Question about HP 7210 OfficeJet All-In-One Printer
CARRIAGE JAM WILL NOT RESET AFTER CLEARING JAM
  • 1,218 Answers
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
Posted on Sep 28, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Scholar:
  • 53 Answers
Disconnect the USB cable from the back of the printer.
Now, First of all make sure there is no paper pieces stuck inside the printer. To take out the papers.
Take out the duplex-er ( A box at the back of the printer which has two buttons at the ends of it which you can press to detach it from the printer :- It is used for duplex printing ) from the back of the printer.
Once you take it out you can see the ROLLERS and the ROD which takes the printer page and rolls back to give you the out put.
If you see any papers stuck inside then take it out. Now
Take a lint free cloth and clean the rod and rollers. Try to move the rollers in clock wise or anti clock wise direction. If it moves fine Other wise hardware issue.
Now attach the Duplex-er back to the printer.
Now open the front door and move the carriage manually back and forth. If it is moving freely perfect follow the instructions given below. If it is not the printer hardware problem. Take out all the cartridges and using a lint free cloth clean them. Make sure when you are cleaning the cartridges do not touch the nozzel of the cartridge with the lint free cloth only the out side of the cartridge should be cleaned properly. put all the cartridges back into the printer. Now Reset the printer:-
To reset it.
Connect the printer power cord to the Wall Outlet or Wall Jack.
Make sure it is not connected to the Serge Protector or power strip.
Partial reset :-
Now on the printer itself. --> Press and hold the
# and 3 button at the same time. Now take out the Power cable from the back of the printer and wait for 20 sec. Now put the power cable back in the printer. Now release the two buttons. ( Note :- remember you need to hold down the # and 3 button the hold time )
(On the printer screen it should say Part nvm reset.)
Now try to turn on the printer and check if it shows the carriage jam option. If it works Perfect. If not then do this :-
Semi-Full Reset:-
Open the front door and take out all the cartridges from the printer. Now close the door.
# and 6 button at the same time. Now take out the Power cable from the back of the printer and wait for 20 sec. Now put the power cable back in the printer. Now release the two buttons. ( Note :- remember you need to hold down the # and 6 button the hold time )
( On the printer screen it should say Semi-Full rest )
The printer might shut down automatically or may be it won't. At this point Put the cartridges back into the printer and then turn on the printer if it was shut down.
or If the printer is on turn it off and then switch it back on.
The problem should be resolved up till now.
If still the problem Exist Call HP as the product has gone bad.
HP :- 1-800-474-6836 ( Tech Support )
Posted on May 06, 2010
I'm getting an error msg and can't print. It says please fix cartridge jam and hit enter. I can't find any jam. What do I do?
If there isn't a cartridge jam then it's probably a carriage jam:
However, I'm not too familiar with clearing a carriage jam. I just know that if your cartridges are not blocked then the carriage is likely at fault. You will need to Google this on how to fix a carriage jam.
Jan 24, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Hi, there is continous paper jam flashing light indicated at the printer (epson 600). i have checked but i found nothing jammed. i wounder i could be the reason. your support is...
Sorry - no solution, except to perhaps agree with the guy who says throw it out the window. I only wish I wasn't just on the first floor. This thing does more jamming than printing. It claims a jam when there is none. Infuriating.
Nov 06, 2010 | Epson WorkForce 600 All-In-One InkJet...
Paper jammed
Hi Good day!!!
Here are some steps to remove paper jam
1. Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands on the metal tools inside the chassis.
2. Pin down the exact location of the jam. The three hot spots for a jam are before a sheet completely leaves the paper tray, between the feed tray and the print carriage or between the print carriage and the output tray.
3. Take off the front paper tray. If the sheet jammed around here, you should be able to see most of the paper.
4. Pull on the sheet with both hands and steady pressure. Don't tug too quickly. You might rip the paper, leaving a chunk of it deeper in the machine.
5. Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Use the carriage access door to get at a jam further inside. You may need to move the print carriage out of your way to get at the jam.
7. Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Thank you for using FixYa
Don't forget to vote thanks!!!
Nov 05, 2010 | Epson WorkForce 600 All-In-One InkJet...
Continue to get clear carriage jam after opening door and clearing or moving the carriage in hp 4215xi
Click here for instructions on resolving carriage jams on the 4215xi. If you successfully complete these instructions and still have carriage jams, your printer likely needs service.
I am an HP employee. I do not represent HP on this site.
May 26, 2010 | HP OfficeJet 4215 All-In-One InkJet...
Carriage jam
You could try clearing the jam and then removing power from the printer altogether to re-initialize the printer. However, if that fails either the printer diagnostics chip has gone awry or you have a virus.
Oct 28, 2009 | HP Photosmart 4180 All-in-One Printer
Carriage return error does not stop.
there is a piece of paper jammed.Follow clearing paper procedure.If there is no paper jam push the reset button
Sep 28, 2009 | HP OfficeJet 7410 All-In-One InkJet...
PSC 2310
To resolve this issue please perform the steps given below.
Perform NVM Reset:
1.Disconnect the power cord without turning off the unit.
2. Wait 60 sec.
3. Press and Hold OK and Cancel buttons while plugging in the power cord into the wall outlet.
Aug 30, 2009 | HP PSC 2410 All-In-One InkJet Printer
Have a HP officejet 7310 with error message that reads "carriage jam" this occured after clearing a paper jam???
You have to make sure you have gotten all the scraps out, and if you put fingerprints on the clear strip behind the carriage, you will need to clean them off with a Q-tip.
Jul 03, 2009 | HP OfficeJet 7310 All-In-One InkJet...
170 people viewed this question
Seeker5211
Seeker5211
