Question about Polycom VSX7000 Videoconferencing System (VSX-7000, VSX 7000, 7000)
VSX 7000 main Camera is not working
My policom VSX Main Camera is not working.It only shows a blue screen.
SOURCE: can't get to the home screen
Polycom identified a FORCE SVideo feed option for the 7000 series.
You must hold the pound key down on the remote when turning on the unit to force an s-video feed out…
Just an FYI as there is ONE VSX7000 Polycom unit we have that only has SVideo output and when it shipped back from the factory they had been using a remote configuration utility and did not set the display up.
It will probably NEVER happen again but just an FYI.
Posted on Mar 04, 2008
I've just solved that problem in the VSX 7000 of my girlfriend's Job.
Your VSX7000 has at least 4 video outputs, 1 for VGA and Supervideo 1 and Supervideo 2.
Firstly you should try VGA connector, because the main menu may be there, so you could change the configuracion.
If you can't see main screen in any of the output connectors you'll have to use the http tool.
In your internet browser enter the camera IP address, and you'll get the Web Interface of the VSX7000.
It will prompt you for user & password, the default options are "Admin" and your VSX7000 serial number (14 digits) you can find this number under the camera.
Once you're in the Web Main Menu, click on Site Map. There you can choose what you want to see in the screen of Monitor1 (My menus are in Spanish, maybe your menu says something like "screens" but I'm sure you'll find it)
If you choose Monitor/Screen 1 as Svideo, and select it as output for Local, Remote and Content you should see the Main Menu after the VSX7000 Reboots.
I hope it would be useful for you, if you have any problem with this let me know... This VSX7000 is working fine now, so yours should work!
Posted on Sep 16, 2008
SOURCE: polycom vsx 7000
no the power supply is propreitory( has multiple voltages) & is not advisable, u could blow up ur expensive confeencing equipemt.polycom has designed it in that manner!!
Posted on Feb 08, 2009
  • 5 Answers
SOURCE: VSX 7000 doesn't come on
If you still have an issue and the unit is out of warranty , give us a call at 415.637.9989 and we will see what we can do. DAVID
Posted on Apr 21, 2009
ariesguy22
SOURCE: vsx 8000 "visual concert vsx" screen
This worked for me thank you very much
Posted on Oct 18, 2012
Blue screen
Pls check the output mode of the VSX 7000
Apr 09, 2014 | Polycom VSX 7000e Video Conference
Videocon TV model No. CTVVBN14MGF-CNA goes in stand by mode after 5 minutes. Please suggest me a solution.
There should be some loose solder terminals at its main power regulator section. Resolder all the suspected solder terminals there, by applying a little more solder. Check the solder terminals at the horizontal output stage too. The fault is with loose solder terminals itself.
Sep 07, 2013 | Polycom VSX7000 Videoconferencing System...
Blue screen
turn off the video. Then grab and hold the camera, and turn it on. release camera after few seconds. For me it works :)
Jan 31, 2011 | Polycom VSX 7000 Video Conference
My VSX 7000S does not recognize the microphone. It is connected to VSX\r\ncamera by the brown RJ11 cable with ferrite end to the camera but no sound is picked up and system status indicates "no...
You need to go into the audio settings via
Admin Settings
Audio Settings
and make sure Enable Polycom Microphone is checked off.
Reboot and see if your microphone is recognized.
Jan 13, 2011 | Polycom VSX7000 Videoconferencing System...
Feb 14, 2009 | Polycom VSX 7000 Video Conference
Forgot the polycom VSX 7000 password - how to reset
The polycom didn't allow for numbers, only letters.....
How do I do password recovery in this case?
Dec 17, 2008 | Polycom VSX 7000 Video Conference
Help me
Power on unit, press and hold * key on remote takes a few minutes but spinning polycom logo will appeara and a minute or two after that the menu screen comes up. Main output is configured for S-video, your seeing a 2nd monitor output, doing above will switch the VGA to be main output.
Jan 16, 2008 | Polycom Small ClassStation VSX 8000...
Can't get to the home screen
Sep 19, 2007 | Polycom VSX 7000 Video Conference
Polycom VSX7000 Videoconferencing System (VSX-7000, VSX 7000, 7000) Logo
316 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
David Burbee
David Burbee
TEKUSER
TEKUSER
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
