Question about Kitchen Ranges
Counter top opening for 30 inch slide in range
I know i need a 30 inch stove opening for cabinets but should the countertop be longer for glass of stove to overlap ?
SOURCE:
  • 22 Answers
SOURCE: installing the Bosch HDI7152 slide in with a bull nose counter
I need to see a picture of the condition you are talking about before I make a suggestion.
Posted on Dec 04, 2007
jsrock516
  • 5911 Answers
SOURCE: glass top range cookware
Here's the recommended cookware for glass top ranges:
Aluminum and Copper - have good heating characteristics, but may leave metal transfer marks on the glass.
Stainless - may take longer to heat and may not heat as evenly (some stainless has a copper liner to aid in heat transfer). More resistant to leaving metal transfer marks.
Baked Enamel - great heating characteristics, provides uniform heating and resists marks on glass surface.
Cast Iron - NOT recommended due to the weight of the metal. Can cause potential cracks or breakage.
Now, any reference to metal transfer marks are merely disclaimers from most manufacturers that the potential exists that the cookware could leave marks on the stove surface. Using a good cook-top cleaning product after the surface cools will aid in removing any of these marks. This does not mean this cookware should not be used.
All cookware used on glass cook-tops should have flat bottoms. There should be no ridges, grooves, or warping. This creates an uneven heat transfer between the pan and surface and can potentially cause the glass to break. Most manufacturers will not honor a warranty where it can be determined that the consumer used the wrong cookware.
Make sure you wipe up any spills on the stove surface that contains sugars or milk. These ingredients (if allowed to burn on the surface and are not cleaned up) will eventually cause damage to the glass surface by either removing the finish or leaving pits and cracks. Wipe up all spills AFTER the surface has been allowed to cool using a non-abrasive cleaning rag or sponge. The green scrubbing pads are considered non-abrasive and CAN be used. DO NOT use steel wool or SOS pads! A small straight blade razor can be used to remove stubborn items by gently scraping in one direction. I don't believe you can use any cleaning product that contains ammonia either.
All of this information can be found in the owners manual that came with the appliance. If you don't have a user/owner's manual, post back with your model number and I'll see if I can locate it for you. I hope this helps you.
Posted on Apr 17, 2008
docjohn174
  • 943 Answers
SOURCE: installation of kitchenaid range - KGSS907SSS
hi every stove that i have worked on and believe me that's a few and all gas or electric were all right up against the counter tops with no space at all so i would install the cabinets thanks please a positive feed back and accept please the appliance doc
Posted on Sep 23, 2008
aborcass
  • 2651 Answers
SOURCE: premier 30 inch gas stove oven does not light
do you hear any clicking when you try to start the oven portion of the range? if not lets try this, open the lower drawer so you can see the burner bar and mechanism for lighting the bake bar. as your watching the mechanism turn on the oven (nothing should happen as per your issue) while oven is on try lighting one of the top burners, any one will do wanna check if that lites the spark and in turn lites the oven pilot.if that does infact work you have a bad spark switch for the oven control
Posted on Oct 29, 2008
SOURCE: Electrolux Slide In Electric Range doesn't fit to the wall?
We have the same Electolux range.....it is supposed to fit about 2 inched from back wall......your granite installer will have to fit a piece of granite behind the range. Yes, it is proper to have the plug installed. The plug is not part of the range package and will have to be purchased seperately if your installer does not use the plug from your old unit.
We are on our second slide in with wave touch controls.......we hope you have better luck that we've had. Ceramic cooktops do not seem to be level on all units. The bottom oven has locked up on both ovens and cause burned foods.....Electrolux has problems that aren't acknowledging as yet..........good luck
Posted on Nov 30, 2008
Is there a standard size for a kitchen countertop?
A linear foot is 12 inches wide and 25 inches deep because the standard depth of kitchen countertops is 25 inches.
The Americans with Disabilities Act Accessible Guidelines state that space at least 30 inches wide should be accessible, meaning that wheelchair users can roll up to the counter to perform tasks. The counter should be between 28 and 34 inches high and accommodate a minimum 27-inch knee clearance below the counter, sink or cabinet space. Anything beyond the first 16 inches of counter depth, from the front edge, is considered dead space for wheelchair users.
