Question about Sony KV-36FS100 36" TV
Tube tv where the screen is crushed into 2 inches
I have a old tube tv that most times has a crushed screen, but if I hit it on the right side it will sometimes go to a full screen. That will work until I turn it off for a while, then it will go back to the crushed screen. Is there anything lose, that I would be able to fix? If there is anything else you could suggest that would be appreciated, I am trying to find a way to fix it by myself.
  • 4,234 Answers
The problem is likely to be poor solder connections at the vertical IC. This is a small flat IC witharound 11 pins attached to a heatsink. If you can read the letters on the IC, it will be LA7837 or something similar. Resolder the pins and try the set. That should resolve the problem. Please note that there are potentiallty dangerous high voltages present inside the set, even when unplugged.
Dan
Posted on May 06, 2010
  • 321 Answers
Get a good magnifier and soldering iron
open thw back cover set unplug leave it discharge for a while and flip over the pc board and try to fin any cracked solder on the espescialy on the right side near the hig voltage transformer and near the power
supply and regulator you may find the bad one
hope that will help.//watch for not speel soldering betwen component pin .regards A S
good luck...
I need a picture tube for my 50in.Sony t.v . I live in central MI. Need to know where & how , to buy & fix the pic.tube Thank You...
projection screens dont use tubes,a 50 inch tv tube will cost 1000 a new flat screen tv is alot cheaper,buy a flat screen hd ready tv
Apr 16, 2015 | Televison & Video
I have black line down right side of 42 inch hitachi lcd tv screen
You have a CCFL lamp that is failing in the panel, time for a new TV
Jan 22, 2018 | Hitachi Televison & Video
24" Panasonic Tau... about 9
Tv is old the tv CRT-(tv tube) it CRT Yoking circuitry not good as before.The tv deguassing coil in not eleminating all the interference of the tv functions anymore.Move the tv unit to the right or to left like about 3 or 4 inches either sides will help for this problems.
Apr 18, 2011 | Panasonic CT-24SL13 24" TV
My new (used) Sony Trintiron recently took a fall and the screen was damaged. The damage appears to be a gash approximately 4-41/2 inches long and 1/4 inch wide. Is there a way I can fix this or get a...
The tv CRT-(tv tube) screen itself is broken now or dying already and tv PCB board broken require replacing too,tv will still work after replacing PCB board or repairing it but tv will not be watchable becauuce tv screen will all mess up like screw up picture colors will have black and blue colors be all over the tv screen.Tv now will not be worth repairing if require replacing CRT-(tv tube) will cost the same as a new tv if tries replacing CRT-(tv tube) if u still can buy it.Can't buy analog CRT-(tv tube) anymore.Sorry time to buy a new tv.
Apr 14, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I have an old tube tv screen, 19 inch. Fable 3 just does not seem to want to fit properly. I am missing about an inch on all sides. I am pretty sure my xbox settings are right.
Most 360 games are made for High Definition Widescreen now.
Have you got an aspect ratio button on your remote? Try switching it to 16:9, and changing your Xbox settings to "Widescreen". You may get the two black strips top and bottom, but the game should look fine. I hope this works for you, as I know how annoying that can be!
Jan 26, 2011 | Microsoft Fable 2 for Xbox 360
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
Angle Stop Installation
the ring is called a "crush" bushing it seals by: (crushing) reducing it's diameter around the supply tube; it can be used only one time as it deforms to seal. each time you remove cut the tube with the old ring off ;put the threaded valve cap with the hole in it (for the tube) threaded side facing the valve on the cut tube; then slip a new ring on the tube and, screw the cap on the valve
Sep 06, 2009 | Plumb Shop Div Brasscraft #453-191 MP...
36 inch tube tv - Screen flickers
my problem is don't sound in my mobile LG CE 0168 please help me.
Aug 17, 2009 | Toshiba Televison & Video
Quite some time ago my 42 inch LG plasma developed thin rainbow lines on the left side - now i have 2 1.5 inch vertical lines dividing my screen into 3 sections. can this be fixed ? and at what cost ?
How old it ur tv,ur plasma bulbs might need be replace.Could be the plasma tube it bad because long times use.But ur plasma screen it self could damage kind radiation not worth repairing.
U alway make deal with the repair man come out for estimate.Cost u like u repair with him.
Make sure ask him come out for no cost some charge $40 come out.
Aug 12, 2009 | LG 42PC3D 42 in. Plasma Television
Tv
Good day.
The problem with your unit is that when your tube was replaced, it was not degaussed or demagnitized. The purpose of such is to distribute the color evenly unto the entire television matrix.
You can try to demagnetized it by rotating a magnet around the surface( but not so near) of the picture tube while it is operating.
Also, please check for the degaussing coil around the rear portion of the tube was returned and also check for loose contacts.
chris
Mar 07, 2008 | Toshiba 36A61 36" TV
Sony KV-36FS100 36" TV Logo
44 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
