Question about Philco (R) 841.205 CD Shelf System
How do you get the turntable to start turning? We just got a Philco turntable and can't find a switch to get the turntable to turn. We got it used so don't have the instruction manual.
  • Philco Master
  • 5,391 Answers
A lot of turntables start moving when the arm is moved to the record start. The turntable should move when you move the arm to the edge of the platter, even with no record. If it doesn't, listen to see if the motor spins. Then lift up the platter matt to see if the belt has slipped off.
Posted on May 06, 2010
Motor on philco turntable not working
Most of these motors run on about 9 to 12 volts DC. You can connect a 9 volt battery to the terminals of the motor. Make certain the rest of the system is off and the motor power leads are not connected to the main system. If the motor doesn't turn with the battery it's faulty. If it does then you are perhaps looking at some switch that has failed or the power to the motor itself!
May 04, 2014 | Philco (R) Classic Turntable CD Shelf...
The turntable on my philco cd cassette and turntable unit does not turn. how to i access the belt, etc. to see whats wrong?
I had a similar issue with my Crosley turntable that I recently picked up... and after digging up the manual online all I had to do was lift up on the tone arm and move it to the right (past the holding mechanism) until it clicked, and voila, the turntable started spinning again.
I hope this helps!
Sep 18, 2010 | Philco (R) Classic Turntable CD Shelf...
Philco 841.205 Turntable Issues
I take it that it doesn't turn? OK two choices for you. Faulty motor, or a on/off switch that doesn't work. If you have to move the arm to start the turntable then some kind of leaver switch is either bent or broken.
I should imagine this model uses no more than a 12 volt motor. If you have no look with the switch, find the motor and take it out. Then stick a 9 volt battery on it, or lower voltage if it's only 6 volt motor. If it don't go it's bust!
Jun 01, 2010 | Philco 841205 Turntable
How to turn on turntable on Philco Turntable CD Player
Just pull the arm back a little bit, the turntable should then start.
Apr 20, 2009 | Philco (R) Classic Turntable CD Shelf...
Philco 841210 turntable problem
need more info....
is the motor getting AC to it?
can you feel any hum or heat on the motor itself.?
Have you tried hand turning the shaft in the motor?
Bushings often totally dry up and have to be re-lubed
contact me at jcrd(at)peoplepc.com
Feb 16, 2008 | Philco (841210) Turntable
Philco 841.205 TurnTable spring and plastic armature pulled off HELP
Well it turned out that that 45 degree plastic piece DID or WAS attached to the main post. It snapped off. I super glued it back on and to each side of that very flimzy broken plastic I cut two very small pieces of wood (using popsicle sticks) and super glued THOSE to either side of the broken armature piece. Once dried I re-attached the spring and it worksd like a charm.
Oct 10, 2007 | Philco 841205 Turntable
Turntable won't turn
In the middle of the TT youll Find a C-Clip It needs to be Removed before the Platter can be removed,You either have a Broken Belt,Or the Grease in the Guide is Old and must be Cleaned out and Relubed
Jul 19, 2007 | Philco PC-841.651 Turntable
Philco (R) 841.205 CD Shelf System Logo
504 people viewed this question
Top Philco Audio Players & Recorders Experts
 Grubhead
Grubhead
jason
Steven Wander
Steven Wander
Are you a Philco Audio Player and Recorder Expert? Answer questions, earn points and help others
