Question about GE Heating & Cooling
GE model AJM10DFV1 window unit I need the
GE model AJM10DFV1 window unit I need the Specs on this unit Power and BTUs
Remove front panel and there is an info plate that says:
Cool BTU/ HR AHAM 9 700 / 9 500
AHAM - Association of Home Appliance Manufacturers
Posted on Jun 17, 2013
2 Suggested Answers
  • 13 Answers
SOURCE: What's the BTUs for a Frigidaire window AC, model A1838?
it is in the model number a (18000 btus)38 this is a 1.5 ton.
Posted on May 15, 2009
Need a wiring diagram for split system heat pump model number ch5536vkc2
need more information to help you.
1) is it single or 3 phase?
2) what power does it have? (example 30000 btus )
3) is it for the indoor unit or for the outdoor unit,? or both?
4) does it has an electronic circuit board in the indoor unit?
5) do you need only the field wiring diagram from indoor to outdoor unit?
Post me back with some details and I may help you out
Best regards,
Silvio
Dec 08, 2014 | Heating & Cooling
I need to know what the voltage for this unit
Model: REG-123H
  • UPC: 855326002968
  • Product Type: 12,000 BTU Window Air Conditioner & Heater
  • Product Dimensions: L: 24.00" x W: 24.00" x H: 16.00"
  • Product Weight: 88.00 lbs.
  • Product Color: White
  • Application: Used to cool individual rooms
  • Type: Window Air Conditioner
  • Warranty: 1 year; 5 years sealed system
  • Coverage Area: 550 square feet
  • Voltage: 230 volts
  • Heater: Yes
  • Air Flow: 266 CFM
  • Amps: 5.5 amps
  • Heating Capacity: 11000 BTUs
  • Frequency: 60 Hz
  • Cooling Capacity: 12000 BTUs
  • Dehumidifying Capacity: 3.6 pints
  • EER: 9.8
  • Heat Pump: No
  • Number of Fan Speeds: 3
  • Programmable Timer: Yes
  • Timer Length: 24 hour
  • Refrigerant Type: R-410A
  • Air Conditioner Type: Cool/Heat
  • Energy Star Rated: No
  • Air Filter: Yes
  • Built-In Air Purification System: No
  • Display Type: Digital
  • Remote Control: Yes
  • Adjustable Louvers: Yes
  • Adjustable Side Panels: Yes
  • Compatible Window Size: Min. Window
  • May 31, 2014 | Comfort-Aire RED-123 Air Conditioner
    Morning, I got a external unit SH24BP2X samsung fro air conditionning, and I'ld like to buy an indoor unit. Is anybody can give me ref which match with this unit. I need 5/6 kw heating power. Thanks...
    The 24 in your model number means 24,000 btus. There is 12 thousand btus in a ton of cooling. This makes your unit a two ton. You can buy a air handler sent up for two tons of cooling and then buy what every electric heat pack that you need. let me know. wally
    Mar 16, 2011 | Samsung Heating & Cooling
    What is the btu of this model.m7q08f2a.
    Hi, to find out the tonnage of your unit in b. t. u.'s, look at the 08 in your model number. There are 12,000 btu's per ton of cooling. You have a window /wall unit, and according to the model # 08 is not a 1/2 ton or a 1 ton, but a 3/4 ton unit or 8,000 btu's if indeed this is the correct model number. Most units we come across are in btus as 06 which is 1/2 ton, 12,000 is 1 ton, 018 is 1 1/2 ton and on up with a properly matched indoor coil. Your unit is a package window unit, so both coils are equal.
    Sincerely,
    Shastalaker7
    A/C, & Heating Contractor
    Nov 18, 2010 | Maytag M7Q08F2ACOM Air Conditioner
    Trying to find ton rating for a Tempstar 9000 mod# CA903VKA2.
    If this is a window or portable unit, you will not find the tonnage only the BTUS. My guess is 9,000 BTUS
    3,000 less than a ton
    Jun 17, 2010 | Heating & Cooling
    Would like to replace need to know size of unit and age.
    this unit is a 3 1/2 unit...the 42 the model number...possible its a 89 or 97 model...this is a 42,000 btus unit...hope this helps...michael 843-384-8474..
    Mar 27, 2010 | Heating & Cooling
    I had two very different quotes for installation. They recommended different models and different blowers. 15k vs 17k mxz4a36na vs mxz3a30 model. By getting the less expensive model and smaller blower...
    The last two numbers in the model number indicates the Btu ratings. The mxz4a36 indicates that this unit is capable of putting out 36,000 Btus and only 30,000 Btus on the other. I would be concerned that the second unit is large enough to satisfy your cooling load. Forget the power, make sure the unit is sized properly.
    Nov 11, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
    Apr 23, 2009 | Heating & Cooling
    Heating & Cooling Logo
    285 people viewed this question
    Top GE Heating & Cooling Experts
    ray gallant
    Lawrence Oravetz
    richie46
    Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
