Question about Kenmore HE2 Plus Front Load Washer
Fabric softner not being added to wash.
Model 417.41042000 Replaced harness-disp valve-Haw w/atc. The old valve tested 1.54 ohms softner side and 1.65 ohms bleach side.
  • 3 more comments
  • scritch2 May 06, 2010
    Everything was clear before I install the new valve .
    After checking the dispenser for blocked passages, I replaced it into the machine and started the wash cycle. After the machine filled I checked the dispensor and it didn'tt have any water in it.
    After I checked for clogged passages Ireplaced the dispenser ans started the wash cycle. After it filled and started washing I checked the dispenser and there was no water in it.
  • scritch2 May 07, 2010
    I ended up finding that the UPPER compartment was clogged. I cleaned it out and it's working! THANKS!!
    Helped point me in the right direction
    President:
  • 1,554 Answers
Verify first if the fabric softener compartment in the dispenser drawer is full of water. If water is present, pull the dispenser drawer out then release the clip to pull it out completely. Remove the fabric softener compartment cover and clean the tubes both in the dispenser cavity and the compartment cover. The tubes fit together but the tube in the cover does not touch the bottom of the cavity to allow siphoning action when an overflow situation is created in the compartment to dispense the fabric softener. No dispensing action will occur if the tubes are clogged.
Posted on May 06, 2010
  • 1 more comment
  • Jahn27
    Jahn27 May 06, 2010
    Is the fabric softener dispenser compartment filled with water?
  • Jahn27
    Jahn27 May 07, 2010
    Sorry for the delayed response due to time zone constraints.
    The fabric softener compartment is filled only with water during the rinse fill as the right-hand side dispenser valve is activated only during this time. Allow the washer to advance to the rinse cycle before checking the fabric softener compartment for water. The dispenser valves are newly replaced so a bad dispenser valve issue can be ruled out. The only issue now is the water not being fed to the fabric softener either due to the valve not being powered up or the tube going from the valve to the compartment is clogged. But you stated previously that everything is clear which indicates that most likely the valve is not activated. Swap the dispenser valve wires to check this condition. Put bleach, detergent, and fabric softener in their respective compartments then run the washer without load and allow it to advance to the rinse cycle. Check which compartment is not flooded or dispensed after the cycle is completed. Check power for the valves coming from the control board/timer if the fabric is dispensed but not the bleach and the detergent.
  • Jahn27
    Jahn27 May 07, 2010
    It's a pleasure to help you. Thanks for using Fixya.
  • 10,865 Answers
Hello. It appears that Kenmore is having numerous problems with the fabric softener injector. Read this link to get a flavor for the depth of the issue and then consider going back to the store and filing a formal complaint. It doesn't appear that there is a fix to the problem. http://www.epinions.com/msg/show_~threads/cat_id_~17/id_~4097/forum_id_~409
Joe
Posted on May 07, 2010
While the washer is go thru the wash cycle it is not adding the detergent, fabric softner, or bleach what would cause this ?
the disp. motor sounds to be off hook , unplug washer open the top of the machine and look to see if the dispenser arm is conected to the motor if its off trasck put it back on the track this shouldhelp
Sep 02, 2011 | LG WM1812C Front Load Washer
Maytag neptune tl fav6800aww wont dispense fabric softner
Test mode? Do you mean Service Mode and you turn on the solenoid for the water valve to divert water to the Fabric dispenser reservoir and it is flushed in Service Mode?
See if this solution will help with your trouble shooting.
Let me know if I can help……Rich
Apr 19, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The fabric softner dispenser does not release the liquid softner
The fabric softener solenoid valve is faulty and must be replaced. It is sold as an assembly with the bleach solenoid valve with part number 997846. You need to remove the front panel to lift the top panel to inspect or replace the valves.
Front panel removal procedure:
  1. Unplug the machine.
  2. Turn off the water supply.
  3. Open the door and remove it by removing the screws on the hinges holding it.
  4. Remove the remaining two screws on the opposite side along the inside lip of the door opening.
  5. Press in on the outer upper edges of the front panel posts then twist it inward to release it from the clips on the face of the cabinet.
