Question about GE Profile Spacemaker Over-the-Range Microwave
Microwave light and fan run all the time will not shut off When I close the door, the fan comes on and the light stays on, never shuts off. Does not seem to be putting out the microwaves, as a cup of water doesn't get heated and the the vent above does not open as it does when I use it. Does heat when I enter the time/power as normal. GE model PVM1870DMICC Tried unplugging it for a few minutes, enough to require a clock set, but no difference.
  • David Strom Nov 24, 2010
    After a few months, the problem cleared up by itself!
    The light is out, I wonder if that fixed it? ;-)
  • GE Master
  • 9,047 Answers
That is probably a bad primary interlock (bottom door switch).
See this file for help on checking and replacing door switches.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Posted on May 06, 2010
How do I get my emerson microwave to turn off after the timer is finished?
There are a couple of microwave ovens out there where after it has finished cooking, the light and fan continue to run until you open the door. Then the fans shuts off, but the light remains on. When you close the door, then the light shuts off. If the light and fan go back on when you close the door, then you have a bad door switch.
Oct 20, 2014 | Emerson Microwave Ovens
Fan & Light stays on???
On a few new model microwave ovens, this is a "feature"! It's purpose is to cool the microwave parts down, and to remind you that your food is cooked. Once you open the door, the fan will shut off and stay off when you close the door again. But if not, or if you microwave oven didn't use to do this, then you have a bad door switch.
Sep 08, 2014 | Microwave Ovens
Samsung model smh7178std, shut the door and the fan and lights come on automatically, if i lift up on the door the fan shuts off but light stays on.
some switches are normally closed "short position" press switch "open" it will be labeled NC on the one side, "stands for normally closed" and others will be NO "stands for normally open" press switch "short" if there is no change in readings when you press switch it is defective.
Mar 28, 2012 | Samsung SMH7178STD Microwave Oven
GE Spacesaver microwave always runs when the door is shut
I see this all the time. In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 10, 2010 | General Electric Microwave Oven
Cooling Fan stays on until the door is open
May be a sensor or thermostat for the fan thats faulty therefore it runs all the time.
Sep 16, 2009 | Jenn-Air JMV8000 Microwave Oven
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
Our Microwave keeps running unless we give it a whack!
Hi firstly to see if it is producing energy, buy some 5mm light emitting diodes from an electronics store. cut off the leads close to the plastic body.
place in microwave and put on cook for max 10 secs, if the led's light up you have microwave energy, shut off the oven as soon as they glow otherwise you end up with a mess.
If you have energy then your problem is most probably the door interlock micro switches which after time do not operate properly. let me know the results and we can go further.
Feb 23, 2009 | Danby DMW1153 Microwave Oven
Microwave buttons not responding - microwave running constantly with door shut
It seems the micro switch for the door close have moved from and is not aline the door clip or the micro switch is faulty
Dec 17, 2007 | Sanyo EM-S9515W Microwave Oven
GE Profile Spacemaker Over-the-Range Microwave Logo
509 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
