I have an RCA model #HD50LPW62AYX2 hdtv/dlp rear-projection set. The picture went out, and we thought it might be the bulb, so replaced it. The picture still will not come on, and there is a loud whining sound coming from the back of the TV, which even continues for a time after the set has been turned off. Could this be a color wheel?
  • 1 more comment
  • laurieb58 Mar 27, 2008
    When the set is turned on, there is just no picture, and no light coming from the back of the set. We can hear sound; the whining noise does not always occur, but can start while the set is turned on. When we turn the set off, we can still hear the whining sound, for maybe 30 seconds or so. It's VERY loud! Like I mentioned, we did replace the bulb, originally thinking this was the problem, but apparently not......
    When this TV's functioning properly, it's a beautiful picture, and we've never had a problem, except for a lamp burnout at one time. It's about 2 1/2 years old.
    Thanks for any suggestions you can provide.
    It says "ATC322W1"
    Thank you so much - I'll show the above to my husband, as I'm certainly not going to touch it! We have a repair person coming out early next week, I hope, but I was kind of hoping it would be something we can take care of ourselves.
    You've been very helpful!
    Laurie :)
  • 8,617 Answers
The color wheel can make a whinning sound for sure, However it should not continue to whine after shutting it off. That sounds more like the fan used to cool the lamp, as that will continue to run after the set is shut off. How soon does the whinning start when you push power? Let me know I should be able to help you out. DLPs are my specialty
Posted on Mar 27, 2008
  • Sonny Berry
    Sonny Berry Mar 27, 2008
    look on the back of the set for the chassis number it should be an ATC number. if the lamp is not lighting I would assume you have some bad caps on the power supply if its the ATC336 I have a tip posted under my profile that fixes the power suppies on that chassis. Let me know the chassis and we can go from there.
  • Sonny Berry
    the ATC 322 has just 7 components that feed the voltages from the bridge rectifier to supply the ballast which lights the lamp they are Diodes DP251 & 252, Resistors RP251 & 252 , Capacitors CP251 & 252 , and the line coil LP251 If you are planning on repairing this yourself, I would highly recomend getting the service manual and some support as DLPs are easy to diagnose with the proper info. I will post a link where you can get the proper service manual for that chassis emailed to you, and they provide free support with any manual purchase so you will have any help you need to actually figure out whats going on with your set. Heres the link if you want the manual just click on the RCA section and then select ATC322.
    http://servicemanuals.vstore.ca/
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: WHINING SOUND
More likely it is the color wheel this set uses---it is located inside the optical engine---part number for it:
267888This part is no longer available from RCA but is available on several sites on the internet (google the part number)
The wheel will when going bad sometimes make a fan like noise or even a high pitched whine.
Check out the sites on the net that sell this for price and decide if you want to attempt to replace it or if you have to have a shop do it for you.
Let me know if you have any questions or need advice.
REGARDS, SD TECH
Posted on Oct 05, 2009
I need to find a bulb for a D52W26
your model doesnt have a bulb like the DLP projection. Instead you have three CRTs ( picture tubes) one red, one green and one blue. If you respond to this same post with your symptoms I can assist with diagnosis.
Oct 25, 2011 | RCA HD52W56 52" Rear Projection HDTV
WHINING SOUND
REGARDS, SD TECH
Oct 05, 2009 | Televison & Video
Have a Pansonice HDTV 1080i. Model PT-47WX42F. Turns on but the
You DO NOT have a DLP set, you have a conventional rear projection set with 3 picture tubes in it. If your led's are blinking then you have a problem loading down the power supply. I recommend you call a service company.
Jul 15, 2009 | Panasonic PT-47WX53 47" Rear Projection...
No Picture but sound
if you have a dlp with the 267888 color wheel, the wheels cant be replaced as RCA no longer makes them. If you use one of the other type color wheels you can get a replacement at the following link. They would need the model number of your set as The D52W19 isnt a dlp and doesnt have a color wheel. So just let them know what the model number of your set is.
Jul 10, 2009 | RCA D52W19 52" Rear Projection Television
Does any one make a replacement color wheel for my rca #hd50lpw62ayx2 projection tv? And if so, replacement procedure to replace. Thanks
You can find a replacement color wheel for a model # HD50LPW62AYX2 at this following link:
RCA HD50LPW62AYX2 Replacement Part Color Wheel
I'm not sure about how to correctly replace the part. Hopefully a tech whose dealt with this model will post an installation guide.
Dec 15, 2008 | RCA HD61LPW165 61" Projection HDTV
The rca scenium / src / dcr /dlp /51"/ hdtv -picture doesnot appear -could heard the sound
you need to replace the bulb. It costs about a hundered dollars and you can replace it yourself. refer to the lamp replacement instructions that came with your set
Oct 20, 2008 | RCA Scenium D40W20 40" Rear Projection...
RCA 52" HDTV DLP tv
suspect the optical engine as the culprit. they can gather dust contamination internally and cause a "faded or washed out pic"
Apr 09, 2008 | RCA Scenium D40W20 40" Rear Projection...
Rca Dlp
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step instructions on troubleshooting Your DLP light engine.
Jan 14, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Televison & Video Logo
462 people viewed this question
Top Televison & Video Experts
