Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
Have 34700z refrigerant pressure into oil injection bottle why?
    President:
  • 180 Answers
This is a normal function of the machin,so don't worry!
Posted on May 08, 2010
Robinair Cool-Tech 34700z sending refrigerant to oil recovery container when charging system.
You confirm it by how it functions, if it sticks in a mechanical way there is no electrical testing that would be valid. I would just replace both solenoids.
Oct 13, 2016 | Robinair Cool Tech 34700Z Recovery,...
Why will my robibair 34700z not inject oil
You need to Rebuild/Replace oil injector solenoid, Located on "Inlet manifold block". Check attach picture to find location of oil injection solenoid. Hope this will help you. Thanks 38033401-113d-4966-a736-c10226c2d91b.jpg
Jul 10, 2014 | Robinair Cool Tech 34700Z Recovery,...
MY 34700Z ON RECOVER SAYS LOW PRESSURE, IT EVACUATES OK BUT SHOOTS OIL INTO OIL BOTTLE UNDER PRESSURE @ SAME TIME
your recycle solenoid is stuck open. the oil drain switch works by building pressure up to 16 psi then the recycel solenoid shuts off and the oil drain solenoid opens. if the recycle solenoid is stuck open you will get liquid 134 out when it is draining
Nov 19, 2012 | Robinair Cool Tech 34700Z Recovery,...
Cool Tech 34700Z Recovery, Recycling, Recharging: when performing a/c system charging see bubles in ...
Pls Check oil drain solenoid it's may need to rebuild or replace.If solenoid is OK then you may need to change oil drain switch.
May 17, 2010 | Robinair Cool Tech 34700Z Recovery,...
When under vacuum down machine started pulling oil front injection bottle
You need to Change ''Oil inject" solenoin from small manifold assy.
Note:Green dot OR blue label denotes are oil injectoct solenoid.
May 11, 2010 | Robinair Cool Tech 34700Z Recovery,...
ROBINAIR 34700Z ALWAYS FAILS VACUUM CHECK AND WON'T INJECT OIL.SAYS PRESSURES EQUAL.
Please check the following: Low side manifold gauge is going to -13"HG while you recover refrigerant from the vehicle.If low side gauge not rich to that lavel then vacuum sensor will detect pressuer &
it will stop you to make vacuum until you fix the problem.If it happen you may nee to rebuild/replace one or more of this solenoid.1#Vacuum solenoid 2# Recover solenoid.3# Recycle solenoid.Also check Low/High side small solenoids ( In the small block assy.)
If all of this solenoids working properly then check Vacuum pump capacitor & vacuum sensor.Hope this will help you to solve your problem.
Apr 09, 2010 | Robinair Cool Tech 34700Z Recovery,...
Refigerant in oil recovery bottle
You have to change/rebuild oil drain solenoid & check oil drain check valve.
Sep 08, 2009 | Robinair Cool Tech 34700Z Recovery,...
Robinair 34788 not pulling a vacuum
It's seems to be problem with your unit relay board,vacuum pump or pressure transducer.Most of Robin air 34788 machine having same problem.You can try as follows 1# Open vacuum pump oil filling cap to release extra pressure from pump.2# Replace new relay board & follow the on screen message(do not skip any option).3# Check pressure transducer is working properly.I hope this will help you.
Jun 06, 2009 | Robinair Cool Tech 34700Z Recovery,...
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
184 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
