Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Aint gota a clue how to load paper in my epson stylus SX410 the user guide is absolutely dreadful
  • 30 Answers
The paper goes in the slot at the top in the part that you lift up like a flap and the paper comes out the bottom slot at the front that you pull down.
Posted on May 06, 2010
Hi My epson RX500 is not taking the paper, tries but then goes to paper jam
Try putting less paper in the tray. The paper you are trying to use mauy be too heavy a bond (to thick) for your printer to use.
Refer to the manufacturers user guide.
Feb 27, 2015 | Epson Stylus Photo RX500 Printer
How to replace cartridges into my SX410 printer
Hi
The explanation could be quite long winded but if you go here:
Epson Stylus SX410
and stroll down the page, you will find a link for the User Guide for this machine. If you download this, and expand the contents from the zip file to a new folder named Epson SX410, then clicking on teh Index.htm file in this folder will open a browser page from which you can navigate to the relevant part which gives full and detailed instructions for ink cartridge replacement.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 22, 2014 | Office Equipment & Supplies
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
I have lost my disc, how do i install epson stylus sx410 to new laptop?
EPSON puts all the device-drivers for their printers onto their web-site: http://www.epson.com
Go there, and enter 'sx410' and do a search.
Download the device-driver.
Install it.
Print a test-page.
Feb 17, 2011 | Epson Stylus Multifunction Inkjet Printer/...
We have an epson stylus SX410/TX410 printer, copier and supposedly a scanner. However, we cannot see how you scan to a computer and cannot see the scan button. Advise please
I have an epson stylus SX410/TX410 printer, copier and supposedly a scanner. However, we cannot see how you scan to a computer and cannot see the scan button. Advise please
Aug 25, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Loading paper into an epson stylus tx110
hi there... this is what you need.
Loading Paper Follow these steps to load paper: step_1.gif Slide the edge guide to the left. ha5280001h.gif step_2.gif Fan a stack of paper, then tap it on a flat surface to even the edges. step_3.gif Load the paper with the printable side up, against the right side of the sheet feeder. Then slide the left edge guide against the left edge of the paper, but not too tightly. ha5280002h.gif ha5280003h.gif mark_no.gifNote: Leave enough space in front of the printer for the paper to be fully ejected. Always load paper into the sheet feeder short edge first, even when you are printing landscape-oriented pictures. Make sure the paper stack fits under the fon4_99.gif arrow mark inside the left edge guide.pls vote for me
Mar 09, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I am looking for instructions on loading envelopes
Try the link below, it's to a on-line user's guide for your printer. To the left you should see a list of subjects, just click the one that says "Load Paper" then click on "load envelopes".
http://files.support.epson.com/htmldocs/nx400_/nx400_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Aug 01, 2009 | Epson Stylus NX400 InkJet Printer
Inserting A4 paper
maybe this Site helps.
http://safemanuals.com/user-guide-instructions-owner-manual/EPSON/STYLUS%20SX100-_E
Here you can find many documentations e.g. for your Epson Stylus SX100
Jun 02, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Loading paper
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
takiqq18
Feb 01, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
216 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
