Question about Everest & Jennings 18" Metro Ic3 Lightweight Wheelchair
Front wheel threaded rod & bolt design problem
PROBLEM:I have the Everest & Jennings Metro IC4 wheel chair for my wife. (6 mos)The front wheels have a threaded rod on the end w/a bolt. Backing up the wheel chair...wheels turn around and expose the threaded rod going through the bolt. IT TEARS UP MY MOLDING as my wife manuvers through the doorways.I am a retired Director of Industrial Design & Human Factors Engineering .Do you have a form fitting cap to negate this problem?
    Guru:
  • 60 Answers
You might try Lowe's or Home Depot's hardware section. They might have a plastic bolt cover or plastic nut that you could put over the threaded end.
Posted on May 23, 2010
I am a quadriplegic and have had my Everest and Jennings shower chair since 1987. it is literally starting to fall apart. but it is the best shower chair, I have ever seen or used.And I would like to
Is it similar to this?
http://www.ebay.com/itm/Everest-Jennings-E-J-19-Transport-Chair-Wheelchair-/400197450577?pt=LH_DefaultDomain_0&hash=item5d2da07b51
Feb 03, 2015 | Drive Health & Beauty
Wheelchair repair
E&Js are common enough that nearly anyplace that sells new chairs can service them. You can also get most of the parts online at places like ocelco.com
Aug 05, 2014 | Everest & Jennings Travelers SE Steel...
I have a metro 500 and it is about 14Yrs old i never had a problem. After i put the new batterys some thing went wrong with the cnnector cable . My batterys are fully charge but on the joy stick within 15...
loose connection on battery? if new batts then you must charge them for a full 24 - 48 hours before using. but posts must be tight. they never fully charged if connections were loose to start check all connections on chair
Oct 27, 2012 | Everest & Jennings Health & Beauty
Is it safe to transport someone on a bus in a Everest & Jennings Transport Chair?
Yes, but only if the bus is equipped for handicapped, wheel chair bound passengers. If it's not, definitely, NO.
Hope this helped to answer you question. Thanks for choosing FixYa.
Sep 08, 2011 | Health & Beauty
I have recently purchased, used, a Everest and Jennings Metro Power power wheelchair. In searching the Internet, for any manuals or information, I have determined this is NOT a model three. I do not...
Have you contacted the Everest and Jennings Power Wheelchair company? Surely they would have something. I checked on eBay and found nothing in the way of owners manuals, but there are some medical supply companies who sell on eBay that I have purchased several items for my special needs daughter. They seem to have extensive equipment and supplies of all sorts.
Or, here is contact info for Doane's Medical Equipment who appear to have Everest and Jennings power wheelchairs. Perhaps they could point you in the right direction.
­?509-782-2717 or Online at www.doanesmedicalequip­?ment.­?com
May 17, 2011 | Everest & Jennings Metro Power? III Power...
Where can i get a tire tupe size 8 by 1 -1/4 85 p.s i for a wheel chair #3081434 in TUCSON,ARIZONA ?
That is a standard front tire size, not specific to any brand. Any wheelchair repair shop in the area should have that in stock. I googled "wheelchairs tuscon" and got multiple listings - maybe call Hewitt's scooter place or American Mobility.
Feb 23, 2011 | Everest & Jennings Advantage Manual...
How do you raise the metro to make it sit higher off the floor? Is it adjustable
This mnaual wheelchair has dual position rear axles and caster forks to allow seat to floor height changes with no additional components. What this means is that the wheelchair is adjustable in height based upon the position of the front caster wheel axles and rear wheel axles. Raising the axles lowers the chair. Lowering the axle postion raises the chair. If the rear axles of the rear wheels are in the top position you can lower the wheels and raise the chair. Likewise, if the caster axles of the front wheels are in the top hole of the fork then put the wheels and axles in the lower hole to raise the chair. It is easy to accomplish this with basic tools.
If the front and rear wheels are already in the lower holes (the chair is in its highest position) you have another option. This option is a more expensive way to raise the chair by buying 4 new wheels. Lets say for example you have 24" diameter rear wheels. If you purchase new 26" diameter wheels you will raise the chair 1". If you have 6" casters and put on 8" casters this raises the chair 1" in the front. Hope this helps.
Nov 23, 2010 | Everest & Jennings 18" Metro Ic3...
Metro power chair lights flash when turned on.. but will not move in any directions
The controller for this power wheelchair is a VSI controller made by Penny and Giles. The Everest and Jennings Metro Power III is distributed by Graham Field Health Products. The controller part number is #90762330.
To figure out what the flash code means go to the following website link for Penny and Giles(pgdt):
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
This VSI service center color diagram is very useful. It will tell you the problem with the power chair. A service technician will have a PP1 hand held programmer that will give more detailed information, but this is a start. Check all your wiring connections/plugs and make sure your chair is fully charged. Hope this helps.
Nov 21, 2010 | Everest & Jennings Metro Power? III Power...
Need 2f010 replacement batterys for a metro power lll wheelchair 12 volt unknown amps
The Auto Parts store in your community can help you with this ... take one battery into them sovthey can match it up.
Thanks for your interest in FixYa.com
Jun 14, 2010 | Everest & Jennings Metro Power? III Power...
Everest & Jennings 18"  Metro Ic3 Lightweight Wheelchair Logo
160 people viewed this question
Top Everest & Jennings Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Louis Smith
Are you an Everest & Jennings Health and Beauty Expert? Answer questions, earn points and help others
