Question about Nova Development Photo Explosion Deluxe for PC
Photo explosion 4.0 project studio. When I create
Photo explosion 4.0 project studio. When I create a project and export to jpg or pdf the file is black when I try and open it. No error message.
  • ljjgriffin May 06, 2010
    Sorry, my operating system is XP
    Photo Explosion Project has its own file extension. Once you create your project you can export it to jpeg or pdf. When I do that the exported files are all black.
    I will try your suggestions when I get home tonight.
    Thanks!
  • 187 Answers
I kind of doubt this is your problem, but try and save the file by using the "save by a different name option." Then click options and slide the file size to large. Make sure you have your color setting set to rbg, not cymk. The channel should be set to 8 bits, not 16. I am not sure where that selection would be made in 4.0, but jpgs are not compatible with 16 bit channel. If you can't find the setting, check the help file.
Two questions: 1 Can you open any pdf and jpg files in Photo explosion, and 2 can you open the files you have created in photo explosion in another program?
If you can't open any jpgs/pdfs with any program, the problem is probably with your operating system. If the problem is only with photo explosion created files, and they can't be opened in any other program, it may be the "plug in." That is the piece of software required to produce the file. A viewer is also required. If you can open the jpg in another program, that would indicate photo explosion. The plugins that are loaded into the program should be listed, possibly under tools. You can try to update/reload these.
You have not indicated your operating system. This is important to correctly answer more complicated issues. For instance, if you have Vista 32/64 bit, your software has to be compatible and set to the right version. Because Vista is prevalent, I looked to see if it is compatible. Unfortunately, Nova recommended buying an update for the 32 bit version and had no info on the 64 bit. Somewhere on the photo explosion box there should be a small label telling you what it is compatible with. I hope that if this was not helpful you will leave me more info and answers to the above by writing a comment. I can get back to you with more specific advice.
Posted on May 06, 2010
Whant to take a photo of myself via webam to pdf format
There are a couple of things you can do to create a PDF from an image file. If you have access to Photoshop just open the file in that and save as a PDF. If you don't have photoshop you could try a free online jpeg to PDF converter (I am not affiliated with this co but a Google search for "free online jpeg to PDF converter" brought up this top result, http://www.convert-jpg-to-pdf.net/ ) The other way is to simply paste your jpeg image file (or insert picture/media file) into a doc or Word document and save it as a PDF. Hope this helps
Apr 16, 2013 | Computers & Internet
Can i use a picture saved in a file for my wallpaper
It needs to exported from the PDF as a image file like jpg, bmp, png... but to export it you may need Adobe Acrobat not just the reader. PDF files tend to locked. You could also capture the picture from the doc with print screen, but you will loose the original resolution.
Once you have the file exported, just open with Windows Picture viewer and set as backbround.
Jan 03, 2013 | Dell Latitude E6410 Notebook PC - Intel...
My files are created in adobe pagemaker now I want them to convert in jpg or pdf format how?
1. Save the Pagemaker document. If you don't do this before proceeding, a pop-up box will remind you.
2. Go to File>Export>Adobe PDF. A dialogue box of PDF options will come up.
3. Determine what you want to use the PDF for. If you are exporting for a specific print job, the printer will give you Distiller settings. Otherwise, in Job Name, just choose the settings that most closely meet your requirements: High Quality Print for a printout, Smallest File Size for a document that will be viewed online.
4. Click "Export." An "Export PDF As" dialogue box will pop up. Choose the folder in which you wish to save the PDF, and name the file. Check the "View PDF" box, so the PDF will open after it has been created.
5. Watch the dialogue box. It should show that Distiller is creating the file. When finished, the PDF document will open.
Good Luck!
John Vickers
Aug 13, 2011 | Computers & Internet
I can't convert file PDF to JPG how i can do ? you can help me?
Just do file > export > image > jpg as in the image bellow: 6_20_2011_5_53_32_pm.jpg
Or this link might help: http://www.makeuseof.com/tag/6-ways-to-convert-a-pdf-file-to-a-jpg-image/
Jun 17, 2011 | Adobe Acrobat 6.0 Professional for PC
When I try to save a project, I get"photo explosion has quit working". It doesn't save and goes back to project studio opening. I run windows 7. I have uninstalled and reinstalled Photo Exp'n...
