What is the model number of the router ?
You need to reset the router with the reset button at the backside of the router.
After resetting the router, still if the page is not coming, You need to upgrade the firmware of the router.
To ckeck the latest update click here.
For instructions for upgrading the firmware, click here.
Firmware can be upgraded by an external application called TFTP. To download TFTP click here.
- Access the router's web-based setup page.
- Open a web browser such as Internet Explorer.
- Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
- A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
- NOTE: If the password of the router has been changed, type the router's new password in the Password field instead.
Step2: When the router's web-based setup page appears, look for MTU and set it to Manual. Enter the MTU value of your Internet connection in the Size field.
1468. The size DHCP or cable providers prefer.
1400. Maximum size for DSL.
Step3: Save settings.
If you run into Intermittent Wireless Connections Using a Router:
Check if your wireless computers have stable connection when connected to other wireless networks. Regular wireless disconnection can be caused by different factors such as: > Wireless interference within the network. > Wireless settings of the Linksys router are still set to default. > Firmware is corrupted.
NOTE: If the procedure does not work, needs to update the router
