Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
Looking for the normal cranking comppression I
Looking for the normal cranking comppression I get 85 psi ,on 1 cylinder and 95 psi on the other
  • 3,740 Answers
First off the readings your stating are a bit low for BOTH cyclinders but the engine has an automatic compresson release so the readings may be low.
Usually we do a leak down test. The service manual calls for using a tester but I have a spark plug fitting made from a drilled out and tapped spark plug that had the ceramic and electrode removed that was replaced by a fitting and air chuck.
The reason you do a leak down test is:
Compression Test
Some of these engines are equipped with an automatic compression release (ACR) mechanism. Because of the ACR mechanism, it is difficult to obtain an accurate compression reading. As an alternative, perform a cylinder leakdown test.
You charge the cylinder head with 50 PSI and listen for leaks from the engine. (you can increase the pressure if necessary.) There is a tester with a gage for this but I have never used it nor do I own one.. so the red, yellow, and green steps below willnot apply.
Leakdown Test Results
Air escaping from crankcase breather ........................................................ Defective rings or worn cylinder.
Air escaping from exhaust system .............................................................. Defective exhaust valve/improper seating.
Air escaping from carburetor ....................................................................... Defective intake valve/improper seating.
(Below N/A without tester)
Gauge reading in “low” (green) zone .......................................................... Piston rings and cylinder in good
condition.
Gauge reading in “moderate” (yellow) zone .............................................. Engine is still usable, but there is some wear present. Customer should start planning for overhaul or replacement.
Gauge reading in “high” (red) zone ............................................................. Rings and/or cylinder have considerable
wear. Engine should be reconditioned or
replaced.
Thanks for using FixYa.
Kelly
Posted on May 21, 2010
  • Kelly
    Kelly May 23, 2010
    Just a final note... If you do charge the cylinders with air, they must be at Top Dead Center (TDC) before charging or the piston(s) will stroke from the pressure.
    Kelly
1998 mercury grand marquis cylinder head to engine block torque specs
Tighten in 6 steps. These are torque to yield bolts and new bolts should be used.
1 Tighten all bolts to 28-31 ft lbs
2 Turn all bolts 85-95 degrees
3 Loosen all bolts 360 degrees
4 Tighten all bolts 28-31 ft lbs
5 Tighten all bolts 85-95 degrees
6 Tighten all bolts an additional 85-95 degrees
Nov 29, 2015 | Mercury Cars & Trucks
What is normal oil pressure for 1998 mercruiser 7.4 boat motor?
Hi Lauren:
Depending on the number of hours on the engine, and the maintenance schedule followed, it can vary quite a bit.
Here's what I would consider to be acceptable.
Cold start, fast idle - 80 - 95 PSI
Engine warmed up - running speed - 70 - 85 PSI
Engine warmed up - Idle - 40 - 50 PSI
Anything higher than 95 could be blowin seals
Anything lower than 35 could be indication of excessive engine wear.
Bottom line -
If it's not burning oil, and
its not leaking oil, and
You're not getting valve clatter or other engine sounds like piston slap or knocking, and the running pressures are close to what I mentioned, enjoy the boat and go chase fish.
Sep 20, 2015 | Boating
Popping on acceleration
It could be a problem in the valve train. For a car that old, before putting new parts in, you could buy a compression tester for about $30, and do your own compression test. It should tell you if the engine is good enough internally to warrant proceeding. If compression is low on any cylinders, that problem must be addressed first. If a valve is not sealing and causing the popping, that cylinder will show low compression.
For the test, the engine should be at normal operating temperature. Then pull all the plugs out, connect tester to #1 spark plug hole. Have a helper hold the throttle wide open while cranking the engine over about 5 seconds. Watch the gauge-the first revolution or two will cause the gauge to jump high at first, and successive revolutions during the 5 second span will cause the needle on gauge to climb a little each time. Record or note the compression on #1, then do each cylinder. Try to do the same amount of cranking on each cylinder, and keep the throttle wide open. What you want are compression readings on each cylinder that is well above 100 psi, and all should be close. The lowest reading should be within 75-85% of the highest reading cylinder. Example: say your highest reading is 135 psi. 85% of 135 is 115-so your lowest reading should be at least 115 psi. Some general guidelines: any cylinder with compression below 100 psi is definitely a problem-that cylinder will not have hardly any power output, even if it is firing. Worn piston rings or poor valve sealing is causing compression loss. A newer engine should have compression readings above 150 psi. As the engine wears, compression will drop. In general, for high mileage engines, you would want to see compression in the range of 125-150 psi, the higher the better, but remember, it should be balanced-the lowest should be at least 75% of the highest reading cylinder.
Post back if you have questions-good luck.
Jan 26, 2014 | 1983 Oldsmobile Firenza
Cranks won't start
First you must check to see if engine is mechanical sound by performing a compression test. remove the spark plugs install a compression gauge in the spark plug hole and crank engine about 4 cycles compare readings to all cylinders reading should be around 125-150 psi readings in the 50 psi range possible jumped or broken timing belt. If engine is mechanically sound test for spark at the spark plugs use a spark plug laid against valve cover and have some one crank it over look for the spark to jump the gap. A no spark problem is internal in the distributor.
Nov 07, 2013 | 1995 Honda Accord
What is the psi compression on a 1998 kia sportage supose to be?
contact the parts store for specs they should have it on the computer system under overhaul specs..ask for a printout of rebuild proceedures..
Jan 19, 2013 | 1998 Kia Sportage
Looking for head torque settings for millenia 2001 2.5 L engine
cylinder head bolts
step 1 17-19 ft lbs.
step 2 additinoal 85-95 degrees
step 3 additinoal 85-90 degrees
Nov 29, 2010 | 2001 Mazda Millenia
1997 ford f150 4.6 4 wheel drive torque spec for heads
from autozone.com:
  1. Tighten the cylinder head bolts in the sequence shown in three steps, as follows:
    1. Step 1-27-31 ft. lbs. (37-43 Nm).
    2. Step 2-tighten an additional 85-95 degrees.
    3. Step 3-tighten another 85-95 degrees.
Fig. Fig. 9 Tighten the cylinder head bolts in three steps using the sequence shown-4.6L and 5.4L engines
Sep 21, 2010 | 1997 Ford F150 Regular Cab
Engine head torque settings
2.0L 4 cylinder
cylinder head bolt torque
step 1 13-16 ft lbs.
step 2 additional 85 degrees
step 3 additinoal 85 degrees
2.5L V6
head bolt torque
step 3 additinoal 85-95 degrees
Mar 23, 2010 | 1998 Mazda 626
What is the torque specs on a ford expidition 2001 4.6 cylinder heads and what is the order?
Cylinder Head Bolt
Step 1 28-31 (37-43 nm)
Step 2 Additional 85-95 Degrees
Step 3 Loosen 360 Degrees
Step 4 28-31 (37-43 nm)
Step 5 Additional 85-95 Degrees
Step 6 Additional 85-95 Degrees
Sequence:
http://www.anubiscycle.com/fixya/2001expedition46sequence.png
Jan 16, 2010 | 2001 Ford Expedition
Cylinder head torque value
Cylinder Head Bolt
Crown Victoria & Grand Marquis
Specs are given in ftlbs
Step 1 28-31
Step 4 28-31
Source: Mitchell1 OD
Jan 14, 2010 | 2000 Ford Crown Victoria
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
441 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
