Question about Maytag Dryers
I have a adirmal dryer model ade7000ayw. it is a electric dryer. its seem that it takes a long time to clohes like towels, jeans, and etc. Its turn on the regular heat but it seem it take 120 min before my clothes are dry. Any suggestions?
    Problem Solver:
  • 19 Answers
Sounds like the lint tray is full or clogged
Posted on May 06, 2010
Why does it increase time to 3H when there are 8 minutes of drying time left?
From what you're describing, there could be a problem with the moisture sensor circuit. On the front of the lint screen holder(you have to stick your head in the dryer and look back, you will see 2 metal strips. These are the sensor bars. When wet clothes brush against them, it lets the computer know that the clothes still have moisture in them and about how much. As the moisture decreases, the electrical signal changes and the computer counts down. The time is JUST AN APPROXIMATION. However, if the sensor bars become shorted, or if there is a problem with the wiring of the sensor circuit, or if the main control board is defective, these will produce the problems you're having. One important thing to note: Samsung dryers, when using the sensor-dry settings, like to have large loads in order to work properly. And, try to have like items with like items(jeans with jeans, shirts with shirts, towels with towels, etc) If you have *small, mixed loads*, use the timed-dry settings for best results.
Also, check inside the lint screen holder with a flashlight(with the lint screen removed) for a large build-up of lint. If there is a significant amount of lint, you could have a partial blockage in the dryer vent tube or wall causing restricted airflow--this will cause longer drying times because the hot air, containing moisture, can't exit the dryer properly. THE RULE OF THUMB ON ALL DRYER VENT TUBES IS: **KEEP AS SHORT AS POSSIBLE, NO SHARP BENDS OR KINKS, STRETCHED OUT(if using the cheaper foil or plastic accordion type)**** Remember, gentle bend coming out the dryer, gentle bend going into the wall. The airflow coming out of the vent(outside the house) had better be close to what's coming out of the rear of the dryer, otherwise there is some type of restriction in the air path that must be removed.
Aug 20, 2015 | Samsung DV422EWHDWR 7.2 cu. ft....
I have a LG Electric Dryer DLE5932W. When I run it on any of the settings in sensor dry the dryer turns off before the clothes are dry and you have to run it multiple times to get a load dry. Then if you...
this could be operator error please hear me out...... when wash bath towels you also put in wash cloths and hand towels .... there is a sensor in dryer drum shroud in front of lint filter to metal silver strips when the clothes are tumbling they sweep across this sensor telling the dryer heat to stay on and continue to dry.... if th small wash cloth sweeps it first before the bath towel then u get the same results as your describing just like if you were waqshing colors load like cotton tshirt and blue jeans the tshirt is going to dry way faster than blue jeans so if the tshirt sweeps that sensor first the dryer going to shut off we have to sort our clothes to thickness ans same size articles just try it once i bet your clothes are dry when cycle completes
Jan 31, 2011 | LG DLE5932W Electric Dryer
I have the duet whirlpool gas dryer - model #GGW9200LW1 and the barrel is making a lot of noise. It seems like one of the inside little cap is loose and the clothes aren't drying. Its taking too many...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Dec 29, 2010 | Dryers
My whirlpool duet dryer doesn't get jeans or towels dry
jeans and towels are very thick, they will take more time to dry.
Apr 07, 2010 | Dryers
Dryer taking 3 hours to dry jeans and towels
Here is a tip that I wrote that will give you some things to check out...
http://www.fixya.com/support/r4312805-dryer_maintenance
heatman101
Apr 05, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Whirpool dryer takes 3 hours to dry jeans or towels.
Most likely your heating element has partially failed. Some dryers have two separate resistance heaters in them. If one fails what you are describing can happen. If you have the tools and are willing to take it in it's not that bad a job. You have to take the cover off the dryer to see it, then it is two bolts. Any appliance repairman can handle this easily.
Mar 22, 2010 | Whirlpool LER5636P Electric Dryer
Dryer is taking too long to dry clothes, even on AccuDry setting for Jeans/towels - it still is heating, just not heating enought to dry clothes, I have been doing two cycles at least for a very small...
Your house vent is restricted causing the long time to dry complaint.
Please clean the entire vent to the outside.
Also make sure the vent behind the dryer does not get smashed when the dryer is pushed back to the wall.
Jan 19, 2010 | Whirlpool GEQ9800P Electric Dryer
What is the best setting to dry jeans on a kenmore 9000 electric
Use Auto Dry for most things and vary the "dryness" level to more or less depending on the thickness of the material you are drying. Auto is most efficient and will adjust itself for finish time.
Auto dry and select "more dry" before hitting start, for jeans or towels.
Aug 28, 2009 | Kenmore Dryers
Heat element(spring) does not stay on long enough
you found the problem yourself, yes its a thermostat, replace this, however the heat should stop on longer than it does, but please note this is a part that should cut out & reset itself, if needed to prevent fire or overheating, this part has gone what we call tired, do not bypass anything on the appliance and use it, this can be dangerous and is against health and safety law etc before continuing to use the dryer check all pipes for blockages as restriction of air flow causes the problem you have, so to prevent another faulty thermostat clean out properly.....
Sep 28, 2007 | Dryers
Dryers Logo
134 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
