Question about AEG D2100-4 Electric Double Oven
I have dropped a cup onto my ceramic Zanussi hob, is the slither of glass that came off able to be repaired ??
  • 269 Answers
Just to clarify something, is your hob above a double oven D2100-4 because that is only telling me about your oven the hob will have its own Mod. no. But any crack to the glass on any Hob can weaken the glass and really should not be used due to the weight of Pots on glass if the glass did break it could be quite dangerous with all the electrics below.
Hope this gives you some help in the matter.
Good Luck.
Posted on May 06, 2010
How can you remove burnt plastic from electric hob oven
from the ceramic or glass cook top
will be a slow process cant scratch the top
hope its not tuppa ware
it will smoke
plastic scraper or solid plastic spatula
with hob off .. boiling water little at a time
may have to low heat the hob again
Apr 16, 2017 | Ovens
What products can I use to clean my aeg hg795540xb gas glass top hob? The instructions say neutral products and no hob scrapers
Please, follow this link:
http://www.amazon.co.uk/AEG-Electrolux-50296742005-Ceramic-Cleaning/dp/B002LJDJ7Y
25358477-ou0pu244fjwiiyewsm5u145c-2-0.jpg 6. CARE AND CLEANING WARNING!
Refer to Safety chapters.
6.1 General information
• Clean the hob after each use.
• Always use cookware with clean bottom.
• Scratches or dark stains on the surface have no effect on how the hob operates.
• Use a special cleaner applicable for the surface of the hob.
Dado
Jan 06, 2015 | AEG Ovens
Zanussi hob. Hot warning "H" remaining on permanently for one plate. Tried issolating power and back on- no joy.
It's a bad temp sensor on the surface element. You'll need to replace the whole element. If you have a glass cooktop, it's best to have a qualified repairman change it out for you.
Nov 25, 2014 | Ovens
Cannon Cambridge glass top
This would require a new hinge for the lid as they have an internal spring offering the resistance to keep the top in the up position
Apr 06, 2014 | Ovens
Rented apartment and zanussi ceramic hot is displaying letter L on the hob plate control. There are no manuals around but unit looks new.
The "L" indicates that the child safety lock is on.
You haven't stated which exact model you have, but on most Zanussi's you turn the hob on and then press and hold the + and - buttons together until the display changes from "L" to "0".
Note that on some models you must do this every time you turn the hob on, on some others the lock can be disabled.
Jun 16, 2011 | Ovens
With a new Ceramic Glass Induction Hob EHD68210P which coloured wire is the neutral? Brown, Black, Blue or Green.
Standard wiring colour:
Active - Red or Brown
Neutral - Blue or Black
Earth - Green/Yellow.
Best thing is to call an electrician as you do not want to damage your appliance.
Nov 04, 2010 | Electrolux Ovens
My glass cermamic cooktop is burned, i mean literally. Its milk stains or sauce stains all over it. And i cant remove it. There are dark brown stains on it. Please help me
try using a ceramic hob specific scraper to removed the burnt on bits then use a ceramic hob cleaner.
Can you let me know what country you are in and I can send you alternative links.
The following link are for the uk.
https://www.bosch-eshop.com/eshop/bosch/gb/ceramic-hob-cleaning-1.htm
311299 is the most cost effective as it contains cleaner and scraper.
Aug 21, 2010 | Ovens
Zanussi zbf360 the glass on the top (HOOB)has
It depends on the make and model, that number you quoted is for your slot in oven,the hob is a seperate unit.They could cost more than the hob is worth but if you get the model number and relog the question maybe we can help.
Hope this helped.
Apr 28, 2010 | Zanussi ZBF360 Electric Single Oven
I need replacement control knobs for my hob-can
In your browser bar type in-------WWW.SERVICEFORCE.CO.UK.
Follow the links in the drop down menu, and you should be able to order the parts you require.
Please rate my solution.
Thanks.
Nov 07, 2009 | Zanussi ZBF360 Electric Single Oven
Samsung PKG001 Stainless steel Single Oven and Ceramic Hob : Hob working ok oven light comes on and fans work ok no display on oven and no heat any suggestions
Had exactly the same problem and just had the samsung engineer out (as it was only 3 months old ) who replaced the thermostat. all is now working ok
Jul 15, 2009 | Ovens
AEG D2100-4 Electric Double Oven Logo
341 people viewed this question
Top AEG Ovens Experts
ashburton
Sal De
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
