Question about Maytag MMV4205 Microwave Oven
Micro wave is locked and I didn't lock it.
Now I can't do anything with it. Just says locked.
    Sniper:
  • 92 Answers
Unplug it... and wait 10 seconds...
or try a keypad sequence... like holding the clear button while cycliing the power...
I would start that way first...
Posted on May 06, 2010
My Daewoo Micro Wave Was Spitting Flames Last Night Due To A Hole In The Wave Plate
Hello Stephanie.
Get a new filter and try again.
Otherwise scrap the micro.
It the filter plate rusted through, or is it burnt?
The microwave's Magnetron-wave-guide is just behind this filter plate.
Looks like a small tube with a silvery cap with hole in center.
Very hazardous condition here.
The high energy from it is damped by the filter.
Is there food in the micro when arcing happens?
An empty micro will arc.
Sep 23, 2017 | Daewoo Microwave Ovens
Turn off child lock
Youcan start it but yo kidsmust not play around it but its fine
Sep 12, 2014 | Microwave Ovens
My micro wave reads that it is locked how do I unlock it. it is sears ultra wave
The "lock" function is nice if you have kids who like to push buttons. It disables the microwave oven to prevent it from running unnecessarily,
To disable the lock feature push the "STOP-CLEAR" button. Then press and hold the "START" button until 'locked' is no longer shown on the display panel.
To re-lock it, do the same thing until 'locked' appears on the display.
Have a nice day.
Oct 20, 2013 | Kenmore 63662 / 63664 / 63669 Microwave...
Try2910227 serial ywmh2205xvb-0 model arcing on the back corner were the rack sits.Is there a way to repair this seen is the unit was purchaced in June of 2011.
Yes, take the rack out and recycle it. I do not know why these micro-wave company put racks in the micro wave ovens. You get some insulation on the inside the micro flaking off next the rack.
The mega-tron tube is a very high energy transmitter. The energy will come out of the top inside the micro wave oven in a wave guide. Micro wave energy that generation by the tube is high frequency into Gega Hertz. You have a metal tray in side the micro wave acts like a big capacitor it stores energy in form of heat the next you know it look like Marconi is putting on a lighting display.
Leave the wire tie on a loft of bread and put in you micro wave oven to defrost. The next thing you might see is a load bread burning, instant toast. ----The use of micro wave were invented by the British before WWII. The mega tron tube generation very high frequency radio wave and these wave struck an object 100 miles away some of this beam energy would balance back to a receiver-----You have Radar.... I wish you and your family well being and be careful of micro wave ovens it can burn from inside out. GB you...stewbison
Aug 22, 2011 | Microwave Ovens
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
I have a microwave model HVM1540DN1WW - manufactured Jan 08 and suddenly none of the buttons work. This seems to be a common complaint as I've discovered in my research trying to find a way to fix this....
There is a child lock on this micro wave. If you do not have the manual it can be downloaded from the following site:-
www.retrevo.com/support/GE-JVM1640SJ-Microwaves-manual
Regards
Alan Hood
ami-man
UK
Apr 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Need to replace handle on micro wave can not
I HAVE A GE PROFILE SPACESAVER 2.0 OVER THE RANGE MICRO WAVE, CRACKED HANDLE, WOULD LIKE TO KNOW HOW TO REMOVE HANDLE AND INSTALL NEW ONE.
Dec 18, 2009 | Jenn-Air M439 Microwave Oven
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Mar 03, 2009 | Amana Radarange Microwave Oven
Micro wave cuts out after 20ish seconds
Try this...
Press: Function 0 2 to turn off demo mode. For future reference, Function 0 1 should turn demo mode back on.
Feb 01, 2009 | Panasonic Microwave Ovens
KitchenAid KHMS155L 1000 Watts
According to the owner's manual for model KHMS155L:
To Lock/Unlock Control: The microwave oven and Timer must
be off. Touch and hold START for 5 seconds until 2 tones sound and a lock icon appears on the display. Repeat to unlock and remove the lock icon from display.
You can download the manual here:
http://www.kitchenaid.com/custserv/service.jsp
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 16, 2008 | KitchenAid KHMS155L Microwave Oven
Maytag MMV4205  Microwave Oven Logo
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