Apr 09, 2018 | Kitchen Ranges
I have a new viking stove slide in electric top range that was installed in our kitchen with existing granite counter tops. But there seems to be a small gap between the stove and the counter. My previous...
If you are talking about a gap caused by the height of the stove, You can lower the height of the stove by adjusting the threaded leg posts on the bottom of the stove. A more difficult fix would be in raise the height of the countertop and cabinets by shimming the bottom of the cabinets.
If your gap is not a height issue, then you can experiment with some type of trim around the stove itself. Local granite dealers has an assortment of trims for issues like this.
I was able to find a number of trims for a back gap on my granite countertops and backsplash from my local European Marble and Granite.
Mar 15, 2013 | Cooktops
We purchased a slide in range, Frigidaire fggs3045kf. We want to put a granite countertop and use tile on the floor. When we raise the heighth of the range to make room for the tile, the ridge of the...
Hello Mkoffice, this a very common problem when floors are installed in front of cabinets and not underthe cabinets. it also causes a problem for the dishwasher. it will become trapped or cant be installed.If you dont want to removed cabinets to install the tile. you will need to raise the cabinet height. my shop has run into this before. We add 1 inch tall strips of wood across the entire front edge of the cabinets. the same is done to the back wall and any area where two cabinets sides meet. we dont use full sheet of ply wood because the granite installers will need access into the top of the cabinets to level the counters. The wood type should match the cabinet.( at least in the front) it will have to be stained or painted.
Hope this helps
Joe Connolly
Aug 16, 2011 | Frigidaire FGGS3045KF Stainless Steel Gas...
Rough openning for a 30"
You want to make that very close to 30" maybe 1/8 to 1/4" more max. If you make the opening too big you will be loosing stuff down the cracks....
When I did kitchens, my preferance was to let one or both of the countertops loose til the range was in place and then push the countertop snug and then screw it down...
heatman101
Apr 22, 2011 | Kitchen Ranges
GE Profile slide in is 28" counters are 30" what
so the whole is 28" and the range is 30" this sounds like a carpentry task or exchanging for a differnt stove really nothing you can do to the stove I being a carpenter as well as an appliance repairman have cut the counters shorter in order to fit a stove if your not used to doing finish carpentry hire a carpenter it will be well worth the money and shouldn't cost that much to shave off two inches. please message me back if you have any furhter questions and please remember to rank this opinion Thanks again
Rick
Dec 01, 2010 | GE Profile 30" Slide-In Gas Range -...
Purchased 30 inch induction cooktop stove to
its ok to cut the laminate using the wood saw to fix the new one.be careful to cut the laminate.
Sep 09, 2009 | Cooktops
GE profile top
Yes, the glass cook top can be replaced. These counter top inserts are actually fairly simple to repair, but the entire assembly usually has to be uninstalled to accomodate removing the glass top and installing a new one. You will need to provide a model number by opening the cabinet underneath the cook top and looking for a nameplate in order for me to assist you further in determing a part number, cost and how to disassemble.
Aug 19, 2009 | Frigidaire FEF366 Electric Kitchen Range
Is there suppose to be a gap of 1/8" - 1/4" between the lip of the range and a granite countertop?
Ranges have a built in safety factor when the cooktops were designed so that the perimeter of the stove stays warm at best when using. The granite is very thermally stable and will not have an issue here. But the oven area needs a little air space from your cabinet/wood surface.
Jul 26, 2009 | Electrolux 30" Self-Cleaning Slide-In...
Installing a under the counter dishwasher
The dishwasher doesn't have to be between cabinets, but it does have to be enclosed on both sides, and it can't support the countertop. You can put an end panel there, which is just a finished panel with trim on the front to match the cabinets. Make sure it is straight and securely attachedd to both the floor and the countertop. Also make sure that you can route the water and drain lines out the other side.
Sep 28, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Installation of kitchenaid range - KGSS907SSS
Sep 23, 2008 | KitchenAid Kitchen Ranges
Kitchen Ranges Logo
711 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
