. Type "MSINFO32" into the dialog box and press enter.
3. Look for item "System Type" and note whether the value is x64 or x86. (x86 means you have a 32 bit OS)
Regardless of whether you have 32 bit or 64 bit Windows 7 follow these instructions:
1. Go ahead and download 32 bit Windows Vista drivers by following the link: Acer Aspire 5570 Audio Drivers
2. Save file to the Desktop for easy access.
3. Extract ZIP file to Desktop.
4. Open the extracted folder.
5. Right click on the file "Setup" and select "Properties".
6. Select the Compatibility tab and check the box for "Run this program in compatibility mode for Windows Vista (Service Pack 2)". Click OK.
7. Double click the "Setup" file to run the installer. If the installer completes, then restart the computer and play a music file to see if you have sound.
If the installer fails, then follow the next set of directions:
1. Press Win+R to open Run command.
2. Type "DEVMGMT.MSC" and press enter.
3. Look for a device that has a yellow exclamation point next to it. If you have more than one, look for a device that says "Multimedia Audio Controller".
4. Right click on the device that has a yellow exclamation point next to it and select Properties.
5. Click the Driver tab and select Update Driver.
6. Click "Browse my computer for driver software".
7. Select "Browse...".
8. Browse to the extracted folder and select the "Vista" folder if you have the 32 bit version of Windows. If you have the 64 bit version of Windows, then select the "Vista64" folder. If Windows tells you there are no compatible drivers after step 9, then select the WDM folder and repeat step 9.
9. Click OK and then click Next.
10. Ignore all errors that Windows may give you and install the driver, restart the computer, and try to play a music file.
Good luck, post back if you have any difficulties, and thanks for using FixYa,
Apr 10, 2011 | Acer Aspire 5500 5570-2609 Laptop
What is the procedure to install a 32-bit softwares in to my laptop(windows 7,home premium,64-bit) ?
Most programs designed for the 32-bit version of Windows will work on the 64-bit version of Windows. Notable exceptions are many antivirus programs.
Device drivers designed for 32-bit versions of Windows won't work on computers running a 64-bit version of Windows. If you're trying to install a printer or other device that only has 32-bit drivers available, it won't work correctly on a 64-bit version of Windows.
Windows 7 64bit does run programs that will run on windows 7 32bit, see here
How Windows 7 / Vista 64 Support 32 bit Applications
BUT not ALL 32bit programs will run on Windows 7!!! There are many programs that will run on Windows XP and before that will not run on Windows 7. IF you had Windows 7 Pro version (or upgrade) there is a program you can download from Microsoft that will simulate an XP environment to allow programs to run called "XP MODE".
Try to install the 32bit software first. If installation not succeed, it would be better if you first look into a newer version of the program you want to run.You have to consider that a newer version of your program might not be that much more expensive than upgrading to pro, and with the newer version, usually comes newer features.
Hope this help and if helpful RATE please.
Feb 17, 2011 | Microsoft Windows 7 Home Premium 64BIT...
PPC6800 (Sprint) Windows Mobile 6 ... internet sharing worked great with Vista - just start internet sharing on phone with it tethered to USB port on laptop ... press connect and my laptop is on internet...
The issue you have is the 64 bit version of the operating system witch can foul things like this up.
What you can do is install the windows 7 32 bit version this will clear things up. So what we are talking here is a compatibility issue with the windows 7 64 bit operating system version.
I have investigated this with many tethered phones and do wish you the best of luck with this solution.
Thanks for giving Fixya.com the opportunity to assist you in your problem.
Rulds2008.
Nov 26, 2010 | HTC PPC-6800 Smartphone
I bought a used laptop and I tried to connect it to isp and i used the cd that i recieved with my service. But when i try to install it it says i need nt6 because i only have nt1. how do i get this nt6
I think that the laptop is running Windows NT with Service Pack 1 installed, and the software that you are trying to install requires Windows NT with Service Pack 6 installed.
However, the _bigger_ issue is that Microsoft stopped supporting Windows NT (at any level of Service Packs) several years ago. Therefore, any computer running Windows NT that connects to the Internet is likely to get "hacked" within a few minutes of being connected.
So, my advice is to either "junk" the laptop, or try to find a "Microsoft Windows 2000 Upgrade" CD-ROM and license-key, and update your computer to use Windows 2000. However, Microsoft will stop supporting Windows 2000 in July 2010, i.e., just a few months away.
If you really want "Service Pack 6", find a friend with a CD-writer and Internet access. Access http://www.microsoft.com/downloads and search for 'SP6A' -- download it, burn it to a CD-R, and carry the CD-R disk to your computer, and install it.
Then, run "Windows Update" -- there are many security-fixes that will be required, even after installing 'SP6A'.
Also, you might have difficulty finding anti-virus software that runs under Windows NT !!!!
Apr 23, 2010 | Toshiba Satellite A135-S2276 Notebook
Which version of windows 7 goes with primavera 6
It works with Win 7 Ultimate, but it should work with all versions -you need to install SQL Server SP3 BEFORE running P6 for the first timethough...
SQLServer2005SP3-KB955706-x86-ENU.exe
Nov 17, 2009 | Primavera Project Planner P3 (PRIMAVERAP3)...
Unable to download files needed 4 installation
Go to Start>Control Panel > Add or remove programs remove all the things related yahoo ( Yahoo toolbar, Yahoo mail advisor, Yahoo installer, Yahoo browser plus etc.) Try download and install then....If still same try download offline installer http://download.yimg.com/ycs/msg/dl/msgr10/us/b4/msgr10us.exe
if still you are having difficulty download old version like Yahoo messenger 8 or Yahoo messenger 7
I think it will help you..Further result please let us know... Thanks for being with Fixya...Good Luck
Nov 10, 2009 | Yahoo Messenger
Loading Maps
MapCreate Topo does not have lake maps. There are 'some' maps on Lowrance's web site (Free Enhanced Lake Maps) but you may need to purchase lake maps on SD cards for the area you're interested in.
Jun 02, 2009 | Lowrance iFinder H2O GPS Receiver
GPS Logo
772 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
