Question about Hitachi EDX-3280 LCD Projector
Projector says lamp failure and picture has turned Yellow
Projector says lamp failure and tempreture light flashing,picture has yellow cast to whole of picture.
Circular pattening on left of projected image.
  • 144 Answers
Replace the unit,it sounds like its old,has been used a lot,and needs a complete replacement.
Posted on May 08, 2010
Projector tdp s9 lamp indicator turns yellow light, even when new bulb is replaced correctly
Once you replace the lamp you need to go into settings and reset the bulb hours back to zero. That will take care of your problem
Feb 14, 2015 | Toshiba TDP-S9 Multimedia Projector
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Picture blurred with yellow cast
Its a Dlp that uses a lamp---the yellow cast suggests a damaged Optical light Engine----Google the model number with problems and you may learn more---if the engine is bad it may not be cost effective to repair the set.
Dec 08, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
Our ViewSonic PJ558 is emitting yellow light. The whole display is in yellow already. Please help.
If the yellow is perfectly uniform across the whole screen, then a processor problem may be present.
If the lamp is very old then this could be a problem.
Otherwise an optical part has deteriated due to overheating
Jul 26, 2011 | ViewSonic PJ558D DLP Projector
Yellow image produced by DP8200x
the light filter on the blue lcd is fried and needs to be replaced. it makes sure only blue light comes therough that lcd panel. when it's light is blocked from coming through, only the red and green lights can be seen, hence the yellowness (red light+green light=yellow light). it's common with lcd projectors. unfortunately, you can't buy that piece seperately. you need to buy the entire optical engine, which isn't cheap (almost $2000).
Jul 31, 2009 | ASK Proxima InFocus Projector lamp for...
Bad yellow cast to photos when printed
If you have a yellow cast to your photos, the problem might not be your printer. If you're using a digital camera, indoors under incandescent lighting without a flash your pictures will look yellow.
If this is the case, set your camera's White Balance to Incandescent lighting or use the flash. If all of your pictures, even those taken in daylight, look yellow you'll have to adjust the colors on your printer using the "toolbox" software that comes with it and back the yellow off. I've found that HP printers tend to have better color rendition than Canon.
May 24, 2009 | Canon Office Equipment & Supplies
I have a Hitachi 50vg825 and the picture is a yellow cast to it what wrong?I just replaced the lamp.
Sounds like your light engine might be going. Hope u still have warranty. Usually pretty expensive
Apr 22, 2009 | Televison & Video
I have a viewsonic pj500 projector which has functioned perfectly for 5 years. Now the area around the image area either shows a dark blue with dark stripes and the image area has a yellow cast which seems...
LCD projector 101, your blue device is dying inside of projector. Consider purchasing a dlp based product, they do not suffer from color decay.
Really you are blessed , most lcds last about 3-4000 hours or 4 lamp changes. good luck
Apr 13, 2009 | ViewSonic PJ500 Multimedia Projector
Unit will not power on
Company said it was defective. Sent back for exchange.
May 30, 2008 | ViewSonic PJ501 Multimedia Projector
Infocus LP240 Projector
The bulb won't do that. What you're describing sounds like a light tunnel failure.
Feb 05, 2008 | InFocus Lamp Projector Lamp for LP240 [...
Hitachi EDX-3280 LCD Projector Logo
231 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