  6. Tilt the top of the front panel away from the washer and remove it.
  7. Remove the four screws holding the dispenser bezel to the top of the top panel.
  8. Remove the 5/16" hex head screws securing the two hold down brackets on the top panel.
  9. Swing the hold down brackets to the outside to unhook it from the slot in the top panel lip.
  10. Lift the front of the top panel and tilt it toward the rear of the machine.
  11. The dispenser valve assembly is the one on right of the water inlet valve assembly where the water supply line is attached to. The fabric softener dispenser valve is the one on the right most.
  12. Clean the terminals and the connector of the fabric softener dispenser valve.
  13. Grab a multimeter and check the resistance between its terminals. The resistance should be between 500 to 1000 ohms. If it reads open, replace the dispenser valve assembly.
  14. Remove the wire harness connections to the valve solenoids.
  15. Loosen and remove the hose clamps on the hoses.
  16. Loosen the valve mounting screws by turning it at least three full turns.
  17. Slide the valve assembly to the left and remove it from the bracket.
  18. Place a towel below the valve and remove the hoses.
  19. Install the new dispenser valve assembly in reverse order.
  20. Install the top panel, dispenser bezel, front panel and the door in reverse order of the removal procedure.
Jan 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Adding liquid to rinse cycle
on your h-3 the soap disp tray will allow you the add powder ,liquid, bleach, or fabric softner at the time you put soap in disp then the water valve will dispence at proper times in the wash cyc you don't have to stop the wash cyc
Aug 26, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Water dispenser on GE side by side not working. what should the refrigerator and freezer settings be? Can that be the problem?
Dispenser controls on any refrigerator actuate one of two things. Ice disp, or water disp. If the IM is not working also, then H20 valve is bad. If just the H20 disp feature isn't working in the door, try this: remove food and unplug unit for 24 hours. Then, plug back in and resume normal operation. If all checks ok, you have a frozen water tank, or frozen water line. Fix: on certain model ref's, there is a water tank service flash where an antifreeze insulation kit should be installed, contact Sears or your retailer for this information. On others, this is simply a freeze up caused by lack of H20 usage or temps in ref/freezer set too low. If this does not fix the water supply, and you still have ice production after 2-5 hours after restarting the ref, remove the dispenser cover and test the water supply actuator switch for continuity. of open after drepression, replace switch. If switch checks ok, then replace water valve as on side of the solonoid valve assy is not functioning. In rare cases, you may have to check or replace the wiring harness. This can be tested only after elimenating the disp switch test, and calling for H20 from the disp, voltage at the disp wires to the H20 valve, but no voltage recieved at the h20 valve, or by an ohm reading of the wires.
Jun 10, 2009 | GE GSS20IEP Side by Side Refrigerator
Maytag MAH8700AWW will not dispense fabric softener
u need to replace the water valve theres 2 the cold is what u would replace
May 21, 2009 | Maytag MAH8700AWM Neptune Front Load...
Water left in bleach and fabric softner after running load
You must take out the compartment and empty it out before adding any bleach the next time, there is a type of button way in the back that you press down on pull out the entire door and empty the water for the next washing. You must press down very hard the entire door does come out check out your book for instructions it is way in the back on the left hand side. This happens to mine once in a while not all the time.
May 05, 2009 | LG WM1812C Front Load Washer
FABRIC SOFTNER DOES NOT DISPENCE
Check to make sure the litle cups are set in place correctly and also make sure they are not blocked with hard fabric softner. A quick test: pour water directly into the fabric sofnter cup and fill it up,IF it siphons out, you will need a new inlet valve for that unit. The inlet valve has soliniods on it for the bleach & fabric softner.
Good Luck!
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 44082 washer won't take in fabric softener
Remove hoses from fill valve, clean screens inside fill valve, if this does not fix problem, replace valve.
Jan 17, 2009 | Kenmore 44102 Front Load Washer
Fabric Softner not leaving dispenser
Run some vinger through it. Fabric Softner leaves a filmy residue that can clog it up.
Jan 11, 2009 | LG DLE5932W Electric Dryer
Kenmore HE2 Plus Front Load Washer Logo
123 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
