Question about Jenn-Air JLG7130A
I have a JennAir grill, model # 720-0337, purchased at Lowes 2 years ago. It is not getting enough gas to the burners, just will light slightly but not enough for proper heat. I have cleaned it thoroughly and still nothing obvious. Do I have a regulator problem?
Full tank(s) no gas to grates???
Posted on Oct 05, 2012
SOURCE: I have a 2 year old Jenn Air gas grill that I
I took out the burners and found that corrosion had made the holes much smaller. I took a round toothpick and, one by one, cleaned each hole. I then shook the burner so that as much of the corrosion as possible came out the gas line intake hole. Mine works just fine now.
Posted on Aug 28, 2009
gcken
  • 140 Answers
SOURCE: Looking for an illustration that
there are 2 or 3 screws on each side,unscrew them the front panel will be free pull down, now you can take the burner out and put new ones in.
Posted on Aug 19, 2010
tunde007
  • 2382 Answers
SOURCE: Hi There, I have a
Hi, you have to contact Clagrill on 501-821-4050 to request for your parts. I think they have a free shipping policy within the US.....
Posted on Aug 29, 2010
cadesertmax
  • 274 Answers
SOURCE: model 720-0164 bbq low propane to
What you have is a classic symptom of a bad regulator. If no gas is going fromt he new tank to the burners, you can bet it is the regulator. No real way to test it once it stops working all together. As it is going bad, the flames on the burners will get smaller as each buner lights.
Posted on Mar 20, 2011
Testimonial: "thank you that is exactly the problem! "
  • 4736 Answers
SOURCE: How do you replace burners on Jenn-air 720-0337
First, remove the grill grates, then the flame tamers to access the burners. As you face the grill, carefully lift up the end of the burner farthest from you (It may or may not have a cotter pin holding it in. If it does, remove the cotter pin with a pair of needle nose pliers). As you lift it up, it should pull away from the burner orifice (inside the control panel). And that's all there is to it.To reinstall the burner, do everything in reverse. But, there is no need to replace the cotter pin. It was there for shipping purposes.
Hope this helped you. Please let me know. Happy Grilling!!
Posted on Jun 12, 2011
I have a 3 burner spirit grill. I can light the grill, but only burner 3 gives me a nice even line of blue flame. Burner 2 seems to be the worst with oranges flames on the right and left end. Burner 1...
Charcoal and grease build up can restrict even the best gas burners , my suggestion is to clean your gas burners with a burner tip tool . You can purchase these at Lowes or Menards . Here is a website for you to visit to get the ideal . http://www.metaltech.com.sa/victor/tips.htm
Goodluck
Electrician by Trade
Feb 18, 2011 | Weber Spirit? E-310 Propane Grill
I bought a large 5 burner unit 5 years ago.
There are a few things you can check.
1. The burner could be rusted and needs cleaned or repaired.
2. A spider or other insect has built a web in the inlets of the burners.
3. If you are using a 20lb propane tank, it could be overfilled.
4. If you turn off your grill using the propane tank valve and not the valves on the control panel, it may cause the overfill protection device to engage and decrease gas flow.
5. The regulator could be faulty.
6. The jets(orifices) where the gas comes out may be sized to small or may be clogged.
Mar 03, 2010 | Grilling
Conversion kit or fix for LP to NG for the Char-Griller
I removed the jets and drilled them out, #54 is what I started with and then moved up from there to get a good flame( gas pressure may be diffrent in your area). I went to lowes and purchased the universal gas line for grills. Item #: 206469 from lowes, I removed the hoses from the valves, and proceeded to remove the regulator from the hose. After that, i used a 1/4" npt coupling, and a 1/4/" NPT to 3/8" Flare fitting( fits to hose). I drilled a hole in the brace that is under the clamshell(it says UP) that way I had a place to relive stress from the hoses. I threaded the Coupler to the Y then threaded the Flare fitting thru the sheet metal and then the coupling. This was an easy mod minus the garage in disarray, my precision calipers on loan, and 3 trips to the hardware store. The connection that goes to the house is a 3/8" NPT Female, my house has 1/2" pipe, The one wasted trip to the store is because i didnt bring the fitting with me to the store and assumed the size was 1/2 to 3/4(Rookie Mistake). 46e03a6.jpg846ce6e.jpgb1bb7d1.jpg
It was 35 degrees when I finished this mod, and on high for all 3 burners, I got it to 675F in a hurry. the needle was still creepin up, but that is when I said that was good enough for me.
I used my lathe to drill out the jets, ksware is correct with how easy the jets break. I broke the one in the side burner. I will make another one when I get an hour or two. Good luck to you and happy grilling.
Little Elm, Tx.
Sep 20, 2009 | Grilling
My charbroil grill isn't running at full power
Your venturi could be clogged up. clean the burner holes with a straightened paperclip, then take the burners out and do the same to the venturi that deliver gas to the burners. If that doesn't do it, you may have a bad regulator.
Feb 26, 2018 | Char-Broil Grilling
Loss of pressure on Kenmore 16322
I can tell you EXACTLY what is wrong. Remove the tank and open all valves to the grill. Reconnect the tank and turn it on just slightly. Relight the grill.
Ther is a safety device in the tank that needs to be reset. The only way to do it is removing the tank.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 17, 2008 | Kenmore 16322
Grilling Logo
150 people viewed this question
Top Jenn-Air Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Fred Harvey
Are you a Jenn-Air Grilling Expert? Answer questions, earn points and help others
