Sony Viao Laptop PCG6W3L showing white screen on switching on. pls suggest
  • CL May 06, 2010
    But it is not even showing bios screen. It is coming like white screen whatever we do ..
  • 4,281 Answers
When you power up the computer press F1 or F2 or DEL or ALT+F2 key to enter in bios then load optimal defaults settings.Then save settings also make sure your harddrive is recognized in bios if it is not show in main menu then disable SATA option then save settings.
But if you are not able to see any display and your laptop look like hangup when power up then opoen back cover of laptop then reattach the RAM memory into it's position pull cmos cell from motheboard for 10 minutes then put it into it's position then check.
If you are able to see windows logo then white screen thjen when you power up the computer press F8 key then enter in enable vga mode then display settings and change screen resolution to 1024*768 .
But if you are unable enter i enable vga mode too then you need windows disk to repair windows.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 06, 2010
  • For that you need to open back cover of laptop.
    Then reattach the ram memory and harddrive.
    Pull cmos cell from motherboard for 10 minutes then check.
Not getting video (blank screen) on my Sony Viao E series laptop.
Your friend is wright, this is a graphic card problem.
most laptop have the graphic card integrated and cannot be changed.
in your case check this link http://community.sony.com/t5/VAIO-Hardware-Networking/CAN-I-REPLACE-GRAPHICS-CARD-OF-MY-VAIO-LAPTOP-E-SERIES/td-p/164377
Thanks.
Nov 02, 2014 | Sony VAIO E Series Notebook VPCEB1GGXBI
How do I switch on my SONY VIAO Laptop to accept wireless internet, which I know is working fine
Depending on the model you own, most Sony Viao laptops have a small slide switch along the front edge.
May 27, 2011 | Computers & Internet
My laptop ( sony viao laptop) fell and now once turned on I have a black screen all lights and sounds are good. Could this be a led disconnect problem or a video card situation. What type of video card...
Unlikely to be a vga cable loose, but you can check by removing the switch panel cover and the screen to check it is still firmly housed.
test the laptop first in an external monitor, if you get an image, then the graphics chip is still ok
This then points to the screen, may appear undamaged, closer inspection with a torch, shone through the back of it will show any cracks you do not see straight away.
If the screen will not light up, fault is probably with a damaged backlight or inverter, you are then looking at a new (or 2nd hand) screen
Dec 30, 2010 | Sony VAIO PCG-K35 Notebook
Sony Viao PCG6w3l showing white diaply. pls suggest the solution
The laptop screen may turn white because of poor connection between the video cable and the LCD screen. What you are getting is pure lamp, meaning the inverted is good. If you want to check the video cable connection coming from the motherboard to the LCD, you’ll have to take apart the display panel because the connector is located on the back side of the LCD screen and the motherboard. It is not an easy task for the regular user (even experienced ones).
Try using an external monitor and press FN+F7 and see if you get display on the external monitor... you can use it like that in the meantime. But you have to take it in for repair to replace the screen.
I hope this helps.
May 06, 2010 | Computers & Internet
MY LAPTOP TURN ON YOU HEAR THE LOGO SOUND,SCREEN TURN WHITE,HARD DRIVE KEEP TURNNING ON AND OFF BUT NO PICTURE,JUST A BLANK WHITE SCREEN. I HAVE A SONY VIAO PCG-Z1VA MODEL.
Insert your Windows installation disk and select Repair Windows rather than Install. Hopefully it will allow you to boot properly.
Sep 23, 2009 | Dell Inspiron 6000 Notebook
I have a sony viao vgn-c210e. but there is an x
u r laptop battery has dead u need to replace it
Jul 29, 2009 | Sony VAIO VGN-C210E/H PC Notebook
I need to know the pixels for a sony viao vgn-430d screen
You should be able to find the proper LCD screen, by the LCD screen size, whether it is a widescreen or not, and whether or not it's a matte finish.
I need the exact model number. The Vaio VGN-430d does me no good. Suggest you look on the bottom of the laptop. There may, or may not be a Service Tag.
Look for something like VGN-NR , and a number.
What you may see on the side of the LCD screen, or on the body of the laptop, is just part of the VGN series.
Apr 12, 2009 | Computers & Internet
Monitor screen is black when hooked up to my laptop.
u have to set screen resolution of monitor to 1024 *768
Jan 05, 2009 | HP Pavilion F1703 17" LCD Monitor
Computers & Internet Logo
127 people viewed this question
David Payne
David Payne
