Question about Brother MFC-665CW All-In-One InkJet Printer
Im getting unable to print 50 error on my brother mfc 665cw
Im getting unable to print 50 error on my .brother mfc665cw
  • 5 more comments
  • exitbills62 May 06, 2010
    I tried putting different different paper in there. Didnt check the encoder strip. Where would that be? I cant even turn it on or off with the on/off button. When I replaced a low ink cartridge it didnt go into the cleaning it usually does.
  • exitbills62 May 07, 2010
    I have a brother mfc brother 665cw. Im getting a cant print 50 error. I cant turn machine off or on. When I replaced ink cartridge it didnt clean itself like it usually does.
  • exitbills62 May 08, 2010
    I have a brother mfc 665 cw printer that has an unable to print 50 error. Everyone is telling me its a paper jam but I dont see any hint of a paper jam. Ive opened the 2 covers and dont see anything out of place. Someone had mentioned the encoder strip as the problem. Im not sure even where that would be.
  • exitbills62 May 12, 2010
    im getting a printer error 50 on my brother mfc 665cw. ive gotten alot of suggestions that havent worked. I have cleaned the encoder strip numerous times but havent cleaned the strip underneath the glass. When i put a new ink cartridge in it didnt self clean so im at my wits end. not sure what else to try.
  • exitbills62 May 14, 2010
    i have a print error 50 on my brother mfc 665 cw. i have cleaned the encoder strip and gone into the maintenance mode and purged what was suggested. Im not sure what else I can do.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 58 Answers
For Printer Tech Support Contact us 1-800-935-0537
http://global-printer-support.net/
Posted on Jun 27, 2014
    President:
  • 803 Answers
Try uninstalling and reinstalling the drivers for it that could help also try rebooting the machine and printer
Posted on May 14, 2010
  • 10,865 Answers
Hello. Read the following link to learn how to fix this problem
http://www.justanswer.com/questions/33xdi-brother-mfc-665cw-unable-to-print-51-i-dont-see-anything
Posted on May 08, 2010
    Genius:
  • 1,354 Answers
Just see the folowing details
50,51,52,57,5A,5B,5C
5D,5E The machine does not work due to a paper jam. Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feeding.
Posted on May 07, 2010
  • 2,973 Answers
Please un and re install the device on your PC. Follow the link below to do so.
Installing Devices on PCs and Laptops
  • 10,515 Answers
This Error can show up for following reasons :
1. There is some piece of paper / paper clip / sticker stuck inside printer and you are not able to access it. In this case you need to remove all ink cartridges, turn off printer, then turn it upside down and shake it few times. If still not working then you need to open it up as much you can to see if something is stuck
2. The electric sensor which receives signal from the mechanical paper sensor to detect jam has issues. Either there is dust on it or its gone bad and needs replacement. You should first open up the printer and blow air in it (using compressed air can) to remove all dust. If it doesn't work then this repair will cost you much more than buying a new Printer. If its in warranty certainly call Brother.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. There might be a paper jam before this error code. The paper might have dislocated the encoder strip. Please turn off the printer and push it back into its slot to resolve the issue. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 06, 2010
  • Rylee Smith
    Rylee Smith May 06, 2010
    Lift printer cover and remove the two plastic
    panels. Mark the position of cables and remove them. Now remove the top scanner
    section and remove screws from top plastic shell. Bent aside the two plastic
    tabs in the front to remove the top shell and gently put the encoder strip back
    in the guide. If still the issue is not resolved, then see the link---
    How
    to clear Unable to print error
    Thanks
    Rylee
    President:
  • 4,070 Answers
Hi! You may try this.
- turn the machine off
- turn on the machine while holding the menu button til the lights flash on and off, that will mean that youre in the maintenance mode
- press 80
- press mono start button till you see the PURGE xxxx
- press 2783 to reset the purge counter and you'll see PURGE OOOO
- press the stop button
- press 99 to exit the maintenance mode
It'll be reseted. Hope this helps and have a good one!
Posted on May 12, 2010
    someone else had suggested this... i did it and im getting the same error. there was a machine err_1:50 and i did the 2783 and now it says mach err_1:00 and then when I exit it say machine error 50. any other suggestions?
I haved an error message on my Brother MFC-665CW--unable to print 51
in my printer brother mfc-7340 when i coping with machine after some time display will show print unable with error code 72 what i will do? plse tell me;
Apr 07, 2013 | Brother Multi-Function Center MFC-665CW...
The paper jam you had probably lifted the long, thin, plastic encoder strip out of its slot. It is making the printer think paper is still jammed. Try gently pushing the strip back into the slot. You might have to use a screwdriver or other thin instrument to get to the strip.
Be sure printer is off when you do this.
Sep 18, 2011 | Brother MFC-665CW All-In-One InkJet...
I have a Nokia E63 phone with print features. My printer receives the data but doesn't print. All other printing is as normal. Printing is through Wlan to MFC665CW.
This is not a solution,
I have a MFC 375CW , i have exactly he same problem with my Nokia E63. Hope there is some one to help us.
awaitng reply
thanks
Jan 28, 2010 | Brother Multi-Function Center MFC-665CW...
Unable to print 30 or 50
the encoder strip is probably out of its socket. its a long mylar strip that goes from one side to the other, and goes underneath the printhead.
Jun 25, 2009 | Brother Multi-Function Center MFC-665CW...
MFC-665CW "unable to print" 50 error
Did you have a paper jam before this happened? If yes then the paper must have pushed the encoder strip out of alignment. You will need to turn off the printer and then push it back into slot to fix it. Let me know if you need more help. Sai.
Jun 11, 2009 | Brother MultiFunction Center MFC-440CN...
I have a brother mfc 665cw printer, had a printer jam, cleared the jam and now recieve unable to print 50 error, unable to copy or print. Have found some information about the encoder strip but I have no...
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 05, 2009 | Brother Multi-Function Center MFC-665CW...
Cleared printer jam, message Unable to print 30
...and 50? Is it toggling between those two error codes?
Anyway, see here what to do:
http://www.fixya.com/support/t211210-brother_mfc845cw
Mar 11, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC-665CW All-In-One InkJet Printer Logo
3,422 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
