Question about Kodak EASYSHARE 5100 All-In-One Printer
The printer has not been used very much but the black ink is not transferring onto paper. The cartridge is full and I have tried a new and different cartridge. The colour cartridge works fine.
  • 30 Answers
When you say not very much, it might be that the ink had begun to harden and dry out due to lack of usage. You may have to buy new ink, but maybe try running the cleaning utility through the printer utilities to see if it resolves the issue.
Posted on May 06, 2010
Black ink leaked on inside of printer.
try to replace the defective cartridge by a new one and see printing test result
Nov 18, 2011 | Canon PIXMA iP6700D InkJet Photo Printer
My printer will not print. I have cleaned it, and you can just barely see what I have printed. Does it need a ink roller?
This thing doesn't use ink. It uses thermal transfer onto the paper. Meaning it burns the letters onto the paper. You probably got bad paper cartridge or wrong brand. Try inserting a new cartridge.
Sep 15, 2010 | Dymo LetraTag QX50 Thermal Label Printer
My printer is not printing out any black ink onto paper. Only the color is printing out onto paper. I put two brand new cartridges in for the black ink and color ink, and it says that the ink levels are...
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It’s best to do this each time you install a new cartridge. for more information….... http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Sep 03, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
My canon ip1900 printer does not print even though it sounds like it
Your printer cartridges have likely dried up. You can try removing the print cartridges from the printer and pressing the print head (the bottom where ink comes out) into a moistened paper towel. This will hopefully rehydrate the dried ink in the print nozzle. Ink will likely transfer onto and through the paper towel, so please take precautions to not soil anything.
If this does not work you will likely need new printer cartridges. Refills can be used with decent success for the black but the machine will likely refuse a refilled color. Unfortunately this is how Canon has designed the machine. An original should be used in this instance.
Jan 14, 2010 | Canon Office Equipment & Supplies
Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black...
Canon PIXMA MX850 Multi Function Printer Printer Canon MX850 will not print from... Answer Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink... (More) Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black cartridge and not the large black cartridge? Thanks
Sep 30, 2009 | Canon PIXMA MX850 Multifunction Printer
No black ink printing
Try reinstalling the printer, as it sounds like a driver problem. This shouldn't happen, but occasionally the drivers get corrupted. And refilled cartridges certainly don't help, and may continue to give trouble even when replaced with OEM ones. Have you tried turning the printer completely off - disconnecting the power lead, for a few minutes? That sometimes clears things.
Jun 27, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Giant blobs of ink on every photo...
If you aren't currently, use the cartridge that the printer's manual says is for photos. Photo paper requires a different kind of ink.
Jun 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Black ink stall damage
The ink cartridges sit inside this area made up of three (3) light grey plastic "walls". The middle "wall" has a spring on it that is held onto the wall by a little molded *** that is part of the plastic mold. This *** breaks and the color ink cartridge will not sit in there correctly.
agrebe@sbcglobal.net
You could use epoxy.
Drill small hole and cable tying the wire in place.
If the spring has ripped a hole in the printhead contacts, then you will not be able to fix it.
Mar 13, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Copier won't print black
Have you tried a new black cartridge?
1st I would try to clean the bottom of the black cartridge with a paper towel and some windex. Spray the windex on the paper towel, and then wipe the bottom of the cartridge so it removes any dried ink.
Then you can press the bottom of the cartridge with the paper towel for about 5-10 seconds and see if you get any ink to flow onto the paper towel.
Install the ink cartridge and run the maintenance program that HP has with their software, or just use the menu on the printer, and run the cleaning maintenance and repeat if it still doesnt work.
Worst case, replace the cartridge.
Hope this helps.
good luck.
Mac
Feb 09, 2008 | HP PSC 1210 All-In-One InkJet Printer
Balck ink not working
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Mar 16, 2007 | Canon S 330 InkJet Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
103 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
