Question about Fujitsu fi-5120C
The feeder takes several sheets at a time. How do
The feeder on my Fujitsu 5120c Scanner takes several sheets at a time. How do I fix it?
    Novelist:
  • 104 Answers
When ever you face such type of issue, the Scanner will display U-2 error with the Red led blinking and the TWAIN display will be "The multi feed is detected.(Code DS32006)".
To resolve the issue, please follow the steps provided below:
#Check if the documents satisfy paper specification? Please refer to the Operator’s Guide for paper specification, paying
attention to the following points:
• Is there any print within 10mm x 10 mm square in the center of documents on the top?
• Is multi feed error detected by paper length when scanning documents with different length?
• Is there perforation in the center of documents?
#Check ADF and clean pick roller, Pad ASY and around DF sensor with care.
#Replace Pick roller and Pad ASY and see if the error is removed. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the permitted values, replace Pick roller or Pad ASY. If the error still occurs, confirm that the cable is correctly connected then replace the sensor.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
Posted on Jul 27, 2010
Can't connect fujitsu 5120c scanner to windows 7 machine
To connect your Fujitsu fi-5120c scanner to Windows 7 PC, you need to install the TWAIN driver for Windows 7. Please download the driver update from the link provided below:
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/twain/v9211013.html
Hope the above information is helpful.
Please feel free to to contact us for further assistance.
Thanks & regards,
ScanCare
Sep 04, 2011 | Fujitsu fi-5120C
Code DS42003 PAD ASY IN PAPER FEEDER
After you've been scanning for a while with your Fujitsu 6110 or 6130 scanner, you will get a message from the scanner recommending that you replace some of the scanner's consumable parts, such as the pick roller and pad assembly. Although you can ignore these messages, they will keep showing up, even after you have replaced the parts, until you also clear the scanner's page counters in the Software Operation Panel.
http://www.scan123.com/blog/index.cfm/2013/3/15/How-To-Reset-Page-Counters-for-Fujitsu-6110--6130-Scanners
Sep 30, 2010 | Fujitsu fi-5120C
Scanner keeps grabbing 2 to 3 sheets at a time when scanning
You need to clean the rubber rollers with a damp cloth thoroughly.
S. Mohan
Jul 29, 2009 | Fujitsu fi-5120C
Paper jam
It seems youre facing an issue with the scanner consumables - pad and pick roller. It is a goos idea to replace both of them at the same time. Also check the feed and exit rollers (the two rollers on the upper part of the scanner) as the get sticky causing problems like the one you describe.
Sep 27, 2017 | Fujitsu ScanPartner fi-5120C Pass-Through...
How to remove Assembly pad message after replacement
you can reset this message in the scanner controll panel.
Please call windows <start>
<settings>
<system control>
<scanner and cameras>
open <scanner and cameras>
inside you will find your fujitsu scanner fi-5120C
now call <attributes>
-- in WIN2000 there is a button, in XP use the right mouse button--
in <device settings> you see the ADF counter, an the consumable counters for pad and pick roller.
Reset the changed parts, confirm the EEPROM writing
and the message will be cleared.
Jun 24, 2008 | Fujitsu fi-5120C
Fi 5120c will not scan sheets that have different color entries
Check the software settings in the scanning software. Try running scandisk in the OS. Check if the scanner is working with any other comp. If it works, may be your OS is corrupted.
S. Mohan, Chennai
May 29, 2008 | Fujitsu fi-5120C
Fujitsu 5120C Scanner
http://193.128.183.41/home/v3__product.asp?pid=462&inf=doc&wg=75
Dec 12, 2007 | Fujitsu fi-5120C
How to scanning double sided document in fujitsu 5120c scanner
You may want to try using Laser Fiche. This scanning software allows you to select "Duplex" which allows you to scan double sided document
Oct 23, 2007 | Fujitsu fi-5120C
Scanning trounleshooting
Open the paper feeder tray gently. see the rollers which intake the paper. Clean softly those rollers and tray with a dry medium. Pleasedo not touch any senser there. Read the open instruction from manual.
Aug 20, 2007 | Fujitsu fi-5120C
Fujitsu fi-5120C Logo
769 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
