Question about Homelite ZR10926 16 Chain Saw
What is the oil to gas ratio for a homelite zr 10926 16 chain saw
    President:
  • 2,220 Answers
This is a current Homelite product although not your saw. This clearly recommends 50:1 as do I. I find no OM for your saw, a "Ranger 33cc 16" Chain Saw UT-10926"
http://www.homelite.com/product_manual/file_url/66/UT10540_60_80_QSG.pdf
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1 and have for a number of years.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
I suggest you contact Homelite and request an OM for your saw.
Homelite/Ryobi.com (Contact Us)
https://register.homelite.com/contact_us/new
Please ask they prove a link to a site where ALL homelite product OMs may be accessed.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 06, 2010
What is the oil to gas ratio for homelite model 360?
I cannot find the full details for the model 360 chain saw but a typical Homelite chain saw uses the 50/1 gas/oil ratio.
1 gallon (US) 2,6 oz
1 litre 20 cc (20 ml)
If you want to download the user manual for your chain saw then please check the full model number . for example UTxxx and select this in the Homelite site.
Product Owner Manuals
Aug 21, 2014 | Homelite Garden
What is the homelite chain saw 360 Gas/Oil ratio ?
2.8 oz per gallon will get you very close to a 50/1 ratio. 3.6 oz per gallon will get close to 40/1
May 21, 2014 | Homelite ZR10926 16" Chain Saw
On a gas chain saw, do you mix the gas
there is usually a fuel/oil ratio (i think yours is 50:1) you must buy the 2 cycle oil and mix it with gas at the ratio reccommended by the manufacture. the bottle may say 6 oz per 1 gallon = 50:1 So 1 bottle of 2 cycle oil for every gallon of gas. mix them in a proper fuel can. then let the cutting begin.
Mar 17, 2011 | Homelite ZR10926 16 Chain Saw
Need gas/oil mix for Homelite 330 10604A, HJ
To the best of my recollection the 330 is an older model saw and should be running about a 16:1 ratio. 8oz. of oil to 1 gallon of fuel. Hope this helps.
Note: You're always better being a bit richer (lower ratio) than you are leaner (higher ratio).
Feb 20, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
What is the mix for my Homelite 16" 33cc chainsaw?
50:1 is the fuel to oil ratio. Never use petroleum oil (engine or boat motor oil). Always use a synthetic saw oil available from home centers, hardware stores and saw dealers. The bottles are usually graduated to various ratios for a gallon of fresh gas. Always premix in it's own container and shake the container thoroughly each time just before filling the tank to prevent oil starvation. Be sure to use bar/chain oil for the chain as well, and keep the chain sharp and well adjusted. Hope this helps!
Nov 14, 2010 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Correct mix of gas and oil for Chain Saw
The ratio is 40:1, provided this is a gasoline homelite chainsaw. Find the suitable amount to put into the gas can at a ratio of 3.2 oz per gallon. The bottles that you buy the oil in have marks on them telling you how much there is, and often times, are sized to dump into a preset amount of gas. Put the oil in the can, then put the gas in the can, cap, and shake. Always shake before dispensing.
May 30, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
May 26, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
I have a 3300 homelite chainsaw 16'bar,what is the oil,gas ratio?
This should run well with 40:1 ratio using modern synthetic saw oils only. Always premix the fuel and oil in a can before adding to the saw, then agitate the saw to mix the old with the new. Hope this helps!
May 03, 2010 | Homelite ZR10926 16 Chain Saw
Homelite chain saw --first time user--do you mix oil and gas--two compartments--is the first compartment for bar oil
In the compartment closest to the chainsaw bar, you need to fill this with chain and bar oil. Any good name brand will work fine.
In the other compartment you need to add a mix of petrol and oil in the ratio specified for your saw. If unsure, 25:1 petrol/oil ratio should be ok.
Jul 21, 2009 | Homelite Garden
Homelite ZR10926 16 Chain Saw Logo
815 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
