Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
My 4 yr old l-120 mower is stalling after running for 2 hrs. need to chock it to keep it going.nxt day wouldnt even start had to spray starting fluid in carb to start it..never had this problem b-4..please help also changed fuel filter in winter cause i use it yr. round.
  • 198 Answers
Make sure the bolts on the head are tightened---if it's sucking in too much air you'll have those symptoms
Posted on May 07, 2010
Need s step by step start up.New owner of old machine 5521bbc
put machine in neutral pull the chock all the way out put throttle full open push in brake pedel all the way turn your key switch to start it if it hasnt run in a long time probably need to rebuild the carb if donsnt start try sqiurting some starting in the carb if it starts and dies it means carberator needs rebuilt you try to star it again this time before it dies keep it running with starting fluid just shoot short squirts in carb to keep it running do this for only 2 minutes if you keep doing it you will damage motor try that and see if it will run
Sep 15, 2014 | Garden
Homelite very hard starting prime 10X full choke model UT32651
Make sure your fuel mix is fresh and of the right gas-oil ratio. Today's pump gas has Ethanol mixed with the gas and can go bad in as little as 30 days. this stuff is terrible to run in small 2 cycle engines. A lot of loggers I know buy Ethanol free gas for their saws. Also do not ever use starting fluid to start a 2 cycle engine ! What happens is the Either washes the cylinder wall of oil and now you have a scored piston and/or cylinder
Apr 03, 2014 | Homelite Garden
Fuel pump wont work 1990 mercury sable station wagon car turns over but wont start it stalled and wouldnt start again but a few hours later it started briefly and i made it about 500 yards and it died and...
fuel pump bad or fuel pump relay bad. Likely fuel pump.
Spray some starting fluid in air intake and see if it starts. If yes, replace fuel pump in fuel tank. drop tank for access. About a $250 repair at shop. call around.
Sep 04, 2009 | 1990 Mercury Sable
I have trouble initially starting my MTD Yardbug mower. Once going, the engine runs great, but it seems like when the throttle lever is set to choke, it doesn't actually choke. I usually have to either...
Sounds like your throttle cable is out of adjustment (i.e. when you put the carb in choke position is doesn't actually go into choke).
Aug 24, 2009 | Garden
Yard machine mtd 123cc mower stalls after starting it runs for a few seconds and then stalls. Previous to this it only ran on choke but when you took the chock off it stalled also. Now it stalls even when...
dirty gas. the fuel bowl likely has junk in it which plugs the jets as soon as it starts. you may get luck just emptying the carb bowl but a good carb clean and new gas will do the trick. (dump out the old gas
Aug 16, 2009 | Mtd 22" Yard Machine Push Mower
Car will not start 1.416v polo yr 2000 old shape
dealer only factory immobiliser playing up
May 26, 2009 | 1997 Volkswagen Jetta
Poulan 6.75 Lawn mower will not start
Remove spark plug, clean and dry. Replace plug. Remove air filter. Spray WD-40 into carb opening; one second blast. Turn over engine, (pull handle). Engine should start briefly and run for 3 seconds.  If not, you are not getting spark to spark plug. If engine starts, you have a dirty carb and you can buy a rebuild kit from manufacture.
May 02, 2009 | Poulan Pro " Pro" Self Propelled Mower
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
235 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
