Question about ASUS P5V800-MX Motherboard
Conflicts of RAM and motherboard
Good day!
I have bought memory sticks for my computer. They are Transcend DDR 1 PC3200 1GB. My motherboard is ASUS P4R800-V Deluxe (rather old). As Manual says these sticks were not tested with this motherboard. I think, at that time ASUS did't know about these sticks. Every second day I have BSOD with an error pointing to the conflict with memory. My previous attempt to increase memory - Kingston sticks - worked even worse - BSOD every 2 hours. I have no problems in my first configuration: Samsung's sticks 256mb, but they are too small now.
I want to set manually all items in BIOS, concerning memory parameters. Now they are AUTO. Couldn't you provide me this information?
My Transcend sticks are:
TD 123PET4
TO907
№ 2491780413, 2491781343
Is it enough?
Sencerely, Nikolay
St-Petersburg, Russia
    Scholar:
  • 91 Answers
Well unfortunetly it seems as though your RAM may be bad or not compatible. My suggestion is to go to crucial.com and use their easy memory finder to see what is best for your system. Then look for it else where like newegg.com or tiger direct, etc. There isn't a whole lot that you can do to fix RAM like that to make it work with a system predefined by the maker.
Posted on May 06, 2010
Have asus p4s8x mob,when adding 3rd stick of memory (1gb) total of 3gb.computer hangs on startup 1long 3 short beeps. if i remove one old stick and leave new with old (2gigs total)it works fine,also works...
The Asus Asus Motherboards P4S8X-MX uses PC-3200 type memory and usually ships from Asus with 0MB of RAM. The Asus Motherboards P4S8X-MX supports up to 2GB of RAM. Maximizing your system memory will allow your Asus Motherboards to operate as fast as possible and offer the most productive environment.
RAM modules must be installed in special locations on the motherboard called Sockets. These memory sockets are what hold the RAM module in place and can range from 1 to 16 or more. Banks consist of a group of 1 or more sockets. A system can have 1 or more of these banks of sockets. If a system has more than 1 socket in a bank, a Kit must be purchased for that bank. A kit is simply more than one, usually 2 or 4, like RAM modules. All sockets in a bank must be filled, and for such systems we sell memory in a kit. Typically you will see 2x512MB or 2x256MB signifying you are purchasing 2 units of 512MB RAM modules or 2 units of 256MB RAM modules, respectively.
The Asus Asus Motherboards P4S8X-MX has 1 bank(s) which have 2 socket(s) in each bank for a total of 2 memory socket(s). This means the Asus Motherboards P4S8X-MX can support up to 2 individual RAM modules.
We recommend you purchase the largest capacity RAM module each time you purchase memory. The reason for this is if you decide to upgrade again later and all your memory sockets are filled, you will not need to discard the already installed lower capacity memory.
Below is a visual representation of the memory bank(s) and socket(s) configuration for the Asus Asus Motherboards P4S8X-MX.
Standard Memory Bank & Socket Configurationsocket_2.gif hope this helps John
Jul 01, 2011 | ASUS P4S8X Motherboard
I have this ASUS P4GE-MX Motherboard. I want to upgrade my ram from DDR 256 MB TO DDR 1 GB. For temporary purpose, I tried another 256 DDR ram with 400 MHZ, but I had some problem with booting my system....
Hello, The Motherboard's specifications mention that it uses DDR Ram, while the FSB runs at 400MHz. That means that any kind of DDR memory will work up to the maximum of 2 GB (it has 2 slots, so it's up to the max of 2x1GB DDR sticks).
There's no issue with the speed, actually the faster you can get the better results you will have. Try looking for 1GB DDR 400MHz (preferably two of them, if you want to max out the capacity and since it's kind of cheap to do so).
The one you tried and didn't work, might be due to a faulty RAM module.
Mar 13, 2011 | ASUS P4GE-MX Motherboard
I have 2 sticks of 512 MB DDR 400 pc3200 in the motherboard but when i use crucials scanner to find out what memory is compatable with my computer it shows 2 sticks of 256. This board is supposed to be...
hi
your motherboard supports following RAM only
Note: PC2100/PC1600 up to 3 DIMMs; PC3200/PC2700 up to 2 DIMMs; 1GB PC3200/2700 with 32 DDR chips up to 1 DIMM only)
Aug 04, 2010 | ASUS P5S800-VM Motherboard
Not recognizing memory.
The Asus P4S800-X MB can use Dual channel DDR memory and single channel memory. The dual channel memory which comes in matching packs. (Normally 2 DIMMS per pack) is the faster memory.
In other words if you are installing, 4- 512MB DIMMS of PC3200 all memory should be matched,
or you're MB may not see all connected DIMM'S.
See page vii in you're manual. If you're running windows XP, Home or Pro edition the bios will show up to 4GB of memory installed but windows XP 32bit will only show 3GB of memory. As mentioned above all 4 of you're 512MB of memory should be dual channel and run at the same speed. You can run both single channel and dual channel but you must follow Table 1 in you're manual. (1-9).
Example; PC3200 400MHz.
Or 4-512MB PC2700 333MHz. See page 1-9 for memory configurations and the QVL list supported.
Check out Asus FAQ's; http://support.asus.com/faq/faq.aspx?SLanguage=en-us&model=P4S800D-X&product=6&os=17
This should help you configure the memory.
Mike
May 09, 2010 | ASUS P4S800D-X Motherboard
Problems with memory sticks and motherboard
see my website theit is solution www.techyardsolution.com
Apr 13, 2010 | ASUS P5V800-MX Motherboard
Mother board ASUS A7s333 with 3 slots for RAM.
change your ram's one of them is mismatched
change from where u have bought it....
it will work
helpful i'll always here.....
Oct 23, 2009 | ASUS A7S333 Motherboard
Ram supported by asus motherbord p5p800-vm<green>
Memory should be same as the one that is in the motherboard . Each motherboard support only one type of memory. Search on the internet for the type of motherboard for memory supported with it. If it says other than DDR2/ DDR3 then the motherboard wouldn't support the memory. Do some searching like motherboaed p5p800 and see few websites for specification for the motherboard, check the memory specifically for the details.
Sep 18, 2009 | ASUS P5P800-VM Motherboard
1gb DDR 400 not recognized
That board needs to have minimally memory in pairs .. get another 1Gb stick
Dec 06, 2008 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Memory upgrade problem
first u have to notice bus speed of old ram .it also 333[pc 3200]or not.
Feb 17, 2008 | ASUS K8V-X Motherboard
ASUS P5V800-MX Motherboard Logo
70 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
