Question about Garden
Runs fine untill you cut then loses power - Garden
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
Couple things to try. Fresh fuel and carburetor adjustment. Usually the high speed jet causes this. Starvation for fuel.
Posted on May 06, 2010
I have a Mazda MPV 2003, i bought from japan, 7 months ago, this van was running well until two days ago, it stsrts and cut off, starts again and while driving it is losing power then it will speed up
Before any diagnostics, I would run a tank of gas with a bottle of fuel dryer and injector cleaner to ensure that the engine racing isn't resulting from moisture and clogged injectors.
Jul 28, 2014 | 2000 Mazda MPV
Once vehicle is warm stalls and loose power
Vehicle Starts, Runs and Loses Power
http://whoisbyme.blogspot.in/2012/07/vehicle-startsruns-and-loses-power.html
Its a hot start issue.
Can be related to low fuel pressure or problem with crank sensor.
Also it can be weak battery or starter.
But possibilities are to be inspected to confirm what exactly it is.------
To troubleshoot and confirm the issue,i suggest you refer few solved help links with similar types of problem like yours:------
Click the link below:------
1991 Toyota Trecel: Engine Starts fine but dies when gets Warm?
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1994 Toyota Pickup: Starts fine but dies in few seconds?
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
1995 Lexus LS400: Running Hot?
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
2002 Toyota Camry: Puff of Blue or White Smoke while Starting?
http://whatisbyme.blogspot.in/2012/05/2002-toyota-camry-puff-of-blue-or-white.html
Multiple problems on car: Car runs hot, A/C blows hot and car starts surging?
http://schematicsdiagram.blogspot.in/2012/04/multiple-problems-on-car-car-runs-hotac.html
Delay starting on Toyota Prius?
http://schematicsdiagram.blogspot.in/2012/02/delay-starting-on-toyota-prius.html
Honda car will not start intermittently?
http://technoanswers.blogspot.in/2012/02/honda-car-will-not-start-intermittently.html
Intermittent starting issues on Volvo 760?
http://schematicsdiagram.blogspot.in/2012/02/intermittent-starting-issues-on-volvo.html
Car starts and cuts off immediately?
http://repairhelpcenter.blogspot.com/2012/01/car-starts-and-cuts-off-immediately.html
These details will help.
Thanks.
Dec 04, 2012 | Cars & Trucks
Check engine light flashing, engine bogging down and cutting out on acceleration. Car running great no sign of problems until the sudden lose of power when accelerating. Felt like it was going to cut off...
it could be a lot of things.. but if you smelled something burning then you may have already done damage to your car. id have it towed to a dealer.
Mar 07, 2011 | 2005 Mazda RX-8
Runs well untill it gets hot. then cuts out
If it's the little xl model, it's probably the ignition coil breaking down when it gets hot and therefore it can't and won't be able to handle a load. Also, scarred pistons skirt or rings could also be some of the problem here. Make sure your mix for a Homelite saw is 40:1 not 50:1 like most saws are. Homelite seems to run better with a heavier oil mixture. Good luck.
Aug 02, 2009 | Garden
06 Road King Classice shuts off when in 4th gear beloe 50mph
It's normal for the check engine light to take from 0 to a couple seconds to turn off. The computer runs a system check. Put an oil pressure gauge on the bike and watch it closely. If your pressure drops when the bike loses power, the engine may be locking up from lack of oil. Another possibility is your lean-angle cut-off switch is defective. The switch cuts power to the bike in case you lay it down. Harley also has had problems with their fuel injection system losing power for no apparent reason.
Apr 26, 2009 | 2006 Harley Davidson FLHR Road king
91 miata mx-5 cuts out at 2200 rpms- cant smog- check eng. lite isn't on
The very first thing to do is replace the ignition wires. These were a very common problem on Miatas. Since you're taking them off, it would be a good idea to change the plugs as well. These things are really just maintenance, but one other thing to check is the condition of the intake hose. It is critical that the hose that runs between the throttle body and the airflow meter has no cracks or flaws. Sometimes they are hard to see because the hose has creases in it. It's a good idea to take the hose off and inspect it carefully. If it is broken in anyway, the airflow meter won't know how much air is entering the engine and fuel will be cut off.
Apr 05, 2009 | 1991 Mazda MX-5
96 civic cuts out on highway
check the fuel filter, fuel pump, fuel pump relay, also check the main relay located behind the centre console, behind the radio
Mar 01, 2009 | 1996 Honda Civic
Garden Logo
85 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
