Question about Singer 5050 Mechanical Sewing Machine
The bobincase springs up giving no stitch in singer inspiration
I have a singer inspiration model when i sew the bobincase springs out gathering thread in and around it
    New Friend:
  • 191 Answers
Try buying a new bobbin case, it probably was damaged by jumping out of position.
Posted on May 07, 2010
Why won't my sewing machine produce a zigzag or decorative stitch?
sometimes u have to sew on scrap for a few stitches for the computer to recognize the stitching has been changed. Then it might break through Hope it works for you
Aug 25, 2014 | Singer Inspiration 4210 Mechanical Sewing...
How to change stich to long stich for gathering?
http://www.singerco.com/uploads/download/3e3e5558857ed68836712ac8545abb48178772a5.pdf is the manual for your machine; look at p. 27. You want stitch 00, and then increase the stitch length with the up/down buttons on the control panel.
p. 24 of the pdf covers adjusting the top tension of the machine; you'll have an easier time of gathering if you reduce the top tension about 1-2 number setting.
May 29, 2014 | Singer 5400 Sew Mate 60-Stitch Sewing...
Stitching keeps gathering while I'm sewing
#1 cause of puckering is a tension/threading problem. Make sure the thread/needle matches the fabric type too.
Dec 14, 2012 | Singer 3116 Simple
Can't find straight stitch setting on singer inspiration model 4228
do you have a manual? if not
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 4228) & click search
Apr 23, 2012 | Singer Inspiration 4228 Mechanical Sewing...
How to set the machine to straight stitch
Go to the home page
My machine is a Singer Inspiration 4210. My stitch on top looks fine at first glance but it is birdnesting underneath. What should I do to correct this?
Check your top tension. It sounds like it may be too loose or the bobbin tension may be way too tight. Most likely it is the top tension that is incorrect though. The TOP tension effects the bottom side of the stitch and the bottom tension effects the top. If the top tension isn't tight enough it won't draw the thread up through the top side taunt enough and the excess underneath makes a big loopy mess.
Jul 29, 2011 | Singer Inspiration 4210 Mechanical Sewing...
I have the singer 7442 and i cannot figure out how to get the baste stitch for gathering material on a flower girls dress. I've tried everything and there's nothing in the manual, can you help with this?...
Normally to gather fabric, you select the regular straight stitch, turn the stitch length up to maximum (4 or 5 usually), and stitch two rows of stitches, one at 10mm from edge and one at 20mm from edge.
Then gather by pulling the bobbin threads (underneath ones) from each end to gather the fabric. If doing lengths of more than 1 metre, then stop, leave long thread tails, and start a fresh length of gathering threads to avoid gathering long lengths of thread which might break on you.
If your machine has a basting stitch it might look like " .___.___.___" on the dial however, I've never been that happy with machine basting for things like attaching slippery fabric to underlining, I've always done it with needle and thread to keep the two layers matching and not stretching/slipping. For example, stitching a piece of chiffon to a underlayer of satin, even pinning carefully, these two fabrics will slip under the machine foot so I'd always do it by hand.
If you have masses of fabric to gather, sometimes what is quicker is doing a large wide zig zag over a length of perle cotton (heavier than thread) at the 15mm seam, don't let the needle pierce the cotton though. Then you can gather the fabric along the perle cotton.
Sewing machine instruction manual often assumes a knowledge of sewing techniques that you may not yet have. I have the Vogue Book of Sewing on my shelf and refer to it often. Or Singer do a good range of sewing books too, its worth investing in a good reference book.
I also love www.patternreview.com, this is such an awesome website for dressmakers/sewing enthusiasts and you will find loads of helpful tips here.
Hope this helps you a little.
Apr 16, 2011 | Singer 7422
When the needle comes down in it hitting the metal cylinder that the bobbin sits on. The diagram in the instruction book doesn't show me how it's supposed to go, my model is a singer inspiration 4206, in...
You may just have a bent needle or a burr on your needle plate. Is the machine set to a straight stitch? If, not do so. Check these first. I doubt that it is the timing.
Sep 07, 2010 | Singer Inspiration 4206
Singer 5050 Mechanical Sewing Machine Logo
166 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
