Question about Hotpoint (HSM25IFTSA) Side by Side Refrigerator
Water in freezer bottom and water leaking out from
Water on bottom freezer floor and water leaking out from freezer once a day. Whar is causing this problem
  • 375 Answers
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Posted on Jun 03, 2010
Why is there a layer of ice on the floor of the bottom freezer of my refrigerator?
The water most likely is coming from a defrost drain blockage. Unplug and remove the rear panel inside the back wall of the freezer. See panel location #4 in the photo=> HERE
You will need to get that panel out of the way to see and clean out the defrost drain.
Click Here=>Leaking Refrigerators
I am here should have questions, Thanks John Tripp Appliance 911
Jul 23, 2014 | Maytag 22 cu. ft. Bottom Freezer...
Ice is forming in the bottom of my side by side fridgedaire freezer and once its 1/4 inch thick starts to melt and leak from the freezer onto the floor. I then take out the ice built up and the process...
The drain is either frozen or plugged...when the freezer coil defrosts the water has no place to get away...
Find and fix the drain and you will be okay again...
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Nov 16, 2010 | Frigidaire FRS3R5EMB Side by Side...
Water leaks out of freezer bottom same time every day model rsd22
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 13, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water leaks every 5-7 days from the freezer. I
If your water valve is not closing properly, it will do that. The water valve is not very expensive. If you have ice and water in the door, there are 2 water valves. Replace BOTH! If one is weak, the other is not too far from giving out too.
Jun 01, 2010 | Refrigerators
Kenmore side by side with water occasionally leaks water at bottom front. About every 2nd day. Whzt could cause this?
Most cases, your freezer evaporator drain hole is frozen, every time it goes into defrost, water backs into the bottom of the freezer and leak on the floor. Try turn off the freezer for approx. 48hrs with door open, afterward turn it back on, most cases it will reset by it self, if no,t check door gasket, evaporator fan motor or debris in the drain hole. Good Luck.
Mar 03, 2010 | Refrigerators
Freezer leaks since we moved it to fit vinyl flooring in kitchen
Generally there is a water tray at the very bottom that can be slide out and in with a hose attached to it. its for excess drainage.. with the moving of the refrigerator is sounds like maybe the hose can loose and causing youre puddle. I would start there first.
Jun 11, 2009 | Samsung 25.8 Cu. Ft. Side-By-Side...
Water building up on the bottom inside the freezer side
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
Apr 19, 2009 | Frigidaire Gallery Series GLRT83TEK 30"...
Leaking frost-free Zanussi fridge-freezer
Has this thing a separate frezer and cooler compartment.
Have tried to completely defrost and clean that thing.
At times like in airco's the pinch valve for the cooling process to effect (expansion) is stuck frozen, or very seldom broke.
Apr 14, 2009 | Freezers
Frigidaire Side-By-Side Refrigerator Leaks Water on Floor
I don't have the same refrigerator, but had a similar issue with a GE. Melt the ice at the bottom of the freezer. I think the water comes from the auto defrost feature. There should be a hole at the back bottom of the freezer that water would go into, and run to an evaporator pan under the refrigerator. The tube may be blocked that allows this water to drain, so it is backing up in the bottom of the freezer, and overflowing through the front bottom of the freezer to your floor.
Sep 28, 2008 | Refrigerators
Freezer leaking water
The drain is plugged just below the coils in the back of the freezer. My fridge had the same problem and I found the hose (which can be accessed from the rear bottom) was plugged with mold. Also, i noticed the hose was connected to the water holding pan and was too close to the bottom and easy to plug. I removed it from the connector and just let it dangle in the holding pan.
Aug 30, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Hotpoint (HSM25IFTSA) Side by Side Refrigerator Logo
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
