Question about Hyundai V770+ 17 in.CRT Conventional Monitor
How to exit 'off mode' and make the screen active
My panasonic tv is ever blowing thhe horizontal transitor
Posted on May 06, 2010
I bought a used 7525 Xerox. Wont print now. Screen reads Activation Code Attempts Exceeded. The maximum number of Activation Code attempts has been exceeded and activation code entry is now locked.
The previous owner has set activation code check if you can get the code if unable to then reset the Xerox..use the following steps
1- enter diagnostic mode >> hold 0 10s then press start >> password 6789
2- tab on Adjustments then tab on dc301 NVM initialization >> choose copier >> selest all >> then initialize.
3- tab on call closeout then exit & reboot.
4- after the macthine turned on you find it in a non customer mode.
5- again enter diagnostic mode again >> hold 0 10s then press start >> password 6789
6- tab on Adjustments then tab on dc131 NVM Read/Write > enter 616-014 >> change the value to 2
7- again tab on call closeout then exit & reboot.
8- while the machine is turning choose customer then follow the setup as you want till reach to lock or unlock tools >> choose unlock tools.
9- you will never need the admin password again also on the web page.
Jan 26, 2018 | Xerox WorkCentre 7556/P Copier
F buttons description
F1 - Security System
Press and hold the "Fn" key on the lower left-hand corner of your Toshiba keyboard.
Press the "F1" key to activate the security system.
Your laptop's screen will go blank so others can't see what you are working on or accessing.
Sponsored Links
Computer Repairs (Melb)
No Fix, No Fee. Same Day or Free. We Come To You - 1300 723 628
www.thepcdoctor.com.au/melbourne
Press any key or touch the touchpad to exit the security mode.
F2 - Power Save Mode
Press and hold the "Fn" key.
5
Press the "F2" key to activate the Power Save mode and make changes to how your laptop handles operating on battery or AC power.
6
Press "Fn" and the "F2" key again to exit the power save mode.
F3 - Standby Mode
7
8
Press the "F3" key to place your laptop in Standby mode.
The Standby dialog box will appear.
9
Verify you want to enter Standby mode. Press the power button on your Toshiba laptop to exit Standby mode.
F4 - Hibernation Mode
10
11
Press the "F4" key to activate the Hibernation mode and save whatever documents and files that are open to your hard drive.
12
Verify you want to enter Hibernation mode. Press the power button on your Toshiba laptop to exit Hibernation mode.
F5 - Active Display Device/F6 and F7 - Toshiba LCD Screen Brightness
13
14
Press the "F5" key to change your laptop's active display device from the laptop screen to an external monitor.
15
Click on the display configuration you want: displaying on both the laptop and external monitor; only on the laptop; only on the external monitor; or a specific screen resolution.
16
Press and hold "Fn" and "F5" to accept the new display settings. Press and hold "Fn" and "F5" again to return to your laptop's display only.
17
18
Press the "F6" key to decrease your laptop's screen brightness. Press the "F7" key to increase the brightness.
F8 - Wireless Connection/Bluetooth
19
20
Press the "F8" key to select the wireless Internet or Bluetooth connection you want to use.
21
Press and hold "Fn" and "F8" to make your selection. Release the keys to confirm your selection.
F9 - Touchpad Control
22
23
Press the "F9" key to enable your laptop's touchpad.
24
Press and hold "Fn" and "F9" again to disable the touchpad.
F10 and F11 - Numeric Keypad/F12 - Scroll Lock
25
26
Press the "F10" key to enable your Toshiba laptop's numeric keypad.
27
Press and hold "Fn" and "F11" to enable the cursor control keys on the numeric keypad.
28
Press and hold the "Fn" and "F10" or "F11" key to disable the numeric keypad or cursor control keys.
29
30
Press the "F12" key to lock your cursor on a specific line of text. Press and hold "Fn" and "F12" to turn scroll lock off.
hope this helps
Sep 25, 2012 | Toshiba Satellite A100-S8111TD Notebook
Activating the grad function?
Turn calculator ON.
If you see no icons, press MENU then 1: to enter the RUN screen. Press the SHIFT MODE key combination to enter (SetUp). Use down arrow to highlight the line Angle. Press the F3: key to activate the GRAD angle unit. Press EXIt to return to the RUN screen.
Sep 19, 2011 | Casio FX-9750GPlus Calculator
HOW DO YOU MOVE THE ARROW KEY ONCE YOU ARE IN THE MENU?
You use the button with the <> arrows to move through the menu selections. Use the menu key to select the function you want to change.
Below is an excerpt from the Acer manual. The manual can be found at http://www.retrevo.com/support/Acer-X203H-Monitors-manual/id/23224bh549/t/2/
Front Panel Controls
1.Power Switch:
To turn ON or OFF the power.
2.Power LED:
Lights up to indicate the power is turned ON.
3.Empowering / Exit:
1) When OSD menu is in active status, this button will act as EXIT-KEY(EXIT
OSD menu).
2) When OSD menu is in off status, press this button to select scenario
mode.
4.Auto Adjust button / Exit:
1)When OSD menu is in active status, this button will act as EXIT-KEY (EXIT
OSD menu).
2)When OSD menu is in off status, press this button for 2 seconds to
activate the AutoAdjustment function.The Auto Adjustment function is
used to set the HPos, VPos, Clock and Focus.
5.< / >
Press < or > to select the desired function.Press < or > to change the
settings of the current function.
6.MENU / ENTER:
Activate OSD menu when OSD is OFF or activate/de-activate adjustment
function when OSD is ON.
