Question about Sony SnapLab UP-CR10L Digital Photo Printer
MY SONY SNAP LAB will not power up. I changed the
MY SONY SNAP LAB will not power up. I changed the power cord and even tried on different sockets in the house it just was working perfectly a few days ago
  • 4 Answers
Sounds like your SnapLab's power supply is dead. You will have to send to repair, or order the part and replace yourself (if you think you are qualified to do that yourself...)
Posted on May 06, 2010
Lexmark 3500 4500 It was working fine a week ago or so. Now It won't light up when I press the power botton. I disconnected and reconnected the USB and power cords and it will light up with no message for...
Try and change to another power socket that is used for another appliance that works. Also try a fairly heavy powered device like a vacuum cleaner into the socket you use for the printer.
If no success try changing the fuse, they do get 'tired'. Make sure it is the correct value fuse. Also try using a different power cord.
If all that fails get back to me!
Jan 26, 2014 | Computers & Internet
Netbook turns off instantly when power cord plugged in - even when not plugged into power outlet!
Have you tried a different adaptor or power outlet other than that the dc jack on the notepad may need replaced
May 08, 2013 | Gigabyte Atom Series Netbook: Q2005 -...
CAN THE SNAP LAB DO CHRISTMAS CARDS (SLIM LINE) 4 X 8?
Yes, but you will need to upgrade the printer's version to the latest version. Go to http://www.kobisonline.com/Sony-SnapLab-UPCR10L-Snap-Lab-Digital-Photo-Printer-UP-CR10L_p_9.html for the firmware upgrade link
Dec 08, 2010 | Sony SnapLab UP-CR10L Digital Photo...
Hp Pro L7680 not coming on
Check if you see any light glowing in the power adapter, that is connected to the printer . If there isn't , then probably you may change to a new power cord and adapter.
You can also try a different wall socket.
Even afte that if the problem persists , then it could be printer issue. it needs to be replaced.
Sep 07, 2010 | HP Officejet Pro L7680 All-In-One Printer
It won't turn on. I've used a different cord in hopes that would work.
As you have tried to change cords for your laptop .There might be problem with power socket which is in the laptop. Also try to change battery of your laptop. It might work
May 04, 2010 | HP G60-120US Laptop
TV SAYS "UNKNOWN SIGNAL" AND I CANT GET ANY VIDEO OR AUDIO
The cord may have a short in the wiring. A pin in the connector could be missing. Or the PS3 hdmi socket could be bad. You should call Playstation Technical Support line at 1-800-345-7669 (1-800-345-SONY). If it under warranty you should not try to fix this problem yourself as you could cause even more perment problems.
Apr 28, 2009 | Sony Playstation 3 (PS3) Console
Computer powers ok from one location but not in another
Try and replace both power supply's with higher volt supplies.
Those are too low requirements to hold up those computers.
Solution:
Get two higher voltage power supplys.
Apr 27, 2009 | Sony VAIO PCV-W600G PC Desktop
PSP power cord does not fit into socket
before trying to replace the yellow socket try this first.got this same problem before.when i remove my charger before the yellow plastic ring was left stuck inside the socket.so when i buy a new adaptor it doesnt fit to the yellow socket anymore,so what i did is i use a piece of pin,bend the end point little bit and try lifting that yellow plastic ring inside.when i finally remove it the new adaptor fits again like nothing happens.try this first.if your willing to change it i will give you the complete instruction on how to replace it.hope this one fix your prob.
Jan 06, 2009 | Sony PlayStation Portable (PSP) Console
193 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
