Vizio sv420xvt when turned on no blue screen,millions of red and yellow dots.Need to know what board to change and hope it is not the lcd panel
  • 19,396 Answers
Hi.
You cannot know what board is involved without testing the TV. Testing requires skills and training.
The faulty board is likely the digital controller board(Vizio 3642-0492-0150), which is the main board inside the TV.
Before replacing the main board, the Power Supply and the must be tested.
On this 42'' there is also a Daughter Bd Assy, and T-Con Board that must also be tested.
Testing is done at component level, mainly reading volts in strategic points and checking components for continuity.
Here a general procedure explaining how to test the power board. Disregard the part on inverter as this is unlikely responsible for the symptoms you have described:How to test an LCD TV or monitor PSU
Regarding inputs, this can also be responsible, and may be tested by simply using the TV on different connections. Here the boards :HDMI Input, and AV INPUT .
Before doing anything else call Vizio at the number listed on the owners manual, to verify warranty status and to check the factory quote on repair.
Regards.
Ginko.
Posted on May 06, 2010
Today my 55" vizio screen popped and then turned red. I unpluged and restarted everything and now the audio is on, the chanels change, but the screen is completely read. some images are readable.
If this is a VO47LFHDTV20A TV set, the problem is most likely your LVDS(cable from the main board to the t-con)cable is faulty. When you turn the set on, do you have a red screen instead of the standard blue screen? Do you also have red tints on all images on all inputs? If this is the case, your LVDS cable is bad. If you are comfortable opening up your set, track down where the LVDS cable goes into the t-con board. Turn on the set, and wiggle the cable, if the red tinting goes away, you will need a LVDS cable, about $24 part.
Dec 09, 2012 | Vizio VO47L 47 in. LCD TV
Vizio VO370M red color has gone away
Change the input to some other device and see. Then if the problem persists, this might need attention by a qualified service technician.
Jul 25, 2012 | Vizio E370VL 37 in. LCD HDTV
My av input shows in black and white. how can i change it
is it the red white and yellow or the green blue red outputs? If it's the red, white and yellow then first try another set of RCA jacks, because bad jacks can cause this problem. Then if that doesn't work then you will have to repair or replace your video board or main logic. Try shopjimmy.com or discount-merchant.com
Dec 24, 2010 | Vizio 42 in. LCD TV
My vizio won't turn on and has code 5.1
http://cdn.vizio.com/documents/downloads/hdtv/SV420XVT/SV420XVT_Users_Manual.pdf ..not sure if this will help you out its the only manual i can find.half way down the page it gives yoy faults and what to check for.
if this is not the manual please let me know.
Jul 12, 2010 | Vizio L32 32 in. LCD HDTV
There is a blue line on right side of screen extending upward about third of the way
A picture is worth a million words in this case.
Since the line is not all the way up chances are you might be able to repair it.
Might be the LCD controller, which for Vizio L37 is T370XW01 or could be the main board.
if the line was all the way it would likely have been the LCD itself, which is not repairable; chances are still that's what it is, of course, but I can't remember seeing an LCD problem as you describe it.
Both the LCD controller (also called TCon) and the main board can be found on eBay and other dedicated stores. In fact I happen to have the TCon from a recently dismantled L37...the main board went out to repair another Vizio L37 just two days ago.
Hope this information helps.
Your rating is appreciated!
Jan 29, 2010 | Vizio L37 Television
Vizio VX32L HDTV10A
I had the same problem with my 32" Vizio lcd tv, I took it to a repair shop and they said it might be the motherboard but they didn't seem too sure about. I am considering ordering the motherboard and trying to fix it myself hope this helps.
Nov 29, 2009 | Vizio VW32L 32 in. LCD HDTV
Vizio 42"LCD Red Dots when warm
sometimes changing from hdmi to composite inputs solves it.
Jan 01, 2018 | Vizio Gallevia GV42LF 42 in. LCD...
Vizio 52 Red dots
It sounds like you have a defective LCD panel. This is more common with the plasma TVs. Are you sure it's an LCD?
Aug 01, 2009 | Televison & Video
I have a Vizio SV420XVT. There is a green line from top to bottom on the right side of screen. Help me fix this, just went out of warranty
A single line out means a bad LCD panel..The cost for parts will exceed the cost of replacing the TV...
Jul 23, 2009 | Vizio SV420XV 42 in. LCD TV
No signal
You need a main board
I’m happy to assist further over the phone at https://www.6ya.com/expert/lou_afa492c634393790
Nov 14, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
170 people viewed this question
Top Televison & Video Experts
