Question about Hotpoint Dryers
Drum rubbing how do i stop it - Hotpoint Dryers
  • 48 Answers
See if the felt on the front of the drum is worn out. If so replace the felt.
Posted on May 06, 2010
Drum stopped rotating at end of cycle smell burning rubber
There are two likely reasons for the rubber smell - either the drum belt has melted and snapped or the drum seal has rubbed too much and melted. Most likely cause would be poor drum bearings or consistent overload of washing. I am assuming this is a front loader as you have not provided any details of make or model.
Sep 26, 2014 | Washing Machines
Does anyone have the parts schematic for Miele Touchtronic W4800 drum assembly?
Attached is a IPB for the drain section - are you speaking of Item number 1? This was an issue at one time with the intake side - a piece of felt glued to the drum stopped the chaffing. 5471732e-e156-4138-ab0a-dca218299e0f.jpg
Aug 16, 2014 | Miele Washing Machines
Washer maytag front loading 4000 series assembled and runs but iwith two problems.1) residue on inner surface of door window..lint like oily paste ..gasket rubbing on inner drum?? meaning main rubber
The fault seems to be that the main seal is rubbing against and is thus producing the oily residue on the window. Now the fault seems that the drum is rubbing due to POOR ALIGNMENT or poor BEARING settings.
You need to check the PLAY on the drum and if this shakes a bit then the assembly must be reset with correct aligment and the drum must move without rubbing the rubber seals.
Check this link; replacing bearings
Jan 14, 2013 | Maytag Washing Machines
My 2002 chevrolet 4wheel drive makes a noise alot like that of a break rubbing.It stops as the speed increases, I changed all four brakes and rotors and also changed the universal at the rear end. what...
Make sure backing plates behind front & rear rotors aren't rubbing on rotors. Jack up each wheel individualy & spin. May also be emergency brake shoes rubbing inside drum inside rear rotors.
Jun 24, 2010 | 2002 Chevrolet Silverado
Thumping/rubbing sound in drum
The belt tensioner roller has a flat spot caused by a worn bearing that catches and stops whilet the drum is turning. This causes the flat spot and the noise its making. You can purchase a new roller by itself and do change the belt the same time too
Apr 08, 2010 | Frigidaire Electric Dryer
Whirlpool Dryer squeals
Either the drum is rubbing against something or more likely the belt pulley is cause the noise. Oil the pulley wheel and the drum rollers and it should stop squealing.
Dec 14, 2009 | Dryers
Candy washing machine smoke coming from inside
it is rubbing on spin cycle due to being out of balance.Rubbing wont occur when turning by hand.
Stop by your local hardware store for a packet of drum balancers.
Aug 16, 2009 | Washburn Electric Guitars Modelno. X10-B
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
Kenmore dryer front of drum rubs
Check your plastic drum slides. I get em(2) out of the drum and reverse them and that sometimes stops it.
Feb 14, 2009 | Kenmore 62602 Electric Dryer
Dryers Logo
48 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