Welcome to Fixya. Have you tried running the software in Compatibility Mode? Depending on your version of Windows 7, you may have the ability to run it in Compatibility Mode. Try right-clicking on the Photo Explosion shortcut that is on your Desktop. Then, go to Properties from the pop-up menu. Then, select the Compatibility tab. On that tab, put a check next to "Run the program in compatibility mode for:". Then, select Windows XP SP2. Click on the OK button to save this setting. Finally, try launching the program again.
If you have questions please let me know. Thanks for using Fixya.
Mar 21, 2011 | Nova Development Photo Explosion Deluxe...
Export:error:real time c:\users\owner\appdata\local\microsfolder\render\my movie 848e009f\alternate\render\my movie 848e009f\dvd\studiosequence\temp' Help - what does this mean? What should I do?
Hi and Welcome,
If you are experiencing Export Errors using Studio, the following FAQ should help:
1. UPDATE TO THE LATEST PATCH:
Click here for the latest Studio 12 patch
There is no patch available at this time for Studio 14
2. ENSURE BACKGROUND RENDERING COMPLETES:
Allow the green bars that appear over clips that have had filters, transitions or other effects added to complete before going to the Make Movie stage.
3. ALWAYS REINCODE ENTIRE MOVIE
If after installing the latest version of Studio, the Export Error persists and you are attempting to create a DVD, then in Studio click on the Setup pull-down menu and select Make Disc. On the top portion of the Make Disc tab make sure there is a check in the box for the setting "Always re-encode entire movie", then click the OK button. Create the DVD again.
4. DELETE AUXILIARY FILES
Delete the auxiliary files before rendering. To do this, go to File >> Delete Auxiliary Files. This will bring up a window to chose which auxiliary files will be deleted. Select the option to delete the files for the current project. Once this is done, try to output the project.
Oct 12, 2010 | Pinnacle Studio Ultimate 12 for PC
I have images in .ppt format that I would like to upload to facebook. Is this an acceptable format?
.ppt is the extension for PowerPoint presentations, so it's not really an image format. This is why you willnot be able to upload it on Facebook.
However exporting the images from the .ppt is very easy! Just follow these simple steps and you will have your images exported and ready to be uploaded.
To export your PowerPoint slides to other file types (BMP, WMF, JPG, PNG, etc)
  • Open your presentation and choose Save As from the File menu.
  • In the Save As Type dropdown listbox, choose the file type you want to save.
  • Give the file a name and click OK.
  • PowerPoint asks whether you want to export just the current slide or your entire presentation. The question is worded a little oddly, so read the message carefully before clicking Yes or No.
When you save the entire presentation rather than a single slide, it uses the name you give it, makes a folder of that name, then creates the exported files in that folder, giving them names like Slide1.jpg, Slide2.jpg and so on.
Mar 29, 2010 | Computers & Internet
How to convert jpg to pdf file
IMPORT jpg file in pdf, that means create new PDF and then insert jpg. picture-s. Save your file and that's it. probably youll get that at adobe, so find their software, couse reader in for reading such files.
Nov 30, 2008 | Computers & Internet
Exporting as esp
You can actually do a SAVE AS and select .eps as one of your file formats. You also have the option if you have photoshop to export out as a .jpg then open it in photoshop and resave the file
Jul 12, 2008 | Adobe Acrobat 4.0 Full Version for PC
Cannot install photo explosion delux
Kindly give a brief discription of your problem...
1.Are you getting any error message?
2.Compatibility Issues?
3. Have you updated your computer?
4.Does your computer meets the Requirements for the Program?
Kindly give a feed back to Improve my statistics and to see If it was helpful for you...
Thanks and Regards
Mar 27, 2008 | Computers & Internet
Nova Development Photo Explosion Deluxe for PC Logo
325 people viewed this question
Top Nova Development Computers & Internet Experts
David Payne
David Payne
Computer Links
John Hong
John Hong
Are you a Nova Development Computer and Internet Expert? Answer questions, earn points and help others
