Question about Epson Livingstation LS57P2 57" Rear Projection HDTV
Hey Just made a comment on your problem. I know how frustrating it is.... Just wanted to pass this to ya: Hey, Very similar problem with my LS47P1. Here is the scoop (I work for a retailer which carried these and I bought one) - Epson has admitted that there is a flaw in the engineering of manynewer bulbs (that is ones that were made after the initial release ofthe LS47P1) - Apparently the 3 little metal contacts on the lamp tend to get"squashed" down over time once the lamp has been installed (this takesa little while, like 2 weeks to a month after the replacement lamp isinstalled). - The contacts no longer make a connection with the inside TV sidecontacts and the electrical charge needed to ignite the gases in thelamp does not get through (like 9 out of 10 times) - You can get it to work temporarily by pulling out the lamp andcarefully pulling the inside contacts upward to make a betterconnection inside. NOTE: I did this for a while everytime it didn'twork and after a while the pieces of metal became worn and would breakoff. So do this only if you have an extra lamp handy or you're on yourlast witts (as I was). HERE'S WHAT TO DO: 1. Call Epson of America (I am in Canada, but they are the ones to talk to anyway) 2. Tell the first person who answers the phone to transfer you to theLivingstation (rear projection) department. If they start telling youthat it will take like 48 hours and they will call you back tell them"NO! put me throught now!" 3. Tell the real tech expert your issue. 4. Get him to send you out a non-defective lamp (these ones have been retrofitted to not get "squashed" in the TV. 5. Put new lamp in and cross your fingers.... Hope this helps. Mark
Where is the projection lamp in a Livingstation and how do I get it out?
Posted on Apr 10, 2008
SOURCE:
Hey How yal dining Just need to let ya know u do you I guess
Dining is good but the guess is incorrect, you need to dine with only one guess and then yal know ya guess is dining on yal hey how.
May 13, 2016 | Furniture
I have a 2000 olds bravada it starts but stalls right away?
hey sorry I commented on your other post and the link I wanted to share with u didn't show
www.diy-gm-security.com
http://www.diy-gm-security.com/ Do It Yourself GM Security bypass
Oct 20, 2014 | 2000 Oldsmobile Bravada
You **** i dont know what happened to your site but i cant get no help at all and its frustrating
click onto fix ya . com and it will take you into the fix ya solutions for everything.
Feb 13, 2011 | Dodge Neon Cars & Trucks
Keys ??????
you have to get the key from the dealer who will program it for you.
Jun 12, 2009 | 1996 Audi A4
0000 passcode mismatch
the traditional 0000 passcode did not work with my new SA505, being frustrated I decided to just start at one and put four 1111 in, and low and behold it worked. I now can pair it and it works great, Just a lucky guess but hey it worked.
Jun 11, 2009 | Radio Communications
Remounting a rifle scope, Luepold 3X9 with Luepold rings
hey jerry when ya renount a scope ya just want to tighten all the screws evenly when ya do this ya want to start with right front then left rear then left front right rear you do this till its as tight as you can make them without striping screws when your done you should have even space at all the rings good luck and i hope this helped ya
Oct 30, 2008 | Leupold ® Rifleman® 3-9x50 mm Scope
Ps3 call of duty 4
Hey... Try my suggestion on
http://www.fixya.com/support/t455268-ps3_call_duty_4
and also check out my comments. Good luck!!
Mar 19, 2008 | Sony Playstation 3 (PS3) Console
Epson Livingstation LS47P1 won't turn on
Hey,
- Epson has admitted that there is a flaw in the engineering of many newer bulbs (that is ones that were made after the initial release of the LS47P1)
- Apparently the 3 little metal contacts on the lamp tend to get "squashed" down over time once the lamp has been installed (this takes a little while, like 2 weeks to a month after the replacement lamp is installed).
- The contacts no longer make a connection with the inside TV side contacts and the electrical charge needed to ignite the gases in the lamp does not get through (like 9 out of 10 times)
- You can get it to work temporarily by pulling out the lamp and carefully pulling the inside contacts upward to make a better connection inside. NOTE: I did this for a while everytime it didn't work and after a while the pieces of metal became worn and would break off. So do this only if you have an extra lamp handy or you're on your last witts (as I was).
HERE'S WHAT TO DO:
2. Tell the first person who answers the phone to transfer you to the Livingstation (rear projection) department. If they start telling you that it will take like 48 hours and they will call you back tell them "NO! put me throught now!"
Hope this helps.
Mark
Jan 25, 2008 | Epson Livingstation LS57P2 57" Rear...
I need a code for a sanyo tv
Hey I was searching the internet for the Sanyo code for the One For All URC4110 code and ran into your post.. I believe you're looking for the same. Well, after some searching I found it so I wanted to let you know... It's 0154
Nov 25, 2007 | GE JASRM24912 Remote Control
Epson Livingstation LS57P2 57" Rear Projection HDTV Logo
169 people viewed this question
Top Epson Televison & Video Experts
Steven
Steven
Level 1 Expert
janman
Are you an Epson Televison and Video Expert? Answer questions, earn points and help others
