Question about Marshall 15 Watt Guitar Amp
Mp3 How do you link in cd player to marshall amplifier.Do i need a specific cable
  • Marshall Master
  • 5,603 Answers
The problem is that a CD has a stereo signal and the Marshall is mono.
You could make a simple mixer cable with resistors as a completed cable is not something you will find easily.
Take three 1K resistors joined at one end and connect the open ends of those one each to the three terminals of a stereo plug that fits you CD player.
Connect a mono plug and cable with "hot" to the joined connection of those resistors. Connect the ground shield of that cable to the barrel connection of the stereo plug that one of the resistros is also connected.
NOTE: if you use the "line" output of the CD player, then use 10K ohm resistors instead of 1K.
Posted on May 06, 2010
I had this Amp for almost 4 years now, and suddenly got a problem a month ago. When I'm using it from clean sound it suddenly auto switch to distortion sound and vice - versa .
Normally that would be caused by a dirty footswitch jack or a broken (intermittant) cable on the footswitch itself. If neither of these is the problem, it will be a relay in the amp and will have to go in for service. Here's a link
http://www.marshallusa.com/service.asp
Oct 23, 2016 | Marshall Music
How to connect the foot switch.
Using the CORRECT footswitch for this model, you just plug it into the footswitch jack. You MUST use the correct one for the model.
Aug 05, 2011 | Marshall Amplification Marshall MG50FX 50...
I tried to use the Send as a line out on a Marshall MG50.It would not work and sometimes the sound would cut off when the cable was plugged in to Send.I've never had this situation with other...
Assuming that the amplifier has no other problems (till this one come up) and in case you don't use the "send" connector frequently, I believe that it's some kind of "dirt" in the connector. Switch of the amplifier and use a contact cleaner spray (available at any electrinics' shop) in order to spray in the connector. Plug - in and out many times a free male connector into the female one for the contacts to clean up. Allow some minutes the amplifier to dry and check the results.
Also make sure that the cable that you use for "send" audio is working. In case of a short-circuit cable you may come to the same problem.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Jul 04, 2011 | Marshall Mg50dfx 50-Watt Combo Guitar...
I have an MG50FX amplifier that is less than half a year old and in the middle of playing the distortion will fade to the point of disappearing and will then suddenly come back in the middle of a note. ...
Many things can cause this... A COMMON problem is broken solder joints near potentiometer where they attach to the circuit board. Look for bad solder joints and also cracks in the circuit board.
Apr 04, 2011 | Marshall Amplification Marshall MG50FX 50...
How do I correctly connect my mg100hdfx head to a marshall stereo cabinet? Do I connect cables from both outputs from my amp to both inputs in my cabinet?
the second jack is usually for a second cabinet.
http://www.marshallamps.com/downloads/files/MG100%20hbk%20Eng.pdf
here's a link to the manual. to be sure.
if it has effects on it, you may require two cabinets for the stereo effects. in the truest sense of stereo is what i mean.
Feb 27, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
Marshall jvm 410h i'm getting loads of feedback when i use od1 or od2 orange or red mode
Dampen the strings of your guitar. If feedback disappears, then you need to move the amp so it can't resonate the strings of the guitar. OD1 and OD2 WORSEN the chances of the feedback into the strings. When this occurs you can often see the strings vibrating without the player picking them.
Nov 22, 2010 | Marshall Amplification Marshall JVM Guitar...
I got he Marshall MG100FX amp with 2x 12inch speakers. The potmeter of the master volume doesn't work anymore. Do you know the specifications of this potmeter? Armin, delta.design@usa.net
That should be a 320K pot. <br /> <br /> Here's a link to the schematic. <br /> <a href="http://www.ampix.org/albums/userpics/10003/MArshall_MG100DFX.pdf">http://www.ampix.org/albums/userpics/10003/MArshall_MG100DFX.pdf</a> <br />
Aug 26, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall 15 Watt Guitar Amp Logo
145 people viewed this question
Top Marshall Music Experts
matt martin
matt martin
Leonard Jeffrey
Level 1 Expert
rjivaro
Are you a Marshall Music Expert? Answer questions, earn points and help others
