Question about Acer Aspire One PC Notebook
When first starting up-have a double screen and when Windows boots resolution is 800x600. Native resolution of 1024x600 not listed
    Guru:
  • Acer Master
  • 468 Answers
It appears that the display adapter is not installed properly. Please follow the steps below:
Start Menu> All Programs> Acer erecovery management> Restore> Reinstall Application & Drivers> Select the appropriate display driver (Intel or ATI) and install it
Posted on May 09, 2010
Screen Resolutions My resolutions changed to very small, when I clicked on the monitor.
Your operating system?
For Windows XP,
  • Right click in an open area on the desktop.
  • On the window that opens select properties.This opens the Display Properties window.
  • Click on settings.
  • On the screen resolution option,set to around 800x600 pixels.
  • Click O.K to save.
For Windows 7,
  • Click on the start button.
  • Click on the control panel and under Appearance and Personalization,select Adjust screen resolution.
  • On the list next to Resolution,move the slider to the resolution you want.e.g 800x600 pixels.
  • Click on keep to save the changes.
For Windows Vista,
  • Click on start button.
  • Click on the control panel and then on Appearance and Personalization.
  • Click on Personalization and then on Display settings.
  • Under Resolution,select the resolution you want.
  • Click Apply to save the changes.
Hope this helps.Thanks!
Please rate this answer.
Oct 28, 2011 | Computers & Internet
WHAT IS THE NATIVE SCREEN RESOLUTION FOR MY ACER ASPIRE X3200 ?
This depends on the monitor you have. A default resolution for a computer with no video drivers is 800x600
May 03, 2011 | Acer Aspire X3200 PC Desktop
FPD1960 TFT LCD Monitor that turns on and you see the Windows Screen, and then goes black. Each time I turn it off and then back on, it repeats this pattern. All cables are securely fastened, I am using...
Windows is using a video mode the LCD monitor can't display. The cable doesn't matter in this case. It's an issue of the refresh rate and the resolution set in the system.
When the system boots, hit F8 just before the Windows splash screen would come up. Start the computer in safe mode with networking support. It should be able to come up in safe mode because the resolution will go to 640x480 or 800x600 by default.
Once you get to the desktop, go under the desktop properties. Hit Advanced. then go under the monitor tab. Make sure the monitor is defined. If it says generic display it will give you resolutions and refresh rates you can't use. If it isn't defined, you can install the driver under properties.
Finally, set the default resolution to something easy like 800x600 and try the refresh around 60-65hrz.
Jun 16, 2010 | Gateway FPD1960 19" Flat Panel LCD Monitor
"Input Not Supported" after adjusting screen resolution
What resolution are you trying to run? The native resolution for your monitor is 1440 x 900, setting to that should fix your issue
Jul 13, 2009 | Acer AL1916W 19" LCD Monitor
Screen resolution on powerpoint cannot be locked at high res. Changes when connected to my projector. Monitor screen res. also changes everytime the projector is plugged in, In power point display (2nd...
I just checked the specs on your Benq PB 6110, which has a native resolution of 800X600 and will simulate 1280X1024. When you connect it to your computer, the computer goes to 800X600, right? That is the resolution of the BenQ. How high a resolution do you want? THe highest I have seen in projectors is 1024X760, which is not that much higher. Projectors seem to lag behind monitors and Plasma/LCD/LED TVs for resolution. They must have a very small market share therefore low developement.
May 07, 2009 | Microsoft Office PowerPoint Home and...
Promblem resolution 1024x600 on Lenovo S10
1024x600 is not a standard screen resolution.
You can set it to 800x600 or 1024x768
Mar 28, 2009 | ASUS Eee PC 900 Notebook
Display resolution goes from 1024x600 to 800x600 at start up.
try reinstalling the drivers for the onboard graphics and for the monitor. Might be the monitor is not supporting the default resolution.
Jan 18, 2009 | ASUS Eee PC 900 Notebook
I see two screens on my desktop.
You are using a screen resolution that is not supported by your monitor. Start the computer in safe mode and open display properties. What ever resolution and color depth is (usually 640x480 and 16 colors), click OK button. Restart the computer. Go to display properties and increase the color depth to the maximum value. Set the resolution to 800x600. Restart the machine. Do you see double screens? No? Great! Now try increasing the resolution to the next level. (1024x768). When you click 'apply' you will be give 15 seconds to say it is OK. So if you see double screens, do not click anything. Display will revert to 800x600 resolution (and you will see only a single screen!)
Sep 21, 2008 | ASTVision 5B 15 in.CRT Conventional...
Preset
Without knowing any more about your system I can only give you a couple of general ideas.
First try updating to the newest video card drivers possible.
You can try going to the drivers tab in display adapters in device manager and click update drivers.
Failing this, if your system is more than a few years old you will probably have to update to a more current video card to get the resolution that you need.
The native resolution for your screen is 1280x1024.
Jan 03, 2008 | Envision EN9410 19" Flat Panel LCD Monitor
Acer Aspire One  PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
