LG RU-42PX10 42 in. HD-Ready Plasma Television Logo
Posted on Feb 28, 2017
Picture not staying
Dear Sir,
I have recently purchased LG Plasma Model No # RU-42PX10/10C/10H/11/11C/11H from an American friend of mine in the State of Kuwait. When I connect my Kenwood DVD Player and Kenwood Home Theater system with my Plasma. The picture and sound result is clear and excellent. I have no problem connecting my DVD player with the Plasma TV but when I connect my cable (satellite) system with the TV , I hear the sound and the picture result is black & white and does not stay at one position. The picture shakes and seems like it needs to be tracked so it can stay at one position.
I therefore, I called two different special technicians to fix this particular problem. Unfortunately, both of them could not fix it. They both tried to connect wires in different sockets but nothing worked. I am very excited to display my Plasma in my living room. Please advise me what do I have to do? I am worried if this TV is not international (universal) and will not work in kuwait
- Do I need to change the settings by calling the LG Technician here in Kuwait
- Do I need the wires to connect in different sockets
- Do I need to buy HDMI wires or ?
Please do me this favor and help me. The person I bought the Plasma already left the kuwait and went to America. I have the catalog, remotes and warranty cards. Your help and respond in this matter will be greatly appreciated.
Very Respectfully,
Ali Khalid
[email protected]
  • ALI1985 Mar 26, 2008
    Dear Sir,
    Very Respectfully,
    Ali Khalid
    [email protected]
  • Anonymous May 11, 2010
    Are you using the TV in Kuwait?
4 Related Answers
Anonymous
  • 3 Answers
  • Posted on Jan 19, 2008
SOURCE: home theater system connections
Hi
I have the same tv but my dvd surround is a toshiba, that shouldn't matter though. When I watch a dvd I go to component 2 which is where I have my dvd connected on the input of the tv when I watch tv and want the surround on I go to component 1 which is the tv input then on my dvd player I go to auxillary and I can watch tv in surround. I don't know the LG home theatre system but you should be able to select your inputs like between dvd, tuner, aux. Flip between them and you should get sound. hope this helps.
Anonymous
  • 505 Answers
  • Posted on Dec 07, 2008
SOURCE: LG 42PX3DCV 42 in.
Pixel misfiring (diffusion errors) are caused when the tv is not firing and erasing the pixels correctly. It can be caused by a number of things, usually a voltage or waveform is off somewhere. If you just bought the tv, return it and get another. If you are out of warrany, you can remove the back panel and run the tv to check the voltages. Don't touch the heatsinks! they're electrically hot and will zap you.. the voltages are labeled on the back of the plasma panel with a sticker. first check Vs and Va. sometimes you can check -Vy, Vset, Vscan and others if labeled on the board. If you have to adjust waveforms you need a very $$ o-scope and should get qualified technician to adjust. If a board is bad, its likely your power supply or Y-sustain pcb, and less likely your Z-sustain or contol (logic) board.
Anonymous
  • Posted on Dec 29, 2009
SOURCE: loose picture sounds stays on
password for rar file
manualspace.com
Chi Chu
  • 8457 Answers
  • Posted on Sep 09, 2010
SOURCE: I purchased an LG BD570
Yes,put it in PCM stereo audio setting.Should work find with the Blu Ray player using the HDMI cable.
Our 42" Plasma HDTV suddenly
Hello sir, looks like your LCD inverter board is toast. this board is responsible for the back lighting of your TV, if this goes so as the lamp. your screen is blacked. Have this replaced by your dealer or check if they have service.
2helpful
2answers
LG RU-42PX10C Plasma TV picture had colored lines & went black...
This will be your Y SUSTAIN board on the left hand side when you take the back off.
Plenty available on ebay, Very easy fix
Lost picture on my LG 42" plasma model number 42PC1DV
it is problem high voltage unite problem (EHT) change it then solve your problem
2helpful
2answers
I have an LG Plasma "RU-42PX10C" i have sound but the picture is a lot of Horizontal colored lines
Please check if you have turned the wide feature ON. Wide feature would make the picture wider.
Hope this helps.
Regards,
HP
Lousy picture
go into the menu and find the contrast: reduce the red part of the RGB until it is suitable
50lg 50px5d plasma green light goes on, but no sound or picture
Your friend is probably right. It will either be the Y-sustain brd or the Z-sustain brd. I have seen both bad at one time or another, The part numbers are on the boards.
Sound no pic
i had the same problem and i found a defective voltage regulator on the a/v board
good luck my friend
[email protected]
LG 42PX10 Plasma
I just fixed my plasma with same looking problem. Mine is a 42PX11. Cost me $320.00 in parts from Fishwick Electonics. Replaced three circuit boards, crossed my fingers and turned it on and am happy to report it has been working fine since for about 6 months now.
LG RU-42PZ90 42
I don't have a solution but I do have the same unit with vertical lines on the screen. I just had a tv guy come and diagnose my issue and he recommended I part it out on ebay. I'm interested first in trying to fix myself. Are you interested in selling me some of your parts?
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
