Question about Cobra 18 WX ST II 40-Channels Base CB Radio
Stuck on channel 9 wont change
Bought it barnd new wired it and now it is stuck on channel 9 and wont change.
  • Bill Buchsbaum
    Bill Buchsbaum May 11, 2010
    Does it have a Channel 9 monitor button? If so, press that button to return to normal operation . . .
    Genius:
  • 1,274 Answers
Try pressing the emerg. or Cha.9 button....hope this helps...
Posted on May 12, 2010
Toshiba smart tv stuck on one channel tried new remote wont change channel went back to old remote still the same
Did you try changing the source? It might be getting the channel from a source other than the TV.
Sep 09, 2016 | Toshiba Televison & Video
Why wont my channel change work on my cb
I'll have to answer with a question is the instant 19 or 9 switch selected? Some models an have addition switch on face for quickly changing to one if not both of these channels.
Mar 02, 2015 | Radio Communications
Can u please help me fix this. I bought a Belkin Surf and it wont give me wireless reception
Uninstall Belkin Router Monitor software from the control Panel
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Dec 19, 2010 | Belkin Wireless Surf Router (F7D2301)
Wont change channels...stuck on channel 8
on this radio you have to put the norm and channel 9 switch to normal or up if it is on ch 9 positon it will not change channels.
Apr 16, 2009 | Midland 1001Z 40-Channels Base CB Radio
Insignia TV is acting wierd
the problem lies in themain board in the tv. you can buy one from ebay for around $80 used. its not to bad to replace either. just remove the back panel the main board it the tin/ metal wit hthe ciruit board in it on the left side same side as the power botton just unplug the 5-7 wires and unscrew the 2-3 screws and carfully side that board out and replace with a new workign one and put back together and you should be good to go.
please rate my answer it is much apreceated
Feb 04, 2009 | Insignia IS-LCDTV32 32 in. Television
Ilo 32 in
Try the keys on the set I would think there is a menu key there on the set to help get you out of favorite channels. Universal remotes don't always work as thought should be and usually onthe the devices remote will access all functions. Is our remote dead or busted? Try opening it up look for bad solder on the circuit board clean the switch contacts on the the board it may just fix it
Sep 03, 2008 | iLO 3200 32 in. LCD Television
First, try resetting the faceplate CPU by shorting the proper pins on the faceplate to radio connector on the back of the faceplate with a piece of wire... They are marked on the connector, if this fixes it for you, enjoy!
If that doesn't work, then remove the back cover of the faceplate and check the faceplate connector itself for bad solder joints. As a matter of fact, check the entire radio for bad solder joints before looking any further.
I bought one of these radios a short time ago; Everything worked except for LSB.
I was told by the radio shop I bought it from that I'd have to wait until June to get it fixed, so I opened it up myself to see if it was something easy to find/fix, since I felt that if it was anything major it wouldn't be able to get AM or USB either.
In my case, I found bad solder joints on the faceplate connectors and a bad solder joint on one of transistors attached to the heatsink.
Once I fixed those two things, it's been a great little radio.
Be sure to reset the faeplate after resoldering and assembling, to clear any errors from the CPU.
Apr 05, 2008 | Midland 79-290 120-Channels Base CB Radio
Cobra 18 WX ST II 40-Channels Base CB Radio Logo
208 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
