Question about Kenmore 24.9 cu. ft. / 705 liter Chest Freezer 13551
My upright freezer sound like its breathing
I have a small upright freezer that i recently had a new compessor installed in. since then i have noticed iyt makes a noise similer to breathing . . coul this be an indication of low freon ? with the temperature contrl ol up all the way it tends to maintain a temperature of 10 degrese F when thje compressor runs it goes down to 0F.
  • marlin_theve May 07, 2010
    yes
  • Dan Webster
    Dan Webster May 11, 2010
    Were new compressor mounts installed?
    Guru:
  • 1,524 Answers
Call back the technician who installed the compressor.
Normal operation is mid position, not all the way up.
Posted on May 07, 2010
My freezer has condensation inside
Hi - From what you have described it sounds like the freezer has a poor door seal. When cold air and warm air outside is entering it causes condensation. Try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then I suggest contacting your manufacturer and see who they recommend to repair the unit.
Oct 06, 2012 | Frigidaire Freezer 16.7 Upright Freezer,...
Upright freezer not freezing food and ice forming on back wall
is the top of the freezer full where it can breathe remove something to help it breathe
Sep 10, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
I purchased a Sears upright freezer in 2007. We keep it in our kitchen. Recently I noticed brown spots on the door of the freezer. Upon looking closer, I discovered it's rust! What can I do? The...
dear sir /madam
i think you should use anti rust spray WD-40 on your door after make clean it with sand paper . after clean make same colour there coz your freezer is working good so i think no need to buy new.
hope answer the question
thank you
please vote!
Aug 23, 2010 | Kenmore 13.7 cu. ft. Upright Freezer 26442
Frigidaire upright--"Hi temp" warning light on door. Don't know why freezer temperatures are so high (into 30s), food is thawing. Electrical seems to be fine. Have not noticed problems with door. New...
2 months old should still be under warenty.
Check the freezer fan by opening the freezer door and pressing the door switch and listing for the freezer fan sound. If no sound then the fan motor could be bad.
Look at the back wall too see if you have frost build up. If you do then you have a defrost problem.
If thees are not your problem you could have a seal system problem. (( freon leak ))
Jan 11, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
New upright kenmore freezer temp varies +/- 10 degrees
Over what period of time did this variation occur?
The freezer should have an automatic defrost cycle. The temperature will rise while it is going through this cycle.
Oct 18, 2009 | Freezers
Upright freezer door inside developing ice
The door seal is at fault. Regardless of the small tear it is not sealing well.
Take a dollar bill and close it in the door. Then pull on the bill to feel resistance.
You will find it pulls easily in some place. That is where your air leak is that is causing the condensation.
Do this about every 6 inches all the way around the seal.
Mar 27, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Not Freezing
Check the door seal all the way around. We purchased one recently that was slightly dented (not noticeably and the seal was not tight.) You need to get in touch with whomever you purchased it from immediately so that it can be repaired or replaced.
Aug 18, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Kenmore 24.9 cu. ft. / 705 liter Chest Freezer 13551 Logo
182 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
