Question about U-Line Icemaker
Water overflows the ice tray into the container. I have replaced the blue valve. Is there anything else other than adjusting the cube size?
  • cw20 May 06, 2010
    The bucket is not overflowing with ice, water runs from the icemaker into the bucket.
  • 12,061 Answers
Www.tropicalmarineairconditioning.com/.../WH95TP-BI95BTP-BCM95_install.pdf
http://www.u-line.com/pdfs/discontinued/30-10009.pdf
http://foggyfacts.blogspot.com/2009/12/ice-maker-ice-dispencer-repair-manual_18.html
OK all those links above, are about your item, they are service and repair manuals, and a user manual too. Inside are diagrams, of and about what you need to know, download and have a look and it will soon all be clear.
Posted on May 06, 2010
    President:
  • 1,469 Answers
Many refrigerator ice makers operate 24 hours per day. They do this to match the increasing amounts of water and ice being consumed by modern customers. Some ice makers will stop once ice bucket full, but many do not. Therefore, if ice produced faster than you consume it the bucket may eventually overflow.
Turning off ice maker usually done via a switch or metal arm on the body of the ice maker. On those with a metal arm up position is 'off', and down position is 'on'.
Alternative method is to remove ice bucket and dispose of unwanted ice before it reaches top of bucket. Use caution with this method as some buckets are difficult to reinstall. It may be easier to simply dispense excess ice into a glass or bowl, which is then dumped into the sink. Excess ice can be used to water household plants.
So you don't need to adjust cube size.
Take care.
  • Egwe Emmanuel Onyedikachi
    Answer to long to write. You can use this link to get any solution you want about the ice maker.
    applianceaid.com/icemaker.html.
    Take care.
Ice maker overfills the ice tray, ejecting large block of ice instead of individual cubes.
What is your model number? Sounds like you may need a new icemaker. Sometimes when the icemaker motor goes bad it causes the icemaker to keep filling even though it hasn't kicked out the ice in there. Also, are you sure there isn't 2 valves on the refrigerator?
Nov 15, 2015 | Refrigerators
Large mass of ice cubes frozen together in tray, most likely from leaky ice maker. Can this be fixed without purchasing a new ice maker.
have you checked it when it's filling to see if it's overflowing or the heater on the ice maker might not be shutting off and melting some of the cubes but you have to check,also it could be the water valve,see if there's an adjustment on the ice maker,look in your book,some of them have an adjustment,try to adjust it so less water is coming into the ice maker but to answer your question you might need a new ice maker or a water valve,the only way to tell is to watch it when it fills to see what's happening,you can pop off the cover to the ice maker and jump it out with a piece of wire,in the bottom right hand corner you'll see two holes close together,t and h stick the jumper wire in those two holes and the ice maker will start up,watch it until it fills,if it overflows try the screw to let less water into it,if that doesn't work then it's gonna be the water valve letting to much water come into the valve
Feb 11, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
I am not sure this is the right refrig. I have a model 253.78259800 top freezer with a model JD-21 ice maker. The ice bucket keeps filling up with a solid piece of ice. It makes and drops cubes, then water...
there s a adjustment but it only controls /like 1 to 2 oz of water . its prbably the ice mker unit or the water valve . .. ice mker tell water how long to let water in and if valve is bak it might not shop off causing water fill . change water valve first . then ice maker if needed .. icemker might have a bad tray and some cubes do not drop / if so next fill will over fill causing problem . mm
Dec 07, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
My ice maker is letting too much water go into the ice tray so it freezes in a solid piece. Cubes do fall down but there is so much water it freezes into a solid block
The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
Oct 30, 2009 | Sub-Zero Bottom Freezer Refrigerator
Cube size adjustment location on lg refrigerator
The icemaker requires a water pressure of 1.5 - 8.5kgf/cm2. It is acceptable if the water supply fills a cup of 180cc with water in 3 seconds. The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
Oct 29, 2009 | ASUS Eee PC 900 Notebook
My icemaker overflows and does not produce cubes but a solid block of ice over the unit and down into the cube reception tray and over the bottom of the freezer unit. Have removed all the ice and restarted...
Hi
you need to adjust the water level, carefully remove the front cover of the ice maker itself.
On the front of the ice maker, there is a small nylon screw that controls the water intake amount.
If the screw is turned to the Right, it will Decrease the amount of water entering the ice maker.
If the screw is turned to the Left, it will Increase the amount of water entering the ice maker.
The screw should only be turned 1/4 of a turn at a time; therefore, more than one adjustment may be required.
The maximum adjustment is one full turn in either direction. Additional rotation could damage the ice maker..
OR
Dirty icemaker water valve or broken valve can cause icemaker to overflow.
Thanks for contacting fixya.com
Oct 22, 2009 | Hotpoint Refrigerators
Ice maker made too much ice, then none at all...
buy the water valve and the ice maker. replace. water valve locate in the bottom part of the unit. remove kickplate. (left side blue color). ice maker little trick to replaced. (special the 2 screws in the upper part.) call 1800 222 7820. subzero. for your closest store
Sep 19, 2009 | Sub-Zero Bottom Freezer Refrigerator
Ice maker overflows
The Icemaker may not be dumping the cubes after they freeze then more water pours in on top of them. The icemaker has a heater which turns the cubes loose and allows them to dump. You may find someone to work on an icemaker, not sure. If this is the case, I would replace the icemaker.
Dec 16, 2008 | Amana Refrigerators
Ice maker is making ice but the ice is becoming solid in the tray and jamming the blades and not comimg out in cubes
THE POSSIBLE CAUSES MAY BE FROM THE CUBE SIZE CONTROL
ADJUST THE CUBE SIZE CONTROL
INSPECT THE WATER SUPPLY LINE
TEST THE WATER INLET SWITCH
TEST THE WATER INLET VALVE
Sep 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker leaking
what is the model number of this fridge?
HTML clipboard_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
May 19, 2008 | Sub-Zero 632 / S
U-Line Icemaker Logo
293 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
jasbo
jasbo
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
