Question about Gaggia Classic Espresso Machine
Gaggia Classic Cannot insert coffee
Gaggia Classic Cannot insert coffee holder/basket. Have cleaned thoroughly it looks like a metal washer may have dropped or expanded out of place. Can you advise
  • anneparker22 May 06, 2010
    How do I replace or reseat head gasket
    President:
  • 1,618 Answers
You will have to reseat or replace the head gasket.
Posted on May 06, 2010
Testimonial: "thank you will look into it"
  • Ernest R
    Ernest R May 07, 2010
    Using an ice pick or scratch awl, remove the old gasket and clean the coffee grounds from the head using a group brush, after cleaning insert new gasket, and use your thumbs to push it in place, then remove basket from filterholder, and insert filterholder in head to seat gasket.
I cant get my Gaggia Classic to work with pods
You need to use the single-serving size one-hole basket, not the double, with the diffuser valve seated beneath the basket. Then the Illy ese pod should be inserted with the decal facing up. Finally, and most importantly, when you lock the filter assembly into the machine, you need to close it firmly. Brown water can mean that the basket assembly is not sealed in tight enough.
Sep 07, 2014 | Gaggia Classic Espresso Machine
I have a Gaggia classic and want to use pods. I've got Illy ese pods and the right (one hole pressurised basket) but still get just brown water. Can anyone help please?
I HAVE BEEN USING THE GAGGIA CLASSIC FOR 34 YEARS AND I ALWAYS BELIEVED THIS MACHINE IS BEING DESIGNED FOR SPECIFIC COFFEE QUALITY. THE ILLY ESE PODS ARE NOT FOR THIS MACHINE, TRY LAVAZZA PODS INSTEAD THAT IS SHAPED PERFECTLY WITH GAGGIA FILTER HOLDER FOR PODS.
My Gaggia classic has suddenly stopped frothing
Hi There,
You are not getting enough steam, to produce the froth and there no blockage. I suggest you replace the thermostats. Takes 10 min max.. Gaggia thermostat set
Sep 28, 2017 | Gaggia Classic Espresso Machine
My new Classic made perfect coffee for the first three weeks but now it sprays hot coffee in all directions from the delivery spout
Do you mean the spout OR do you mean the filter holder.If it sprays out too quickly from the outlet,it could be because the coffee is too dry, too coarsely ground or not compressed firmly enough in the filter. If it is spraying from around the filter holder it is probably old coffee grounds stuck on the rubber seal in the filter holder head (the part of the machine that the filter holder attaches to ) You can buy a special right angled brush for cleaning the rubber seal in place OR you can fold a washup sponge and use the corner to clean around the seal.
Jan 23, 2011 | Gaggia Classic Espresso Machine
Can you repair a seized solenoid ?
Yes, but you must clean it thoroughly. You can open the solenoid body and let it sit in acid for a while to clear the scale build and or rust buildup on the plunger and the silver holder. If you are going to do this you must also replace the small O-rings on the solenoid square brass piece.
Jan 11, 2011 | Gaggia Classic Espresso Machine
Coffee sprays from portafilter spouts while pulling shot
Either the group gasket is dirty or damaged. Also check the basket for damage.
Jul 21, 2010 | Gaggia Classic Espresso Machine
Gaggia Deluxe - Excessive steam discharging into filter holder
your seal of non teturn valve of group, just above metal part where you put upper filter. open the valve and carefuly clean, check the seal and spring.
Mar 09, 2009 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Gaggia Classic
Hi Riccardo,
Maybe the rubber ring that is underneeth the boiler has become hard and inflexible. You can order a new rubber ring thru your local dealer.
Marco
The Netherlands
May 21, 2008 | Gaggia Classic Espresso Machine
Gaggia Classic Espresso Machine Logo
227 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