Jul 02, 2011 | Acer X203H bd Monitor
LOOKING FOR PICTURE SETTING SAMSUNG MO.NO.LN-T5265F
This may help you...you can also get an owners manual free on line.
English - 23
Using Automatic Picture Settings
Your TV has Three automatic picture settings ("Dynamic", "Standard", "Movie") that are preset at the factory.
You can activate either Dynamic, Standard, Movie by making a selection from the menu.
1. Press the MENU button to display the menu.
Press the ENTER button, to select "Picture".
2. Press the ENTER button to select "Mode".
Press the ??² or ??¼ buttons to select the "Dynamic", "Standard", "Movie" picture
setting. Press the ENTER button.
?³ Choose Dynamic to increase the clarity and sharpness of the picture.
?³ Choose Standard for the standard factory settings.
?³ Choose Movie for a natural Image without picture enhancements.
3. Press the ??² or ??¼ buttons to select "Contrast", "Brightness", "Sharpness",
"Color", or "Tint(G/R)", then press the ENTER button.
4. Press the ??? or ??? buttons to decrease or increase the value of a particular item.
For example, if you select "Contrast", pressing the ??? button increases it.
Press the EXIT button to exit.
• When you make changes to Contrast, Brightness, Sharpness, Color, Tint(G/R)
the OSD will be adjusted accordingly.
• When in PC mode, Tint, Sharpness, and Color are not available.
Press the P.MODE button on the remote control repeatedly to select the desired
picture mode.
Picture Control
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 00
??¼More
TV Picture
Move Enter Return
Mode : Dynamic
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
Dynamic
Standard
Movie
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
50
??² Con trast ??¼
Move Adjust Return
English - 24
Adjusting the Color Tone
You can change the color of the entire screen according to your preference.
Press the ENTER button to select "Picture".
2. Press the ??² or ??¼ button to select "Color Tone", then press the ENT ER button.
3. Press the ??² or ??¼ button to select "Cool2", "Cool1", "Normal", "Warm1",
or "Warm2".
When the picture mode is set to Dynamic or Standard, Warm1 and Warm2
cannot be selected. Movie mode is only available.
Move Enter Return
??²More
Color Tone : Cool2 ???
Detailed settings ???
Size : 16 : 9 ???
Digital NR : Low ???
Active Color : On ???
DNle : On ???
Reset : OK ???
TV Picture
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : On
Reset : OK
TV Picture
Cool2
Cool1
Normal
Warm1
Warm2
Activating Backlight
You can adjust the screen brightness by adjusting the LCD backlight brightness. (0~10)
2. Press the ??² or ??¼ button to select "Backlight", then press the ENTER button.
3. Press the ??? or ??? button to decrease or increase the valueof the backlight
brightness.
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balcklight 1 0
??¼More
TV Picture
5
??² Balcklight
??¼
Move Adjust Return
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : Off
Reset : OK
TV Picture
OK
Cancel
Resetting the Picture Settings to the Factory Defaults
1. Press the ??² or ??¼ button to select "Reset", then press the ENTER button.
Press the ??² or ??¼ button to select "Cancel" or "OK" then press the ENTER button.
Each mode can be reset.
Feb 04, 2011 | Televison & Video
How to activate safe mode on acer aspire
press f5 at acer logo appear at start up, then chose safe mode
i hope this helpfull, please rate very helpfull if you think this helpfull
thanks for using fixya
Jan 22, 2011 | Acer Aspire 3623WXCi Notebook
How to i change it the decimal setting , because i am getting wrong answers
I am not sure what you are exactly asking. However if you are concerned about the calculator not showing you enough decimal digits, this can be fixed as follows.
  1. Turn calculator ON
  2. If you see no icons, press [MENU]
  3. Use arrow keys to highlight [RUN] icon and press [EXE].
  4. In RUN screen press [SHIFT][MENU] to access (SetUp)
  5. Use down arrow key to scroll down the list of options until you reach Display.
When the Display line is highlighted you can press the function keys
  • F1 to activate Fix display mode
  • F2 to activate Scientific mode
  • F3 to activate Normal (Norm2 or Norm2 ) mode or F4 to activate the Engineering mode
If you select Fix or Sci you will have to specify the number of digits that are kept in the decimal part. You do so by pressing the relevant function key (F1,F2,F3 etc.).
Press [EXIT] to exit the SetUp screen.
Nov 13, 2010 | Casio FX-9750GPlus Calculator
My telephone is on silent mode! how can I reverse this option? samsung sch-r450
press and hold the pound button then your screen will say exiting silent mode. and if you press and hold the pound button after that your screen will say silent mode activated
Sep 27, 2009 | Cell Phones
How do you active the LCD screen on Canon EOS Rebel XS. I've read teh manual but still cannot active it. this is to review the shot before you take the shot.
In your manual it is on page 95, on how to do this,
It is called LIve view shooting and it does not work on basic zone modes.
1. Set camera to a creative zone mode
2. then under that tools option select live view function setting then press the set button
3 select live view shoot then hit set
4. press the menu button to exit
May 14, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Windows is activated but will not log me on
There seems to be nothing else we can do other than reformatting your hard drive and reinstalling your operating system since you cannot go to safe mode and do system restore. The problem is with the OS so it needs to be reinstalled. Hope this helps. Thank you.
Sep 30, 2008 | Microsoft Windows XP Home Edition
Hyundai V770+ 17 in.CRT Conventional Monitor Logo
107 people viewed this question
Top Hyundai Computers & Internet Experts
rhodesworks
 Zackery G
Zackery G
Level 1 Expert
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
