Question about Sony Playstation 3 (PS3) Console
My ps3 has an error 800100a it doesn't detect any near my routers
    Scholar:
  • 91 Answers
Is your wireless turned on both on the system and the wireless router? Do you have a wireless connection setup?
If not then these may be your issue. You also need to go into your internet settings on your ps3 and the select your connection type for example: wired or wireless then > select scan> if there are any in the area select your> rename it if you want> put in the passcode if there is one> make sure everything is correct> then test the connection. If the test works then your fine.
On the other hand if you don't have a wireless router or a wireless connection setup on that will be an issue. with your wireless router they should have included instructions on how to setup the wifi network. Follow those and the problem should be solved rather quickly. Once the wifi is set up just refer back to my previous paragraph and follow those instructions again.
Posted on May 06, 2010
"an error occurred during download operation" ps3 when i try to update ..please help
This Error code means there is a Network/Router error, try this to see if it corrects the problem, depending of on if you have a wired or wireless connection
1. WIRED CONNECTION > CUSTOM > MANUAL SETTINGS > AUTO DETECT > AUTOMATIC > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X
2. WIRELESS > ENTER MANUALLY > ( ENTER SSID OR CONTINUE ) > ( CHOOSE SECURITY OR CONTINUE ) > CUSTOM > AUTO > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X
Dec 21, 2014 | Sony Playstation 3 (PS3) Console
Error:8013031b this is not cant network for my playstation 3
1st if you are running your PS3 on wifi then make sure the pass phrase is entered in correctly.
2nd reset the modem and router by turning off both for 20sec. if that doesn't work then find the little red reset buttun on the back of the modem or router and hold in with a ballpoint pen for 5sec. if you hold it in for 10sec. or more it will bring the modem or router back to its factory settings.
Sep 15, 2011 | Sony Playstation 3 (PS3) Console
I have a ps3 and i get a error code 800100A
Hi katie279,
Error Code 800100A shows up when it's having to gain internet acess trough your router. To fix this you need to forward your ports on your router.
There are several guides but the one i recommend is the following:
  1. Go to this site http://portforward.com/ and search your router model (don't forget to skip the advertisement)
  2. On service select "Playstation Network"
  3. Follow the steps
This yould help you with your issue, hope this helped.
-Luchen
Mar 19, 2011 | Sony Playstation 3 (PS3) Console
Unable to get wireless access to internet on ps3, keep getting a connection error DNS 80710102 or 800100A, can you advise how to resolve?
Try to disable the security key of your wireless router in the meantime and try to connect your PS3 without the security turned on. If it connects, what you have to do next is to reset or generate a new security key on the wireless router and setup the PS3 - wireless network connections with the new security key.
May 26, 2010 | Sony Playstation 3 (PS3) Console
I cant log in on my ps3 or do anything internet related due to the error code 80130182 what should I do?
This is a common error which won't allwo you to connect online, here are some steps that youc can try that might fix the problem.
• turn off your PS3 and router/modem
• if you are connected thru wireless, try to hook up using hard wire this time
• you have to access your router/modem's homepage and change security key or might as well disable it in the mean time
• turn on the PS3 and your router/modem and go to Settings
• then scroll down to Network Settings and configure your connection it should detect it as wired
• then try to update your system with the latest firmware update under System >> System Update (if it is not updated)
• after that you can generate another security key and and enable security
Hope these steps helps.
May 10, 2010 | Sony Playstation 3 (PS3) Console
Internet turns off
It's a problem with your unit making a connection to your router. You can do one of a few things:
Uninstall and reinstall your router. Keep all settings default (if you don't, write down everything you do) and keep it to only one encryption key at max.
Distance from PS3 to router can make a huge difference, especially if it's an older router. If you can try either moving the router or the PS3 closer to eachother.
If it is an old router, you may want to consider getting a new one. Some experts will tell you that Wireless G routers are the best for gaming, which is somewhat true but you need to be willing to spend a good amount of money for it. I bought a Belink Wireless N router and my connection is so fast they make me the host of just about every online game. It ran me $60. My router is maximum 15 feet from my PS3 and it goes through 2 walls.
Your type of internet connection could effect it as well. If you have cable it's going to be fast but inconsistant; causing dead moments in your connection. If you have DSL it will run a little slower but very consistant and will almost never cut out.
Words of wisdom: Never turn off your PS3 from the back when the system is powered on; Once a month use canned air to clean out the ventalation system in your PS3; Keep good distance around your vents to give it a healthy air flow; Never set it on carpet as this could pull up more dust and dirt than usual; and when inserting your PS3 disc's try never to touch the shiny part and always either put it back in the case, or what I do is use the lids to my blank CD's to store them in.
Good luck and please rate my solution accordingly.
V/r,
Coldissickofman
Jan 25, 2010 | Sony Playstation 3 (PS3) Console
Connection problem for ps3 internet
cant you attach the old wireless router to one of the expansion slots in the new wireless router and have the old one for ps3 only and the new one for everything else
Dec 30, 2009 | Sony Playstation 3 (PS3) Console
Dns error (PS3)
start from scratch and set it to detect automatically. reset the router.
let me know
thx
Aug 01, 2009 | Sony PS3 40GB Best Sellers Bundle Console
Trying to set up internet for ps3 we purchased used error code 800100a
either manual scan for internet connection or set to wired connection. if nothing changes do a FULL RESTORE under system settings. this usually fixes everything wrong.
Jul 20, 2009 | Sony Playstation 3 (PS3) Console
PS3 Wireless connection
Is your error message relating to security or what exactly? Please try and post the error you are receiving.
Jan 11, 2008 | D-Link DSL-G604T Wireless Router
Sony Playstation 3 (PS3) Console Logo
876 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
