Driver installation software can not locate image runner 5000 on network
I have an networked IR 5000 that was working fine.
I changed the ip addressing (I went from 192.168.1.X to 192.168.87.x )on my lan and it stopped working.
I have set the IP setting manually and i can ping the machine but the same software used to install a month ago now can not locate the machine by its MAC address.
Any suggestions?
Thanks phillip
    Scholar:
  • 141 Answers
Normally when you change a IP adress you just have to change the last digit.....
Posted on Mar 26, 2008
Ip address setting
This is probably like our color Canon copier...There is a screen with the network settings.available from the menu. Once you get the IP address, it is often easier to change and manage settings from the built-in web server on the copier. Open a web browser and go to http://192.168.x.x or whatever the copiers' IP address is.
Dec 19, 2015 | Canon Ir 3300 B/w Copier image Runner...
Scan and Send not sending - CAnon Image runner Advance 5045 - was working 3 weeks ago - not working now
working 3 weeks ago. well, something must have changed in your network since then, check smtp server with your mail provider if it is scan to email. if it is scan to the file, check firewall, ip addresses, destination folder, login and passowrd to the destination pc.
Jul 31, 2013 | Canon imageRUNNER 5000 Copier
My canon image runner 4005 (ir 330-405f) was connected to a network while i was formating my syste. The ip got deleted in it. What should i do?
check with network administrator for new ip or goto network settings and fetch ip by using DHCP.off/on the machine and thats it.
Sep 18, 2011 | Canon imageRUNNER 400S Copier
Need to install ir 5020 onto server. Do I need any config software first like HP JetDirect?
You would need to ensure that the IR 5020 has a valid IP address (Should be located on the Network Configuration Menu from the on-screen display). When plugged into the network for the first time the printer is usually given an IP address, this would allow you to connect to the web management interface and make changes to the settings from an easier interface than the on-screen display.
If you are planning on sharing the IR 5020 out from the server to other computers then you would then need to assign a static IP address to the IR 5020 so that the IP address would not change once configured.
(Side-note - I do not recommend using DHCP on printers as it can cause issues down the road if the printer is given a defferent IP address by the DHCP server.)
Sep 13, 2011 | Canon imageRUNNER 5020 Copier
Is it possible to install the Post Script drivers for a Laserjet 5000 printer? Also how can I use that printer within my network to print from other PC's
Yes, hp provides a Universal Postcript Driver.
1) Go to hp.com and click on Support & Drivers at the top of the home page. In Step 1, select Dowload Drivers & Software. In Step 2, Type into the window LJ5000 and click Go.
2) Select Laserjet 5000
3) Select your operating system, e.g. Windows XP, or Vista, etc.
4) Scroll down to the driver tables. Look for Universal Postscript Driver for Windows and click on Download.
5) Install the driver.
As for the network, I assume this is a Laserjet 5000, NOT a 5000N (which means it has an Embedded network card inside). If this is the case, you will need to add a JetDirect card into the printer. Then you will be able to install it to the network and print from other PCs.
On the other hand, if yours IS a network printer, you will merely need to install the printer to your network.
1) Plug you network cable into the printer.
2) Power the printer on.
3) After the printer comes to READY, wait for about 3 minutes.
4) Go to the printer's onboard menu and scroll to INFORMATION and select that menu.
5) Scroll down to "PRINT CONFIGURATION PAGE".
6) On the Config Page, look for the Embedded JetDirect page, and look in the left column for IP Address. It should be from your network.
7) Look next for Configured by: DHCP.
8) If you go to a PC that is on the same network, type the IP address for the config page into the web browser address window and press Enter key. You should see your printer "Laserjet 5000", and can from here do all knids of settings if you choose.
You will need to install the driver on each PC, or install the driver onto the network server as well.
May 01, 2010 | Office Equipment & Supplies
HOW TO SCAN THE DOCUMENTS IR4570 TO P.C ????
On the device you want to chose the SCAN option and set it to ONLINE.
You then need an application that does TWAIN scanning and aquire image data. Set your scanner device yo "Canon Color Network Scangear".
A freeware product you can use to test is irfanview
You would otherwise need to do an aquire / TWAIN scan from MS Word or Adobe Acrobat (full/pro) or another software that does TWAIN scanning.
May 06, 2009 | Canon imageRunner C3100 Copier
Faxing with the Canon 3570 Image Runner
On the copier display screen is their a tab that says "send"? If not then you do not have the fax option installed. If you have the machine on your network, find out the IP address assigned to the machine and enter the IP address in the address bar of your Internet Explorer browser to access the machine settings from your PC. If you have a fax option you should be able to set it up from there.
Printdoctor
Dec 17, 2008 | Canon imageRUNNER 3570 Copier
Imagerunner 5000s scanning problem
run the network scangear utility from the start menu. Click "discover scanner", when the discovery is finished select your copier and then click apply.
May 28, 2008 | Canon imageRUNNER 5000 Copier
Canon Image runner 5000
Have the IP addresses changed ?
Is the copier set with auto IP ?
If either is Yes you will need to set the machine IP address.
Set the IP-Subnet mask-Gateway adresses
you can do this by pressing the additional functions button
( the* button That is in a circle)
then id management (bottom L/H col)
then network settings (2nd to top R/H col)
then protacol settings
then TCP/IP settings
Then change these settings to the desired settings
Then go to your computer and make sure the print driver has
the same settings
Go to your computer
Go to START
Go to CONTROL PANEL
Go to PRINTERS and FAX
Then either change or check settings or add a new printer
If you need further help please get in touch
thank you
Feb 20, 2008 | Canon imageRUNNER 5000 Copier
Ir 3300
i have an IR 3300 (used) i have given TCP/IP correct with machine and PC also. ping command is working properly and IR Machine also response from the host and also i'm success output (Printout) but can't scanning. I have scangear also tried but the messeage appear "the spacified IP address is invalid or scanner is not connected to the specified IP" but my IP address is correct. (both side) i know that after this my Machine will be online from System button but there is no software. i cant solve my problem
how can i connect my Machine from PC
Dec 18, 2007 | Canon imageRUNNER 5000 Copier
273 people viewed this question
k24674
jasbo
jasbo
